RSS
Reply
Thread Tools View Mode
Old 5th Jun 2007, 00:30   #1
Pfaffen
Multimodder
Pfaffen's Avatar
Pfaffen is on a distinguished road
Project Fibonacci Sequence
Well this is my second mod. And the first I'm doing as a Project Log.
I decided to make the case in dimensions based on the Fibonacci sequence
1, 1, 2, 3, 5, 8, 13, 21, 34, 55.
The design is to make the case in the proportions of the Fibonacci sequence. But if I used 1inch then the case would be 13x21x34 in any combination, that is one big case. So I decided to use .75in per unit and that way it was much more manageable dimensions and I deciced to make it square on top.
So, I started last night with this piece of walnut.
It was 6 x 36 and 13/16ths. After I cut the rails and stiles and ran them through the planer they were exactly 3/4in square.
Here are the shavings from planing them.
Next I cut the rails and stiles to length.
4 stiles and 9 rails, just in case I need an extra.
Next came laying out the pieces so far and labeling them.
I liked the blue painters tape, because it came off cleanly and was easier than trying to read pencil marks on the wood.
Next was cutting the tenons. I used a tenoning jig for the most part and then used the fine tooth saw to finish the job off.
The next was to cut the slots on the rails for the mohagany inserts. The are spaced out in the same sequence 1,1,2,3,5,8 (3/4in per unit)
Here is a top view shot
and lastly, here are the stiles cut with all the rabbits to recieve the plexiglass.
Next step is to mortice the holes in the rails to recieve the stiles. I'm not sure I like the half lap joints, I wanted something simple, in keeping with the design, but not sure what other strong joints are out there that are strong enough with 3/4in stock.
More to follow...
Pfaffen is offline   Reply With Quote
Old 5th Jun 2007, 01:21   #2
Rocket733
Austerity - It's the only way
Rocket733's Avatar
Rocket733 will become famous soon enough
Looking good so far. Why kind of woodworking background do you have seeing as how you have all these nice tools?
Rocket733 is offline   Reply With Quote
Old 5th Jun 2007, 02:01   #3
Pfaffen
Multimodder
Pfaffen's Avatar
Started out Small
I started about 10 years ago, just making small things, boxes, shelves, nothing really to speak about. Then as I collected more (what I could afford) tools, I began to build other things. Now, I'm building cases. Would still like to get a band saw and a stationary router table to complete my work room. I liked the blend of wood working and computers.
Old 5th Jun 2007, 13:21   #4
widmod
Stopp the Relix guy
widmod's Avatar
widmod is on a distinguished road
such case ideas happen when somebody reads to much Dan Brown
__________________
Gaffa-Tape is a very simple modding device
<sings>I'm from AUSTRIA</sings>and NO we have no kangaroos
Microsoft NEVER stopped the beta phase of any of its operating systems
i will not apologize for my language skills
widmod is offline   Reply With Quote
Old 5th Jun 2007, 13:58   #5
fungry
Multimodder
fungry is on a distinguished road
haha Dan Brown is just great. nonetheless, it is an original case.
but is there a way to exemplify that this case is built based on the fibonacci sequence? like have numbers engraved all over the case to display that. because without some fibonacci indicator, i would think this case is something BUT based on fibonacci.
my point is, somehow suggest to the audience the significance of your case. would be very interesting.
fungry is offline   Reply With Quote
Old 5th Jun 2007, 15:39   #6
dacust
What's a Dremel?
dacust's Avatar
dacust is on a distinguished road
I would just put the name Fibonacci on there somewhere small and let people figure it out. Some will get it, some won't. But the seemingly randomness of the cuts will make it look interesting even if they don't.
__________________
-dan
My programs don't have bugs, they just develop random features.
WaterPlant worklog - in progress - Bit-Tech article - WaterPlant site - Home Page - PowerPlant PC - Designing
Don't worry about your english. This is an international forum. That's what makes it great. If I don't understand, I'll ask. Just MOD ON!
dacust is offline   Reply With Quote
Old 5th Jun 2007, 15:43   #7
fungry
Multimodder
hmmm yea that could probably do.
