#1 |
What's a Dremel?
Modular PSU made at home
Hey friends, today would like share with you a family's revenue:
Modular PSU made at home! I opened for psu and separated the cover: ![]() ![]() I used the original cover to cut a new front for for psu: ![]() ![]() ![]() I holed and I riveted the new front, keeping the old ![]() ![]() Using a micro-rectifies, I did a cut to case the connector db25, and with the drill and a thick drill, I did 4 holes for the connectors Mic ![]() ![]() ![]() I stretched the connector atx cables until the connector db25 and cut them letting a free time to weld them. (Hint: Use cables term-retractile or hot glue to isolate the cables after weld them) ![]() ![]() I passed the cable atx inside cuting, I arrested with retractile term, (watch out to do not invert the cables order), weld them in the other connector db25 ![]() ![]() ![]() I repeated the operation, now with the cables molex ![]() ![]() ![]() ![]() ![]() To improve the visual and the refrigeration, I changed for fan of psupor a colored, put a cover of acrylic and a second fan in the cover top, and I used lasergrill for the finishing. ![]() Then it was alone to close the source, and it is ready! Modular PSU made at home! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Time expense: 06 hours Money expense: (US$ 20 + PSU) The Advantage of this modification in psu cables, is just that allows a better interior organization of the case, and consequently a better refrigeration, besides you have the option of only to connect the cables that is going to use, or it adapts them its way. It is worth remind that it should pay attention in the order of the cables in the hour to welding them to do not occur any mistake, following this recommendation, there is not larger secrets. Hugs, Darth
__________________
May the Dremel be with you! |
| Darth Invader |
| View Public Profile |
| Find More Posts by Darth Invader |
#2 |
pretty fing wonderful
wow. well done.
i've been thinking about doing this to my psu for a while. hopefully this will finally motivate me.
__________________
the old: gigabyte P35, e4300@2.8GHz, 4GB DDR3-1333, 8800gts 512, win7
the new: DFI M3H5 Jr, phenom 810, 4GB DDR-1600, OCZ Vertex, debian notatoad.net fdo eff |
#3 |
avatar not found
Sweet job there, looks pretty cool as a finished product, especially when compared to the PSU you started with!
__________________
E4400 - Asus P5B-Plus - Antec NeoHE 500 - 4GB OCZ SLI XTC - EVGA 8800GT - 250GB WD + 320GB Seagate
Lian-Li PC-61 - Zalman Cooling - Creative GigaWorks T20 - AG Neovo M-17 Dell XPS M1330 - T8300 - 4GB Ram - 8400M GS - 250GB HDD |
| Gravemind123 |
| Find More Posts by Gravemind123 |
#4 |
Sierra my delta, bravo!
That's pretty cool dude.
#5 | |||
What's a Dremel?
Do yours and stake the photos here so that we can admires Quote:
Hugs from Brazil, Darth
__________________
| Darth Invader |
#6 |
Multimodder
omg that is sooooo siiiiiickkk
__________________
Check out my water cooled Lan Box! Core2Duo E6300 @ 3.1ghz | Gigabyte EP45T-UD3P | 2x2GB OCZ Reaper 1066 | 5-5-5-15 @ 1100mhz | Sapphire HD 3870 512mb @ 825/1200 | WD 200GB SATA, 500GB SATA, and seagate 1TB SATA | PC Power and Cooling 750w single 60A rail |
#7 |
Hypermodder
Hmm...DB25 and XLR connectors right?
It might have been safer to go with female panel mount jack rather than the male plug. Certainly is something I'll have to look into with a few mod ideas I've had. When I have time, money, and soldering practice. Have to find out if the panel mounts can be made waterproof though
#8 | |
Supermodder
They're very nice connectors for PSU wiring like this. If you've ever seen the "Hiper" modular PSUs, they use exactly the same connectors. |
#9 |
-Xbox Pwner-
It's called a "4-Pin Panel Mount Microphone Audio Jack", but it's easier and cooler to call it a 4-pin XLR connector. I saw this posted over at TBCS, very cool indeed.
