Thread Tools |
#1 |
Brett Thomas
Apple launches iTunes Plus
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
\o/
I installed 7.2 last night, and bought an upgrade to the higher quality DRM-free versions of the music in my library, so I can replace the lower quality files I already have. I wasn't able to download them all however as the network kept timing out, I presume there's a few million other people doing the same.
One thing people should know is that your username and email address will be stored in each iTunes Plus file, so sharing it via P2P is a very bad move.
__________________
Denying Rights to Music lovers. Denying Rights to Movie lovers. |
#3 |
Hypermodder
its about time to be honest, and i bet they are making a killing by charging slightly extra to upadte and buy the DRM free songs, although the higher quality is a great incentave!
__________________
Penguin v5.0 on it's way... AMD Phenom II X4 955 - 4Gb 1600Mhz Corsair Dominator - XFX Radeon HD 5850 - Corsair HX650W - 500Gb Samsung F2 |
| rowin4kicks |
| View Public Profile |
| Find More Posts by rowin4kicks |
#4 |
Madeira's banana is the best!!!
it is really stupid to tax extra for something that has no DRM and will not be hit by the premium that costs to develop the DRM.
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key! |
#5 |
I pickle they
Last edited by pendragon; 31st May 2007 at 16:41. Reason: damn you spelling, you are a harsh mistress! |
#6 |
\o/
To be honest, it serves you right if you buy a song from iTunes and start spreading it around the internet and end up getting caught.
__________________
#7 |
Hypermodder
how long before someone makes an app to strip the personally identifiable info from the files, not long I'm betting
however, i suspect apple has more intricate buried info that isn't quite as obvious |
| completemadness |
| Find More Posts by completemadness |
#8 |
Banned
Another step on the way to reasonably priced, all you can eat, DRM free, high quality, legal music services. Good to see the march of progress!
| specofdust |
| Find More Posts by specofdust |
#9 | |
The Real Pacman
bit-tech Staff
A step in the right direction, if only buying mp3's wasn't so expensive for albums.
__________________
XBL : Shogun Hiren Homepage | HD Tach | Last.fm | DeviantArt bit-tech newsletter | bit-tech Blog |
#10 |
Supermodder
*snip*
| plug_in_ross |
| Find More Posts by plug_in_ross |
#11 |
I *am* a Dremel
#12 | |
Hypermodder
Sounds reasonable enough to me, but i all ways feel apple are rather underhanded in their business practises, they should tell you they are going to embed your info into the file (especially if its encrypted) But as i said, i think this is just another way to dissuade non criminals (like a lock on a door) - criminals will just find a way to alter/remove the watermark and then the system fails |
| completemadness |
| Thread Tools | |
