RSS
Reply
Thread Tools View Mode
Old 31st May 2007, 12:35   #1
Fozzy
Ultramodder
Fozzy's Avatar
Fozzy is on a distinguished road
Tribal HTPC - UPDATE 12: SPONSORS!! Koolance and DangerDen
Hello everyone I'm back again and I'm ready to mod. Some of my last creations are/were Fozzbox (v300), Hellgate:Lian-li (v1200), and Diablo (clear case mod). Today I start a brand new project which is yet to have a theme or even a propper name. This all really doesn't matter though because there is plenty of work to do before I even start worrying about that. Let me share with you the plan for this mod.
Sponsors:
Components:
- 2 Box design
- Metal Fabrication
- Custom wireing
- Single water cooling loop
- 3 HDD Slots
- 3 5.25" Bays
- Single PSU Slot
- Full Size ATX
- Radiator cover for second (internal) Dual 120mm Radiator
- Removeable motherboard tray with Quick Disconnects for easy access
- Modular Fans/Lights for Silence/Darkness and for Show/Performance
- HDD Silencing for Theater enviornment
- Tribal Cut-outs or Themed cut outs (more on that later)
- Compartmentalized CD/HDD/PSU Bay to seperate cabling/ heat from the main compartment.
- 6 120mmx38mm Fans for effecient cooling
- Powder Coating
Hardware:
Undecided
Tools required for this mod:
- Sheet metal Brake
- Dremel
- Drill/Drill Press
- Rivet Gun
- Tap and Die
- File Set
Materials Required:
- Sheet Aluminum
- Modders Mesh
- Motherboard Tray
- 6 120mm Fans
- Angle Aluminum
- M3 Fasteners
- Guitar Jacks male and female
Current stage of the mod:
Fozzy is offline   Reply With Quote
Old 31st May 2007, 14:14   #2
widmod
Stopp the Relix guy
widmod's Avatar
widmod is on a distinguished road
please use sketchup to prevent eye cancer
__________________
Gaffa-Tape is a very simple modding device
<sings>I'm from AUSTRIA</sings>and NO we have no kangaroos
Microsoft NEVER stopped the beta phase of any of its operating systems
i will not apologize for my language skills
widmod is offline   Reply With Quote
Old 31st May 2007, 14:18   #3
x06jsp
da ginger monkey!!!!
x06jsp's Avatar
x06jsp is on a distinguished road
lol loving the 'high-tech' drawings, seriously though even just use paint or photoshop if you cant use sketchup!
x06jsp is offline   Reply With Quote
Old 31st May 2007, 16:47   #4
Mr. Oizo
That yellow furry animal-thingy
Mr. Oizo's Avatar
Mr. Oizo is on a distinguished road
I like it!
Even the #1 Casemodder 2006 of Holland draws his designs with a pencil. So, it actually works
Mr. Oizo is offline   Reply With Quote
Old 31st May 2007, 18:00   #5
x06jsp
x06jsp's Avatar
yer but he could use a ruler! lol
Old 1st Jun 2007, 07:04   #6
Fozzy
Ultramodder
Fozzy's Avatar
Haha sorry guys about the sketches. My sponsors wanted their names out there and I desperately needed to get something out for show. Sketchup will come soon and I'll replace these horrible pictures. Sorry for that.
Old 1st Jun 2007, 08:41   #7
x06jsp
x06jsp's Avatar
phew!
Old 1st Jun 2007, 10:23   #8
Evenge
Supermodder
Evenge is on a distinguished road
I love your previous works, and will follow this one also!
Evenge is offline   Reply With Quote
Old 1st Jun 2007, 10:34   #9
fungry
Multimodder
fungry is on a distinguished road
haha interesting erm hand drawn plans still beats no planning for sure.
i like this comment made in one of bit-tech's Project Mod articles
if you fail to plan, you plan to fail ^^
fungry is offline   Reply With Quote
Old 2nd Jun 2007, 09:43   #10
Fozzy
Ultramodder
Fozzy's Avatar
Thanks I appreciate it. Lots of personal obligations right now so this mod will be slow moving. Hope you'll stay for the ride.