Edit: Just did a quick search, and it is indeed XLR. XLR has nothing to do with the pins, but rather the physical connector. Those are "XLR4s". ![]() -CollinstheClown |
| CollinstheClown |
| Find More Posts by CollinstheClown |
#10 |
Multimodder
i've been meaning to do this myself for a while, i've had all the connectors sitting in a bag for a year now...never thought of using a DB25 for the atx connector though
while it might be safer to have the female plugs in the PSU, it isn't possible. the female plugs are made with a metal sleeve on the end for the cable to fit through, while the male plugs have the nuts on them to secure them in a hole
__________________
If you and dead people know hex, how many people know hex? Obligitory PC spec's: Intel Core i7 920, ASUS P6T Deluxe, 12GB Corsair Dominator PC-12800, Sapphire HD5870, WD Velociraptor 300GB HLFS, Samsung Spinpoint 1TB, Creative X-Fi Titanium Fatal1ty Pro, Logitech G15 and G9, Logitech Z-5500 5.1 speakers, Dell 2408WFP 24" monitor |
#11 |
Multimodder
wow, kickass!
#12 |
Mod Master
Well done.
I modded a PSU for use as a testing supply, and I didn't want any cables to I modded them into the housing: ![]() I wanted to do something similar with all the connectors, but the amount of filing it took for the four there, and the lack of connectors for the other kinds made me not want to attempt the mod. Your clever use of a parallel connector and microphone plugs gives the mod new light.
__________________
Latest Work: Boombox Build Project PCB- Complete Digital Picture Frame 2.0- Complete RumbleMouse - Complete Latest Project: TestPC- Complete Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W |
| mattthegamer463 |
| Find More Posts by mattthegamer463 |
#13 |
Electromodder
I'd be wary of the 25 pin D connector. Each pin is only rated for 1A, so it's a bit of a weak link in the chain - especially since it's supplying your motherboard.
#14 |
Play hard, go pr0n
Good idea the XLRs, and great job with that PSU. I think I'll do the same but I wont cut the ATX connector because I must plug it always ^^
__________________
Planet Express Klan (modding & gaming clan) --> www.pekweb.es Sorry for my bad english |
#15 |
Multimodder
I was thinking the same thing myself when I saw this SteveyG. You are better off using a larger Molex plug that will take all the wires.
| Stonewall78 |
| Find More Posts by Stonewall78 |
#16 | |
Space Monkey
That's very nice, Darth. I've been thinking of doing the same thing for my PSU. I have too many unused wires inside the case, and it would be nice to get rid of them.
![]() -monkey
__________________
But of bliss and of glad life there is little to be said, before it ends; as works fair and wonderful, while still they endure for eyes to see, are their own record, and only when they are in peril or broken for ever do they pass into song. -J.R.R. Tolkien, The Silmarillion |
| supermonkey |
| Find More Posts by supermonkey |
#17 |
I know what a Dremel is...
Wow - that is really impressive. Makes me wonder why i'm spending so much on a Corsair modular psu!
Can somebody do a guide on the cable wrapping?! |
#18 |
Relix Headshot!!
Really like the outcome. You gonna paint it though?
__________________
..::Underground::..
Chenbro Gaming Bomb - Asrock K7VT4A Pro - AMD Sempron 2600+ - Geforce FX5200 128Mb - 1024Mb 266MHz DDRAM - 80Gb 7200rpm IDE Seagate - 80Gb 7200rpm SATA Western Digital - DVD-RW 8x - Cooled by Zalman |
| ReFredzRate |
| Find More Posts by ReFredzRate |
#19 |
How many PC's do you have?
OU I like it.....I have a media PC and so so many cables that do nothing....
I should do the same, or at least remove some of the unused cables..... Good show.
__________________
Main: Gigabyte P35C-DS3R - E6750 (OC), XFX 7600GT XXX, 2xSeagate 250GB in RAID 0, 2GB PC6400 Media: Gigabyte P35C-DS3R - E6600, XFX 7600 HDMI, 2x2.5" Hard disk in RAID 0, 2GB PC6400 File Server: Gigabyte GA-G33M-DS2R - E6300, 4 x 750GB drives RAID 5, 2 x 300GB drives |
#20 |
Supermodder
Let's not call 'em XLRs, because they're not. Real Four-pin XLRs are often used for 12 and 24V power on film and TV cameras, and they're emphatically not compatible with what you're using here.
That said yes they're very suitable. I share our correspondent's concerns about the current rating on the DB25, but you'll probably get away with it. Phil |
| Phil Rhodes |
| Find More Posts by Phil Rhodes |
| Tags |
guide ![]() |
| Thread Tools | |
| View Mode | |