Old 5th Jun 2007, 15:47   #8
rynoman
What's a Dremel?
rynoman is on a distinguished road
looks like this will be an interesting project and will keep an eye on it.
keep up the good work
__________________
ASUS G1 laptop running vista home
p4 3.0 gigabyte mobo 250g seagate 2gig ram evga 7950gt enermax 500w in13 year old custom gateway case runnin xp home
rynoman is offline   Reply With Quote
Old 5th Jun 2007, 19:43   #9
x06jsp
da ginger monkey!!!!
x06jsp's Avatar
x06jsp is on a distinguished road
looking good! very original idea
x06jsp is offline   Reply With Quote
Old 5th Jun 2007, 22:23   #10
Pfaffen
Multimodder
Pfaffen's Avatar
Too much time
I agree. Way too much time on my hands, but I also read the Golden Ratio by Mario Livio. The concept was quite interesting and led to some lively discussions with my friends.
This the concept drawing for the left side.
I'm still toying with the idea of putting the formula, or the number sequence on the other side.
fn = fn-1 + fn-2 with f1 = f2 = 1
More to follow.
Old 5th Jun 2007, 22:35   #11
Pfaffen
Multimodder
Pfaffen's Avatar
Bottom dry fit
Here is a shot of the bottom dry fitted together.
Here is a shot of the corner. Need to tighten it up a bit.
Here is a shot of the corner with the stile removed. A little bit over shot with the drill press, but that mistake is covered up by the stile.
Here is the little jig I created to hold the pieces together while I drilled the holes.
Old 5th Jun 2007, 22:37   #12
x06jsp
x06jsp's Avatar
nice keep them coming!
Old 6th Jun 2007, 11:21   #13
jokkos
Belgian beer modder
jokkos's Avatar
jokkos is on a distinguished road
hmm an original theme for a mod. I like it so far!
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 6th Jun 2007, 16:46   #14
MikeK
Modder
MikeK is on a distinguished road
Great woodwork!
The design looks really nice!
__________________
If the facts don't fit the theory, change the facts. Albert Einstein
MikeK is offline   Reply With Quote
Old 6th Jun 2007, 17:52   #15
dacust
What's a Dremel?
dacust's Avatar
Well, there again, to follow my original idea, how about putting the formula on a sticket or badge, unobtrusive, like the "Intel Inside" or other stickers. The numbers could number the PCI slots in the rear.
__________________
-dan
Old 7th Jun 2007, 01:56   #16
Pfaffen
Multimodder
Pfaffen's Avatar
Good idea. I could put it in the bottom corner. Thanks...
Old 9th Jun 2007, 02:09   #17
Pfaffen
Multimodder
Pfaffen's Avatar
Dry Fit
Here is a shot of the bottom and the 4 stiles
All the mortices and tenons need some touch up.
Old 9th Jun 2007, 06:07   #18
The_Beast
I *am* The Stig
The_Beast's Avatar
The_Beast is a jewel in the roughThe_Beast is a jewel in the roughThe_Beast is a jewel in the rough
wow that is a great idea, BTW nice woodworking skills
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
The_Beast is offline   Reply With Quote
Old 9th Jun 2007, 14:03   #19
tolis86
Multimodder
tolis86's Avatar
tolis86 is on a distinguished road
mmmmm fibonacci nature's beauty in many ways.... keep up!! its gonna "rock"
tolis86 is offline   Reply With Quote
Old 9th Jun 2007, 14:07   #20
Pfaffen
Multimodder
Pfaffen's Avatar
Assembled
Here are a couple of shots assembled.
Here is the jig I made to do the routing of the rails. all the top rails and the bottom rails are going to have a curve to them. Should be about a 1/4 of an inch across the length.
Here is a shot of the corner. It seems there was a small adjustment to the table saw between the time I cut the stiles and the rails. That just means, you always have to double check your work.
Here is a shot from the top.
Lastly, a couple of shots for the width and height
Next step it to get the plexiglass, cut it and put it in.
__________________________________________________ ___________
Pfaffen
Case Mod: World Map - Complete
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
