RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th May 2007, 16:18   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Cooler Master GeminII
http://www.bit-tech.net/hardware/200...ster_geminii/1
CPU Heatsinks are getting bigger and bigger and the Cooler Master GeminII is no exception. With two 120mm fans this thing will cool your entire system, and probably vacuum the carpet as well.
Tim S is offline   Reply With Quote
Old 25th May 2007, 16:31   #2
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin will become famous soon enough
Good review... and y'know, don't mention it bending the mobo :-P
__________________
Desky
E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690
Tulatin is offline   Reply With Quote
Old 25th May 2007, 16:47   #3
Dr. Strangelove
Supermodder
Dr. Strangelove's Avatar
Dr. Strangelove is on a distinguished road
Yeah I noticed that too.
But really is this not just a step too far? I mean there must be a better way to improve cooling. Maybe another gas/liquid in the heat pipes, who knows...
Also do you have any idea of how the original Intel cooler performs compared to the ones in the review?
PS. What happened to that liquid metal cooler I remember being talked about?
PPS. what about that Intel water cooler with built-in pump?
__________________
If it isn’t broken, fix it.
If it is broken, mod it till it looks like it's meant to be broken.
Dr. Strangelove is offline   Reply With Quote
Old 25th May 2007, 16:48   #4
bumfluff
Hypermodder
bumfluff is on a distinguished road
Thats what I was thinking, soon motherboards will be made of metal to support the weight of the CPU coolers, but then they won't work because all the connnections will be shorted. Life's a bitch, what do you do?
bumfluff is offline   Reply With Quote
Old 25th May 2007, 17:13   #5
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
So basicly that's an enormous cooler that's heavy, expensive, requires two expensive fans and then performs poorly? I'll skip that one, thank you.
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 25th May 2007, 17:22   #6
bumfluff
Hypermodder
Don't forget it will break your motherboard aswell unless it is made out of some space age material.
Old 25th May 2007, 17:31   #7
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul has a spectacular aura aboutBauul has a spectacular aura about
I'm still waiting on oil filled desktop cases.
To be honest with a cooler THAT big, it had to be simply mindblowingly efficient for me to ever consider it, and it's not, it's not even particularly efficient, so no thanks.
__________________
Pentium 4 CPU 3.4 Ghz | 1Gb + 2x512Mb Corsair DDR2 667 Mhz
Sapphire Radeon HD 4770 512Mb| WD Raptor 36Gb, Seagate 300Gb | Asus P5LD2 SE
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 25th May 2007, 18:29   #8
konsta
Multimodder
konsta is on a distinguished road
Will stick with my 9700... That one looks ugly in the extreme, and I don't like the idea of not being able to get at my ram if I should want to do anything with it.
konsta is offline   Reply With Quote
Old 25th May 2007, 18:48   #9
KMS-oul
You think you know me.
KMS-oul's Avatar
KMS-oul is on a distinguished road
OMG it's the crushinator. That thing is totally insane.
KMS-oul is offline   Reply With Quote
Old 25th May 2007, 19:23   #10
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
I was mighty tempted to buy one when I first saw it in the store. Now I'm glad I didn't. Thanks for the review
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Old 25th May 2007, 19:29   #11
mikeuk2004
What you Looking at Fool!
mikeuk2004's Avatar
mikeuk2004 will become famous soon enough
Thats ............ I have no words except stupid. Might as well use a CAR radiator lol
__________________
-|- Xfire - Mikeuk2005 -|- Xbox Live - Mike UK 2006 -|- Playstation Network - Mikeuk2004 -|-
mikeuk2004 is online now   Reply With Quote
Old 25th May 2007, 20:29   #12
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
How would a Scythe Infiniti compare?
I'm pretty sure that it would do better..
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 25th May 2007, 22:23   #13
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
I like the large surface are I think it may be able to run passive with a low end cpu (E6300 for example). Would depend on case ventilation though. Although frankly the bent mobo pick gives me nightmares :|
*'inq said that the liquid metal cooling was a pr stunt and could never be made cheap enough for mass production.
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 25th May 2007, 22:30   #14
Tulatin
The Froggy Poster
Tulatin's Avatar
The "liquid metal" was a gallium based thermal paste; but considering it's expense, and habit of eating other metals, it wasn't happenning.
As to other liquids within heatpipes, Asetek filled their Vapochill Micro units with R404, then had the base be a part of the grid - removing the plate, and often, the poor contact that the heatpipes would have with it.
On the scale of "extremes" this cooler is truly nothing. It may be 240mm wide (and thensome) but in terms of weight and surface area, it falls behind other beastly coolers like the Thermalright Ultra 120 Extreme, or their upcoming IFX140.
So yeah, it's possible to make coolers using other materials and methods, it just doesn't seem viable expense wise. As to using inbuilt WC systems, they suddenly become more complex and risky. Flawed units don't just result in noise and heat, but rather in leaks. A few years back i believe it was Evergreen Technology that made a 60mm rad dealie. Pull the tubes, and out spilled the coolant, smelling of alcohol. Would you want coolant all over your hardware?
Perhaps what i'd see as the "best" to-be cooler would be something like what asetek did long ago, but stronger. Have a sort of waterblock base at the bottom of the unit; a grid inside which a refridgerant flows over. Have it dump into 4 massive pipes (much like the 1/2" units on the VCM), which then fly up into a tower, a-la the works of now. Combine it with good (easy) mounting, and you're set.
__________________
Desky
Old 26th May 2007, 00:36   #15
Kipman725
Kipman725's Avatar
Fin density looks less than the thermalright which is why I thought it may be good for passive cooling.
__________________
Old 26th May 2007, 00:39   #16
Duste
Sierra my delta, bravo!
Duste is on a distinguished road
Yeah, in almost all the pictures, you can see the motherboard bending severely. Moreso on page 2, I believe.
Duste is offline   Reply With Quote
Old 26th May 2007, 02:12   #17
Oclocker
I Mod, Therefore I Own
Oclocker's Avatar
Oclocker is on a distinguished road
As far as the bending mobo goes - i am surprised no skt 775 load spreader is in pictures of parts. was one supplied ? bending of mobo is down to it being bolted down sans loadspreader rather than weight of cooler ? if on supplied for 478/939 then even more needed for 775 imho..
on checking coolermasters site/manual - they seem to only supply a 478/939 backplate - obviously they reckon the 775 mobo can take the strain when screwed in place - even if I was happy with that (I wouldn't be) its still likely to be stressed as in the picture for a short while before fitment & I often want to run mobo out of case anyway. seems like stoopid peny pinching to me.
__________________
e-mail njc123@gmail.com
msn same
Oclocker is offline   Reply With Quote
Old 26th May 2007, 03:35   #18
Sparrowhawk
Wetsander
Sparrowhawk's Avatar
Sparrowhawk is on a distinguished road
When I first noticed this on the mainpage, I honestly thought Cooler Master had made a stand-alone waterblock and radiator combo. Judging from the temps, it might have actually worked better if it was a water-based cooler.
Sparrowhawk is offline   Reply With Quote
Old 26th May 2007, 09:49   #19
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
There is one on the way
Old 26th May 2007, 11:25   #20
Mankz
ITS OVER 8000!
Mankz's Avatar
Yay!
__________________
Sig'd!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
