RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 7th Jun 2007, 01:53   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Tubes are back & custom XPCs crop up
http://www.bit-tech.net/news/2007/06...xpcs_crop_up/1
COMPUTEX 2007: Vacuum tubes are back, as Shuttle pairs up with ESTI to make a HTPC that'll beat those drums right out your ears.
Tim S is offline   Reply With Quote
Old 7th Jun 2007, 02:41   #2
wafflesomd
Hypermodder
wafflesomd's Avatar
wafflesomd is on a distinguished road
What a waste of a good amp.
wafflesomd is offline   Reply With Quote
Old 7th Jun 2007, 03:11   #3
nakchak
Minimodder
nakchak is on a distinguished road
gonna run stupidly hot
will look sweet with the tubes glowing, but the psu for the amp alone will have to be a monster.
the heater coils require multiple amps >6 at relativly weird (for transitor based electronics) voltages.
if its a class A amp then it will be relativly low wattage as well (probably arround 30W), but will radiate roughly a degree c per watt
and any audiophile worth there salt wouldnt even consider running audio lines that close to large amounts of RF noise generated by a pc
i also doubt the speaker hookups and interconnects would be of sufficient quality to produce a noticeable difference from a bog standard n.1 setup
it also doesnt look like it would offer anything more than stereo output, typically a valve or 2 per channel
still will look nice on display, but money would probably be better spent on a pro quality sound card and high quality inter connects to existing gear if audio quality is your priority....
nakchak is offline   Reply With Quote
Old 7th Jun 2007, 07:06   #4
JaredC01
Hardware Nut
JaredC01's Avatar
JaredC01 has a spectacular aura aboutJaredC01 has a spectacular aura about
If you look closely at the power tubes, you'll notice they're EL34's. They put out roughly 25 to 30 watts a piece, so you're looking at a ~100 watt tube amp. Assuming it's a stereo output, that's ~50 watts per channel. Also, it looks like it might be a class A/B.
Most studio environments are run using computers these days, so audio lines are constantly run close to a PC of one sort or another. It doesn't seem to adversly affect recordings.
I agree with you on it being no more than a stereo setup, though tube setups are better for music listening than for surround sound, and most music you'll hear is only stereo (with some exceptions of course). I see no problem with it only being stereo.
__________________
|i7 920||EVGA Classified E760||6GB Ballistix Tracer 1600||3x XFX 4890CF||X-Fi Fatality||4x WD Black 1TB RAID 10||Revolution 1050w||Corsair Obsidian 800D|
|E8400 @ 4.00 w/ NH-U12P||GA-EP45-UD3P||8GB G.Skill @ 445MHz 5-4-4-12||4870 512MB||X-Fi XM||WD Green 1TB||Tagan BZ 700w||Antec P182 Gunmetal|
In Progress||Current Rig -- If I helped you, please give me rep!
JaredC01 is offline   Reply With Quote
Old 7th Jun 2007, 08:34   #5
Wolfe
Hypermodder
Wolfe is on a distinguished road
Uh... If you look at high end recording setups, pretty much every one available puts the analog and A\D converters in an external box, connected either through firewire/USB, or a proprietary cable and a PCI card.
As for tubes, well, Meh.
They're a lot of really bad tube amp designs out there, and considering how different using tubes is compared to transistors (current vs. voltage amplification), I'm a little dubious about the Quality.
__________________
User subject to random acts of normality.
Wolfe is offline   Reply With Quote
Old 7th Jun 2007, 14:52   #6
./^\.Ace./^\.
Multimodder
./^\.Ace./^\.'s Avatar
./^\.Ace./^\. is on a distinguished road
At my house I have over 5000 tubes, no lie I guess i could mod a PC to use a few of them Hey if they worked for guitar amps then why not a PC
__________________
CPU: Intel i7 920 | RAM: 6GB OCZ Reaper DDR3 1866MHz | Mother Board: Asus P6T | Graphics: Dual BFG GeForce GTX295 rev.B Quad SLI | PSU: Antec TPQ-1000 | CPU Cooler: Cooler Master V8 | Hard Drives: 500GB Seagate Barracuda, 500GB WD Caviar Black, 1TB WD Carviar Green | Optical Drive: Pioneer DVR-216D | Case: Cooler Master HAF 932 | Monitor: LG W2343T 23" | OS: Windows 7 Pro 64bit |
./^\.Ace./^\. is offline   Reply With Quote
Old 8th Jun 2007, 00:47   #7
JaredC01
Hardware Nut
JaredC01's Avatar
There are thousdans upon thousands of home studios and semi-pro studios that don't isolate their computers or audio equipment. In fact, I'll go as far as to say that MANY of them have their interfaces and audio equipment in the same rack as their rackmount PC.