Old 4th Jun 2007, 08:59   #11
Fozzy
Ultramodder
Fozzy's Avatar
As an apology for the horrendous pics that I gave you earlier I am refreshing the design with a few sketch-up pics. These are early pics and are here just to show how the case is coming along in terms of design. They are simple for now but this is because I am going slow in order to get everything perfect. Once I start bending metal it will be very expensive if I come up short by even a few mm. But enough talk. Here we go.
Image number one shows the case structure. With the CD Drives on the left and a dividing wall in the middle. The dividing wall separates th motherboard and the drives making the final effect much cleaner. It will also allow me to do some cool passthroughs with the cables. The dividing wall is much more complex and will be changed tomorrow night when I get back to work.
Image 2 shows the case from the back with the mothaboard cut-out. I've decided not to use a removable motherboard tray because I've found a motherboard plate from an old case that will work better.
Top view
Full-frontal
Old 5th Jun 2007, 02:08   #12
Teyber
Teyber's Avatar
Teyber will become famous soon enough
you shouldn't start a thread till you have started the project, its on the rules. But, what do you use for hosting images?
__________________
cheapskate is (not) a noob
Teyber is offline   Reply With Quote
Old 5th Jun 2007, 05:03   #13
Fozzy
Ultramodder
Fozzy's Avatar
I use photobucket free accounts. They give you about 3 pages for free then you have to make a new account lol. I should just pay for one but I'm cheap. Also I know that you aren't supposed to do this but a lot of time goes into sketchup models and it's nice to get feedback while I'm working on them. Somebody else might notice something important before I screw up.
Old 5th Jun 2007, 07:29   #14
Fozzy
Ultramodder
Fozzy's Avatar
More sketch-up work and my vision is taking shape. Here's a few more pictures of what I'm going for with the dividing wall. Originally it was going to encompass the HDD's as well but now I'm going to go with split sections so I can add and remove HDD's easier and allow better ventilation for the Hard drives.
Old 5th Jun 2007, 09:21   #15
fungry
Multimodder
taking shape. i'm beginning to like it.
i reckon sketchup should count as part of "starting a project". just as long when they are done planning, they do start it. otherwise its pointless.
my opinion anyways.
Old 5th Jun 2007, 10:50   #16
Koradhil
Supermodder
Koradhil's Avatar
Koradhil is on a distinguished road
Fungry is correct, you should've read the rules:
2. Your first post must contain pics of the actual mod in progress. If all you have is an idea, you don't have a log. If all you have is some conceptual sketches, you don't have a log. If all you have to show is a heap of parts, you don't have a log. This forum is purely for concrete work in progress - the other modding forums are more appropriate for concepts and thoughts.
__________________
» BRAND NEW SITE
Projects: Nimex | Gemini | Aquamedia | Mystique | Orion | Protoss
Powered by A.C.Ryan, Cooler Master, Corsair, EPoX, PQI, Recom, Revoltec, Sapphire.
Koradhil is offline   Reply With Quote
Old 5th Jun 2007, 15:25   #17
Fozzy
Ultramodder
Fozzy's Avatar
my opinion anyways.
Well since I'm having everything CNC cut then that is completely accurate. As soon as the planning is finished the work begins.
Old 5th Jun 2007, 15:37   #18
fungry
Multimodder
CNC? unabbreviate please
anyways! was looking at those sketchup drawings again and was wondering, are you going to make your own mobo tray + back panel are you just gonna rip one off some other case?
Old 5th Jun 2007, 15:37   #19
saltynay
Multimodder
saltynay is on a distinguished road
how do you get a sponsor for a mod??
saltynay is offline   Reply With Quote
Old 5th Jun 2007, 15:45   #20
fungry
Multimodder
you build your reputation as a modder.
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
