Thread Tools | View Mode |
#1 |
Supermodder
Project "Tikki Aquarium" - [update 040707: piranha madness]
In the last few days we decided to start another new project.
It will be a custom build Aquarium in shape of a Tikki Mask. First we startet to build the Aquarium itself, therefore we used a 30cm plexiglas tube and a sheet of uv active plexiglas, we transfer the outline of our tube to the sheet of plexi and cut it out. After that the Plexi circle was glued on one side of the tube to seal it, so it can hold the water in. After that we made a first test run with water etc to see if everything is fine and there is no water coming out. ![]() ![]() Then we started to build the Head of our Tikki Aquarium. ![]() We take some sheets of styropor and glued them together to get the right dimensions to fit on top of the tube, then we made some paper clay and put it all over the Head. After the Paper Clay dried out we put a sheet of raw carbon on top of the head to make it more solid. ![]() ![]() Then we mixed some bondo and put it all over the head to get a smoot and flat surface on which we can build the details for the tikki face ![]() ![]() ![]() ![]() After a lot of sanding and grinding we could then start to airbrush the head in a real wood style... ![]() ![]() Airbrush Video on Youtube Beside that we already start to build the "main" case which will contain the hardware and will be placed under the Aquarium part. For that we make 2 sheets of plexi, on one the mainboard will be mounted on the other we will mount PSU, Pump, Radiator and HDD. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Multimodder
oh nice. is the two cylindrical things the reservoir or something?
pump? |
#3 |
Multimodder
Looks nice. the dual reservoir is a nice idea too. cant wait to see how it turns out.
#4 |
Supermodder
Nice start, I like the acrylic work.
#5 |
Multimodder
Good work, can't wait to see more
#7 |
Supermodder
Awsome! Can't wait to see it finished
__________________
OS-formers Less than meets the eye! Windowsbots wage their battle to destroy the evil forces of the Mac-icons. OS-formers, Both lame in diguise.OS-formers,Less than meets the eye. Tranformers-I mean OS-formers! |
#8 |
Supermodder
great work!
#9 |
Stopp the Relix guy
nice idea! will you route the water cooling tubes true the aquaruium for heat exchange/heating the aquarium?
__________________
Gaffa-Tape is a very simple modding device ![]() <sings>I'm from AUSTRIA</sings>and NO we have no kangaroos ![]() Microsoft NEVER stopped the beta phase of any of its operating systems i will not apologize for my language skills |
#10 | |
Supermodder
[small Airbrush update]
thank you guys for your comments!!
here is a small update about the airbrush progress on the upper part.... ![]() ![]() Airbrush Video on Youtube Quote:
#11 |
Licenced idiot.
Awesome painting there, looks nice and woodish
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#12 |
Minimodder
Looks good so far, nice attention to detail with the paint job. I was actually thinking about combining a pc and an aquarium myself. Can't wait to see the finished result.
| nissanskyrice |
| View Public Profile |
| Find More Posts by nissanskyrice |
#13 |
Multimodder
Very cool! Tha airbrushing is top notch! I love it. Also, that green plexi is a nice touch. NOw are the tubes going to run through the tank's water at all?
__________________
He's no different than the rest of you organisms... shooting DNA at eachother to make babies. |
#14 |
Supermodder
just a small update for today.......
we prepared the inside of our "Head" to fit in the LED Module which should bring some light to the aquarium..... ![]() i think tomorrow the cable will be covered and we will start to build the base part where the hardware will be mounted in..... |
#15 |
Hypermodder
That wood grain is pretty damned awesome. Cant wait to see how it turns out.
__________________
[hal]"I cant let you do that Dave....."[/hal] "Out the 100 Base-T port, past the Router, off the Bridge, through the Firewall..... Nothing but Net." |
#16 | |
Modder
#17 |
Hypermodder
Nice work!
__________________
[Q6600@3.08GHz, 8GB RAM, 1TB HHD,Gigabyte 512MB 8800GT,700W PSU,Win7]
[Xubuntu Home File Server] [CompTIA A+ Certified][75% Through Cicso CCNA] |
#18 |
Hypermodder
Eh?
I know how it was done, I was commenting on how great the effect was and that I am waiting to see how the rest of the mod turns out.
__________________
#19 |
Supermodder
Great work. Very very nice until now. Think this is going to be a great mod. *Subscribed*
#20 |
I *am* The Stig
wow great looking job, can't wait to see more on this mod
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
| Tags |
scratch build ![]() |
| Thread Tools | |
| View Mode | |
