Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
New Scythe and Thermaltake coolers
http://www.bit-tech.net/news/2007/06...take_coolers/1
COMPUTEX 2007: Scythe and Thermaltake have a few more, even larger coolers to make even the hottest silicon reach for a jumper.
__________________
#2 |
Lethargic
If that copper Ninja wasn't so damned heavy, I might be interested. As it is, I'm happy with my aluminium one.
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA |
#3 |
Madeira's banana is the best!!!
to heavy for my taste and my mobo.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#4 |
Space Monkey
This is getting ridiculous, to be honest. What we need are cooler-running components and more efficient cooling solutions. What we don't need is a contest for who can produce the biggest pen- err, I mean the biggest heatsink.
I think these are totally unecessary, and are marketed as widgets to give you bragging rights. So there. -monkey
__________________
But of bliss and of glad life there is little to be said, before it ends; as works fair and wonderful, while still they endure for eyes to see, are their own record, and only when they are in peril or broken for ever do they pass into song. -J.R.R. Tolkien, The Silmarillion |
| supermonkey |
| View Public Profile |
| Find More Posts by supermonkey |
#5 |
Multimodder
If you need a heatsink that big then just spend the money on a liquid cooling unit, Duh
There is no need for that much air flow for CPU cooling especially if you can't even see what else is in your PC
__________________
CPU: Intel i7 920 | RAM: 6GB OCZ Reaper DDR3 1866MHz | Mother Board: Asus P6T | Graphics: Dual BFG GeForce GTX295 rev.B Quad SLI | PSU: Antec TPQ-1000 | CPU Cooler: Cooler Master V8 | Hard Drives: 500GB Seagate Barracuda, 500GB WD Caviar Black, 1TB WD Carviar Green | Optical Drive: Pioneer DVR-216D | Case: Cooler Master HAF 932 | Monitor: LG W2343T 23" | OS: Windows 7 Pro 64bit |
| ./^\.Ace./^\. |
| Find More Posts by ./^\.Ace./^\. |
#6 |
Ultramodder
First there was the casefan mania. Casses stuffed with 120mm or 80mm fans. Nobody complains about the noise these where generating.
Then came the ccfl mania. Cases stuffed with all those kitchy light kits. blinking, rolling or collorchanging. Then came the copper is better cooling mania. Copper heatsinks the size of a car was the bomb. Although not cooling a few degrees more then standard cooling. Then came the Silent mania. With copperfins in all sorts of shapes, from umbrella likes to vortex shaped fins. Then came the Heatpipe mania. Heatpipe was the new kid and everything went over the top from there. Heatsinks with one, two, six, and even 10 pipes on the cpu heatsink. But that did not stop there. All of a sudden copper heatpipes where on every motherboard. And even those gets extremer to rollercoaster like shapes and bends. But hold on! We got something new here!. Now we combine heatpipes with giant radiator like fins. And then we ad some more and bigger fans to it! I wonder why the copperprices wend skyhigh the last couple of years. Over here even the thiefes are seeing $$$ in copper. They even starting to steal whole copper lighting railes and steal even the copper lines that power the trains! And pulling kilometers of copper wire out of the ground. Also it is a waste of resources. Anybodie 'knows' that this is not the right way to go. We have to fight the source of the problem. The devices that generated the heat. There comes a time that the biggest heatsink in the world can not cool a processor anymore with the wattage increase this going. Not to mention the ridiculus psu wattages. I can not imagine that in 2 years every houshold computer is running a 2000watt 24/7. Dont they know what this is going to do to the powergrid and enviroment. Its totaly insane!
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#7 |
glourious bacon?
You bunch of moaning minnies
![]() Any heatsink and fan that could possibly cool a cpu near-silently without the risk of splashing liquid anywhere but getting near to the cooling properties of water is a good idea in my book.
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#8 |
Space Monkey
The stock heatsink that came with my processor runs almost completely silent. It's a pretty small heatsink, and keeps my CPU at about 30C idle. Oh, and it has a 60mm fan on it, as well.
During a heavy load, such as rendering video, the CPU gets up to about 50C. Again, this is with the stock heatsink and 60mm fan. Is it really necessary to have a heatsink that big? Do we really need huge fans? With proper implementation, you can use an older Scythe Ninja with a single 120mm fan to keep things pretty darn cool. I thought about investing in a watercooling setup, but after my research I'm left to believe that air cooling already has reached the point where it's pretty effective. Sure, it might not cool as well as water; however, as long as my components don't overheat, and as long as I can keep things running at near silence, then watercooling remains a geek-factor thing. -monkey
__________________
| supermonkey |
#9 | |
6 screens / 1 card
__________________
It's not about how life treats you, it's about how you treat life. |
#10 |
mother into a board?!
@./^\.Ace./^\.
For water colling you have the problem of refilling your expensive (on my tastes) liquid, chances of leakage, and water cooling pump motor noise, and fan noise for some water colling setup. Also, for people that never installed a water cooling system in there life, and know nobody else that has a water cooling system, it can get very complicated to setup. (eg: what to wire what first)
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro! |
#11 |
Multimodder
Oh, you're right
I would still suggest that they look into water cooling if they are in a toss between water cooled or that gigantic fan thing. the noise from a water pump must be quieter then that fan, and think of the dust
__________________
| ./^\.Ace./^\. |
| Thread Tools | |