__________________
Old 8th Jun 2007, 20:32   #8
Wolfe
Hypermodder
FYI - Metal Box = Isolation.
ADC & DAC on a PCI card inside the computer - Not Isolated.
ADC & DAC in a different metal box than the computer - Isolated.
__________________
Old 8th Jun 2007, 21:13   #9
./^\.Ace./^\.
Multimodder
Honestly it would only take like 15min of reserch to fine with transistors I could replace with a tubes just so my PC looks cooler and the tubes are actually being used
__________________
Old 8th Jun 2007, 21:55   #10
GoodBytes
mother into a board?!
GoodBytes's Avatar
GoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of light
It would be AWESOME if we have computer sound cards with vacuum tubes. Of course they must allow the user to change them, as they have a life span.
But then some sort of cooling would be required for the sound card, as I'm sure these tubes produce heat. Now sure it will take some room in the computer, even disable 2 or 3 PCI or PCIe sockets. Even better is if they create smaller versions of it.
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro!
GoodBytes is offline   Reply With Quote
Old 9th Jun 2007, 07:38   #11
Neogumbercules
Ultramodder
Neogumbercules's Avatar
Neogumbercules is on a distinguished road
ITS A SERIES OF TUBES!
__________________
Abit AB9 Pro, Intel Core 2 Duo E6400 CPU, 2GB Corsair DDR2 6400, nVidia 8800GT, Seagate 160 GB HDD.
Neogumbercules is offline   Reply With Quote
Old 9th Jun 2007, 23:16   #12
./^\.Ace./^\.
Multimodder
Well Tubes already go in sockets, so replacing them is no issue. As for the cooling just make sure the tubes are ether outside the case or get a 120mm fan in front and one in back. Also they did come up with smaller versions of tubes they're called transistors and that is what you want to replace with the bigger and hotter tubes. Tubes only add a bit of wormth to the base anyways, there are easyer ways to do that with software or better hardware but it doesn't come out as good as tubes. So yes you could mod a sound card but is it really worth it for a little bit of base sound
__________________
Old 10th Jun 2007, 08:35   #13
GoodBytes
GoodBytes's Avatar
It was just a small suggestion for music enthusiast. By smaller Tubes I didn't mean THAT small.
__________________
Old 10th Jun 2007, 09:46   #14
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
Why can't they already ditch the damn tubes and concentrate in sound quality Seriously... Only some twister perverts buy tube-amps because they "sound smoother" AKA. the frequency response isn't flat and there's all sorts of distortions in the sound. Frankly these are the exact FEATURES that modern solid-state amp-designs try to get rid of. I don't see the point TBH. Also tubes can break down for no apparent reason, and it's considered rather normal...
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 10th Jun 2007, 10:53   #15
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
God dammit, I knew this'd turn into an argument of digital vs. analogue, again.
FYI "Ace", all you'd have to do with an internal sound card to eliminate all of the noise from inside the PC (at least the stuff you can get rid of), would be to build a faraday cage around it. Problem solved.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is offline   Reply With Quote
Old 10th Jun 2007, 11:03   #16
Glider
/dev/null
Glider's Avatar
Glider has a spectacular aura aboutGlider has a spectacular aura about
Will Jipa, as a Bass player, I must say that modern amps produce nice quality sound, but the human hearing isn't perfect and it certainly doesn't like perfect tunes (certainly not when going into high or low frequencies).
Just to say, music is more then playing the perfect sound. Sometimes it's required, but sometimes the 'warmer' effect of tube amps add nicely to the tunes.
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't
Glider is offline   Reply With Quote
Old 11th Jun 2007, 02:18   #17
./^\.Ace./^\.
Multimodder
I found the tubes I was looking for. If you look in the pic on the thread, the little ones in front, I have original ones made by GE before wwII and they work better then any of the ones made today but that are rare so I don't want to use them. They also cast a lot.
__________________
Old 11th Jun 2007, 06:20   #18
Jipa
Licenced idiot.
Jipa's Avatar
I guess there's the difference between Hifist and a.. well.. soundist. Searching for the neutral equipments compared to searching for the good "sound".
__________________
Old 11th Jun 2007, 07:34   #19
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
It's called "Personal Opinion"
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
