#1 |
Brett Thomas
Build your own server
http://www.bit-tech.net/bits/2007/06...r_own_server/1
Have you wanted a full-functionality web-server, media host, bit-torrent client and NAS box, all fully remote-controlled? Want to build it out of spare parts? Well then... Digg to share!
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo Last edited by Da Dego; 5th Jun 2007 at 17:24. |
#2 |
Hypermodder
niceeeeee
![]() should b useful when people ask me and i can just point them here solid, simple, but concise... perfect.
__________________
Monita DFI NF4 Expert - X2 3800+ 2.925Ghz - 2x1Gb OCZ Gold XTC DDR500 - 2x eVGA 7900GT SLI - 2x80Gb Seagate 7200.9 [RAID-0 4k] - Enermax Liberty 500 - Vista Ultimate x86 - Silverstone Kublai [Modded] Keisha DFI BloodIron P35 - Q6600 3.6Ghz - 4x1Gb OCZ Gold XTC2 DDR2-800 - eVGA 8800GTS 640MB - 2x80Gb Seagate 7200.9 [RAID-0 4k] - OCZ GameXstream 700 - Vista Ultimate x86 - Silverstone TJ-06 [Modded] www.pecelayam.com |
#3 |
Hypermodder
Great guide you put together and it should help me out massively in about a month, thanks
__________________
Penguin v5.0 on it's way... AMD Phenom II X4 955 - 4Gb 1600Mhz Corsair Dominator - XFX Radeon HD 5850 - Corsair HX650W - 500Gb Samsung F2 |
| rowin4kicks |
| View Public Profile |
| Find More Posts by rowin4kicks |
#4 |
Minimodder
I'm still waiting for Windows Home Server
. Then I'll build my server.
#5 |
Hypermodder
Excellent Guide - Thank you
| TechnoScream |
| Find More Posts by TechnoScream |
#6 |
When did I get a custom title!?!
you did disable the GUI after setting it up right? 192mb of ram is one fat memory hog. It also adds to unreliability. My server runs:
ut2004game server Nexuiz server Direct connect client Direct connect hub (lan only) Ftp server Samba share Teamspeak server some random web accessible hardware monitoring thingy SSH (with an actual SS not just terminal login) Then when I want to use aplications that are better in linux like the GIMP swiftfox and open office I can fire up gnome and synergy ![]() you may want to put in a warning about using VNC like programs over the internet... namley don't unless you know how to make it secure... belive me I thought I was invulnerable untill somone else suddenly took control :P Also you may want to post some info on getting disk access speeds faster using hdparm as most drives are configured with slow fail safe parameters by default
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#7 |
DUHHHH
really nice ! I thought about making that but didnt have the patience to search for information (I know ! me = lazy)
now if I could just find that 256mb DDR stick that's somewhere around here... i could use that good old K7S5A with a little sempron and finaly have a file server for my LANs ![]() EDIT : Kipman what's the hardware of your machine to host the UT2k4 gameserver ? |
#8 | |
/dev/null
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't |
#9 |
Multimodder
Very good article/guide.
Every now and then I install linux on one of my odl PC's and always end up just abandoning it again because I really dont need it. my email/fileserver/torrentserver and irc is all on my old Dell C610 running vista basic. It works fine so I am happy with it. But if I do install linux again on that old machine I have in my bedroom, which I am sure I will do soon, I will defo follow this guide. |
#10 |
Spoon? What spoon?
very useful, now have torrentflux running on the media server.
a freind of mine was wondering how to make a server for files when he's away from home, and I can just point him here rather than trying to explain it. hopefully Glider will continue to write more articles for bit, as his guides on linux here so far are definitely in the top ten of the ones I've read. |
| Bluephoenix |
| Find More Posts by Bluephoenix |
#11 |
Hypermodder
Thanks for that Glider, it was a really well written, descriptive and easy to follow guide, brilliant
As someone that has messed around with linux in the past, but always got frustrated or just downright confused, this was brilliant! I managed to get a server setup no problem, and am now working my way through other things on the machine.
#12 |
Weekend Junkie
Very nice guide Glider, but a few lines explaining what chmod, chown and the few scripts do would help immensely for those who have never touched a linux box. Granted, "man chmod" and man chown? does that trick but not everyone knows. Else it's perfect.
Now i'm eagerly awaiting the swamp of questions flooding the linux sub-forum the next few days. That will keep you busy Ken.
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard. |
| Spaceraver |
| Find More Posts by Spaceraver |
#13 |
I pickle they
nice article.. i'm curious though, has anyone used/setup FreeNX or NoMachine's NXSever ? I hear it's faster than VNC.. but I've been having a bear of a time trying to set the darn thing up
#14 | |
1Gb DDR 333mhz 100Mb/s lan it's in my sig most players I have had on was 22 over lan while the hard disk was getting hammered for files at the same time with no detectable lag... network interface was at 99% - 97% utilisation at all times though. I think UT had some kind of priority over SMB though as latancys were still low. I think it would stop running so well at about 60 players if ut supports that much mainly from cpu load. *the game server that eats hardware is the CSS.. found it very hard to get that non laggy and when I did the next steam update broke it! gave up... rubbish game anyway. **if anyone gets AVP2 game server to work please tell me! as the only way I could see of getting it to work was going back to the 2.4 kernal due to the libary required only been compatible with pre 2.6 kernals
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit Last edited by Kipman725; 5th Jun 2007 at 18:16. |
#15 |
Minimodder
Great guide! I was just wondering something, when you set up FTP, don't you need some sort of service provider that you pay for?
thanks |
#16 |
Powered by the PG Monkey...
Thinking I'll turn one of the old rigs into it, just not sure which one. Either way i'm downloading Xubuntu as we speak
![]() Excellent article, more to come please . Maybe a comparison of all the different interfaces you can use, for us GNOME noobs...
__________________
Scorpion - Opteron 146 - 1GB RAM - 120GB Maxtor ATA133 HDD - 8x DVD-RW - 16x DVDROM - nVidia 7800 GTX Graphics - Gigabyte GA-K8N51GMF-9 Mobo - Undergoing Case Mod Phoenix - Toshiba A120 - 1.73 Celeron (Dothan) - 1GB RAM - 60GB HDD - ATi 200m Graphics Salamander - Intel Pentium III @ 733MHz - 256Mb RAM - Total HDD @ 80Gb
#17 |
Multimodder
Super guide
__________________
Radical Fusion update [9th June 07] If you're putting more blood into you're project than sweat, double check that you're holding the tool correctly. |
| Bas van der Werff |
| Find More Posts by Bas van der Werff |
#18 | |
DUHHHH
oh sorry i didnt see ![]() very interesting ! I had no idea a regular PC could handle so many players, that's enough fopr a good onslaught server ![]() I think the fact that it's a shuttle makes it 10 times cooler
#19 |
Modder
Good read, I'm running my server on win2k (hey, it's lightweight and it works) but I may switch to linux in the future. For now, win2k and tightvnc work for me!
#20 | |||
/dev/null
Chown changes the ownership of a file/directory. This is important, certainly when files are 'read only by owner'. Quote:
It's getting too quiet over there
__________________
| Thread Tools | |
