RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th May 2007, 14:05   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
First Look: Corsair CM3X1024-1333C9DHX
http://www.bit-tech.net/hardware/200...24_1333c9dhx/1
DDR3 is hot off the press but does it offer the performance and scaling it's been marketed to provide? Corsair hooked us up with its latest 1333MHz XMS3 modules with DHX cooling so we could find out exactly how DDR3 compares to DDR2.
Tim S is offline   Reply With Quote
Old 28th May 2007, 14:34   #2
samkiller42
KEEP IT CLEAN!
samkiller42's Avatar
samkiller42 is a jewel in the roughsamkiller42 is a jewel in the roughsamkiller42 is a jewel in the roughsamkiller42 is a jewel in the rough
Nice review as always guys, cheers. I think i will stick to my DDR2 till i go quad core next year
Sam
__________________
The Rig: i7 920 D0, Gigabyte EX58-UD5, 12GB DDR3 1600mhz, BFG GTX295, Samsung 64gb SSD, WD 640gb Black, Samsung F2 Eco 1TB, Dell 3007WFP, Windows 7 RC.
The Netbook: Samsung NC10 Black, Intel Atom, 2gb DDR2
The Mac: Awaiting Delivery
samkiller42 is offline   Reply With Quote
Old 28th May 2007, 14:50   #3
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin will become famous soon enough
Shame Corsair, of all people, didn't have the PR guns to OC their sticks by 4Mhz out of the box...
__________________
Desky
E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690
Tulatin is offline   Reply With Quote
Old 28th May 2007, 15:03   #4
Ramble
Ginger Nut
Ramble's Avatar
Ramble will become famous soon enough
Agreed, needs to be 1337MHz before I'd consider buying it.
Funny thing is, I have no doubt that they'd raise the price for a 1337MHz module just for the idiots that would buy it.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back.
Ramble is offline   Reply With Quote
Old 28th May 2007, 16:35   #5
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Originally Posted by Hugo.B
£352...
Is there anyone here able to justify paying that much for RAM?
H.B.
You had to a few months ago if you wanted 2GB
Old 28th May 2007, 17:04   #6
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
When the Corsair PC2-8888 C4 Dominator 2Gb kit came out, it was about £450, so actually, thats not that bad for good memory.
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 28th May 2007, 17:39   #7
Highland3r
I Mod, Therefore I Own
Highland3r is on a distinguished road
Any chance you can run a test showing DDR2 @ 800 vs DDR3 @ 800 using the same timings pls? Even 1066 would be good if thats do-able, just for a quick like for like comparo.
Also, can you confirm the DDR3 was running at 760FSB please? Just a little confused as you mention 760 DDR in there too.
From those tests though, as you've said it doesn't look like a huge leap at the moment. Guess we'll see reduced timings and increased speeds as the technology progresses and refinements are made.
__________________
Prawn or not...?
Highland3r is offline   Reply With Quote
Old 28th May 2007, 17:48   #8
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Ah crap, I forgot to put these pics in nm.
It's not 760FSB, it's on a 1:2 divider, so it's 380FSB*2.
The lowest timings we'll see are probably CAS6. I'd have to set the DDR2 timings more relaxed because the DDR3 won't do DDR2 speeds, but at the same speed DDR3 will out perform DDR2 due to a better prefetch and burst rate.
I'll see if I've got time in the week, but I've moved onto other stuff now and the boards are disassembled.
Bindibadgi is offline   Reply With Quote
Old 28th May 2007, 19:14   #9
Oooo
Minimalist modder
Oooo is on a distinguished road
It doesn't get better than DDR2 on an Intel system.
But am I wrong saying AMD use more bandwidth?
If not, than wouldn't DDR3 @ 1600 make a real big memory performance increse when they relese a chip that support it. Even tough the latencies are a bit high.
__________________
THE System= CPU Core 2 Duo E6300/ Mobo Gigabyte P45 / GFX HD 4850/ Memory Corsair XMS2 6400 3 GB / Badly modded Antec 300
Oooo is offline   Reply With Quote
Old 28th May 2007, 19:36   #10
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
AMD has an internal controller that allows them a far lower latency and higher overall bandwidth. You get around 8000MB/s on a good AMD AM2 system.
Old 28th May 2007, 19:59   #11
Spaceraver
Weekend Junkie
Spaceraver's Avatar
Spaceraver is on a distinguished road
They should consider supporting DDR2 for a few years yet, that way the current chipsets can mature a bit more. We need better timings instead
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca
Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard.
Spaceraver is offline   Reply With Quote
Old 28th May 2007, 20:12   #12
samkiller42
KEEP IT CLEAN!
What motherboard did you use for the tests can i ask?
Sam
__________________
Old 28th May 2007, 20:48   #13
TRG
Minimodder
TRG is on a distinguished road
He used the P5K3 Deluxe and P5K Deluxe.
On pages 5 and 6, shouldn't the charts say "Frames per second (higher is better)" instead of "Time in seconds (lower is better)" ?
TRG is offline   Reply With Quote
Old 29th May 2007, 00:45   #14
Morphine-Kitty
Dead account.
Morphine-Kitty's Avatar
Morphine-Kitty is on a distinguished road
I noticed that too. Other then that, good article.
__________________
Not posting on this forum anymore...
Morphine-Kitty is offline   Reply With Quote
Old 29th May 2007, 01:15   #15
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
Great article, but ridiculous price for basically 0 performance gain.
For the price of the P5K3 deluxe and the cheaper, slower DDR3-1066MHz C7 modules, you can buy a P5K Deluxe plus 3 (yes, 3!) sets of Crucial PC8000-C5 Ballistix (nearly the same as the Corsair PC8000C5 Dominator, but £50 cheaper). Madness.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is online now   Reply With Quote
Old 29th May 2007, 09:08   #16
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Originally Posted by samkiller42
What motherboard did you use for the tests can i ask? Sam
It seems so obvious now someone points it out. I was concentrating on getting all the numbers for the memory right I forgot to put the test setup in. It's now back on page 2, in full.
Done! Forgot to change it from one graph to the next
Old 29th May 2007, 10:38   #17
Henk
Uninformed Opinionist
Henk is on a distinguished road
Interesting article, I wonder how long before DDR3 will be as affordable as DDR2 is now...
Also, this just doesn't seem right:
Originally Posted by Article, page seven
The modules look great, perform as you'd expect but most importantly scale really very well.
Henk is offline   Reply With Quote
Old 29th May 2007, 13:38   #18
ComputerKing
ComputerKing's Avatar
ComputerKing is a jewel in the roughComputerKing is a jewel in the roughComputerKing is a jewel in the rough
LOOL . DDR3 Never thought that.. thanks for the disappointing. Nice review
__________________
GigaByte Triton 180|GigaByte EP45-UD3LR|Intel Q9450|Transcend 4GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|3TB WD Green
The King Of CK Appreciation Society Group
ComputerKing is offline   Reply With Quote
Old 29th May 2007, 14:20   #19
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Well, they *do* look great. They *do* perform as you'd expect: higher latency at same speeds = slower, higher frequency than DDR2 = still pretty quick. Scales well: 1520MHz from 1333MHz modules is pretty damn good imo.
Old 29th May 2007, 17:42   #20
Henk
Yes, I agree with that. It was just the wording "really very well" that caught my attention, it didn't look right I guess I'm a bit too picky sometimes
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
