Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Asus P5K3 Deluxe WiFi AP with DDR3
http://www.bit-tech.net/hardware/200..._deluxe_ddr3/1
Asus P5K3 Delxue WiFi AP is the DDR3 version of the P5K Deluxe with an updated heatpipe array and support for DDR3 1333MHz FSB. Is the new memory technology worth investing in? We take an in depth look at DDR3 to try to find out.
__________________
#2 |
Hypermodder
On the second page, you made a mistake.
"Supports up to Supports up to 8GB of dual channel DDR3 800, 1066 and 1333MHz FSB, using four 240-pin, 1.5V DDR3 DIMMs;"
__________________
[Q6600@3.08GHz, 8GB RAM, 1TB HHD,Gigabyte 512MB 8800GT,700W PSU,Win7]
[Xubuntu Home File Server] [CompTIA A+ Certified][75% Through Cicso CCNA] |
#3 | |
I pwn all your storage
Also, with the slightly tighter timings on the RAM would it be possible to request a re-run of the Photo test? To see what kind of a difference it made? |
#4 |
Hypermodder
Lol, "oh and a ton of performance DDR2, a large monitor, a better graphics card and perhaps a new car or apartment as well" Good read.
__________________
#5 |
ITS OVER 8000!
The only problem I can see are those DIMM slots. I know you say they don't get in the way of the GPU, but on my Asus A8N-SLi Deluxe, the memory fits in, but you can swap moduals while the GOU is in there, which is a pain when you've got a water-block on there ect.
DDR2 still seems king until at least after Christmas... |
#6 |
Supermodder
Out of curiosity, is there a big difference in the network performance between the gigabit ethernet port running on the PCI-Express and the PCI one?
__________________
If it isn’t broken, fix it. If it is broken, mod it till it looks like it's meant to be broken. |
| Dr. Strangelove |
| View Public Profile |
| Find More Posts by Dr. Strangelove |
#7 | |
Richard Swinburne
bit-tech Staff
)Doc: I'm still looking for a utility that will test it properly and consistently. In theory, PCI-Express is better because it doesn't share a bus, but I can't give you solid numbers. |
#8 |
I'm not too fussed about the FSB, I mean the 6-6-6- timings rather then 7-7-7
#9 | |
Pewlius Caesar
bit-tech Staff
Theoretically, you can get Gigabit throughput on a PCI-based Gigabit Ethernet controller in perfect conditions if there are no other devices using the bus (33MHz * 32-bit = 1056Mbit/sec), but no condition is ever perfect. It's much easier to achieve maximum throughput on a PCI-Express based device because these limitations aren't in place.
__________________
#10 | ||
Supermodder
->Bindibadgi, I think saw some network tests done with a program called something like chariot, not sure if i remember correctly or whether it's any good
__________________
| Dr. Strangelove |
#11 |
When did I get a custom title!?!
DDR2 started slower than the fastest DDR1 but now DDR2 is alot faster than the fastest DDR1. I would expect a similar patten here
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#12 |
Licenced idiot.
I feel sorry for those that think they can live with the Analog Devices sound chips seen in Asus boards.. It's a bit like thinkg you can live with drugs! I've had so terrible head**** with the drivers I can't describe it here due to the censorship, but I guess you can figure out yourselves how pissed I am. It's not like you couldn't use the integrated sound card at all or the quality was terrible, but cmon the drivers! I really don't want to open them even every setting would be wrong, because I know I'll just get a terrible headache.
For a high-end mobo I'd really love to see something a bit more.
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#13 |
Richard Swinburne
bit-tech Staff
Doc: Thanks! I'll look it up. For most people 10/100 will be enough unless you're frequently copying large files. Even HD streaming over Fast 100M Ethernet is doable. I used it with a NAS box we've got at my parents house and only when my bro & sis are watching video from it and my dad is copying files to/from it it starts to chug and we could do with Gigabit.
ADI sound chips are ****ing awful. When I see Asus at Computex I'm certainly gonna ask WTF they are doing. |
#14 |
ITS OVER 8000!
( we have to have 10/100/1000 at school, complete pain )
Bindi @ Yeah, you give'm what for!
#15 |
Multimodder
I really like this mother board
I have done all the reading up on it at Asus' website www.asus.com There is only a few problems with it it uses the Intel P35 chipset but doesn't have PCIe 2.0, Intel only released that info after the boards were made also it is now out of date because of the Intel X38 chipset buy the time i can aford one of thies boards there will be a much better one we need to hear what companies like Asus and Intel are thinking for a year ahead, then I can plan a buget and build an awsome PC as soon as the parts come out
__________________
CPU: Intel i7 920 (Stock) |RAM: 6GB OCZ Reaper HPC DDR3 1866MHz | Mother Board: Asus P6T |Graphics: Dual BFG GeForce GTX295 rev.B(Quad SLI) | PSU Antec TPQ-1000 | CPU Cooler: Cooler Master V8 | Hard Drives: 500GB Seagate Barracuda, 500GB WD Caviar Black, 1TB WD Carviar Green | Optical Drive: Pioneer DVR-216D |Case: Cooler Master HAF 932 | Monitor: LG W2343T 23" |OS: Windows 7 Pro 64bit |
| ./^\.Ace./^\. |
| Find More Posts by ./^\.Ace./^\. |
#16 |
Richard Swinburne
bit-tech Staff
But you get to buy a whole new board with P35 and PCIe 2.0 sometime later. In hindsight though, noone needs PCIe 2.0 until a graphics card supports it.
#17 |
avatar not found
Will PCI-E 2.0 graphics cards work in older PCI-E slots or would a new motherboard be necessary? Is the reverse true?
__________________
E4400 - Asus P5B-Plus - Antec NeoHE 500 - 4GB OCZ SLI XTC - EVGA 8800GT - 250GB WD + 320GB Seagate
Lian-Li PC-61 - Zalman Cooling - Creative GigaWorks T20 - AG Neovo M-17 Dell XPS M1330 - T8300 - 4GB Ram - 8400M GS - 250GB HDD |
| Gravemind123 |
| Find More Posts by Gravemind123 |
#18 | |
Multimodder
__________________
| ./^\.Ace./^\. |
#19 |
what is the cheesecake?
your sig is ****ing huge. make it smaller.
stop bumping threads with useless information and flawed arguments
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D." I'm a pretentious git with a camera. ISPs want to spy on you. Join the fight against phorm XBL/PSN/Steam ID: FodT |
#20 |
What's a Dremel?
THE "AMD Athlon 64"
Hi,
Does "AMD ATHLON 64 FX-74" Compatible with "Asus P5K3 Deluxe" OR any other DDR3 ASUS' Mainboard?? Regards, _ABM ~ Vulcan Raven, Giant & Shaman Last edited by Bindibadgi; 8th Sep 2007 at 16:45. Reason: It doesnt need to be blue or size 6 |
| Thread Tools | |
