Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Cooler Master's Cosmos is nearly ready
http://www.bit-tech.net/news/2007/06...nearly_ready/1
COMPUTEX 2007: Cooler Master's Cosmos chassis is almost ready to ship to customers.
__________________
#2 |
The Real Pacman
bit-tech Staff
Wow, that's fudgy. For £120 there way nicer looking cases about.
__________________
XBL : Shogun Hiren Homepage | HD Tach | Last.fm | DeviantArt bit-tech newsletter | bit-tech Blog |
#3 |
Spoon? What spoon?
I'll await the bit review before thinking about buying.
good to see they kept the HDD enclosure concept |
| Bluephoenix |
| View Public Profile |
| Find More Posts by Bluephoenix |
#4 |
what is the cheesecake?
looks hideous tbh
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D." I'm a pretentious git with a camera. ISPs want to spy on you. Join the fight against phorm XBL/PSN/Steam ID: FodT |
#5 |
Don't panic!
First thoughts: hideous.
Second thoughts: better. It's starting to grow on me tbh, alright it's not really plain, but it's enough imho, and the cooling looks awesome. I'll wait for the BiT review, then make a final judgement.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains... |
#6 |
What's a Dremel?
Looking quite good imho.
![]() But for 177€ I can probably buy a better looking aluminum case. What I don't get is why Cooler Master wasn't able to build a proper rig. It looks really messy inside. |
#7 |
Banned
Deleted
#8 |
K.
Discusting.
//Wishes ATCS would come back to them.... ...
__________________
Cheers, Cool_Dude. ![]() ...Talk is cheap. |
#9 |
Multimodder
It needs some work. Maybe a hamer could fix it
__________________
CPU: Intel i7 920 (Stock) |RAM: 6GB OCZ Reaper HPC DDR3 1866MHz | Mother Board: Asus P6T |Graphics: Dual BFG GeForce GTX295 rev.B(Quad SLI) | PSU Antec TPQ-1000 | CPU Cooler: Cooler Master V8 | Hard Drives: 500GB Seagate Barracuda, 500GB WD Caviar Black, 1TB WD Carviar Green | Optical Drive: Pioneer DVR-216D |Case: Cooler Master HAF 932 | Monitor: LG W2343T 23" |OS: Windows 7 Pro 64bit |
| ./^\.Ace./^\. |
| Find More Posts by ./^\.Ace./^\. |
#10 | |
Modder
I know what bar(duct) you are speaking of Antec had them in the older P180s horrible solution made way too much noise. |
#11 |
Madeira's banana is the best!!!
put the fans closer and make it a little cheaper and you have a deal.... after i read the review.....
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key! |
#12 | |
Pewlius Caesar
bit-tech Staff
![]() Check here: http://www.bit-tech.net/news/2007/03..._case_design/1 I'm referring to the bar that runs across from the rear I/O to the drive cage. I know a lot of manufacturers have used similar "bars" for "extra support" but this isn't about that load of rubbish, it's more of an air duct than a bar, I guess - I'm in bad habits from times of old
__________________
#13 |
I'm not a modder.
Are the things that look like handles actually handles, or will they fall off if you try and lift the system with them?
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#14 | |
Pewlius Caesar
bit-tech Staff
__________________
#15 |
Sierra my delta, bravo!
Are those bars on the top and bottom fully functional handles, or are they just there for show?
#16 |
-Xbox Pwner-
Read about... one post up...
-CollinstheClown |
| CollinstheClown |
| Find More Posts by CollinstheClown |
#17 |
Whooolapoook
Now that's just hiddeous.
I like that they have moved the PSU to the bottom though, is there a vent under there so that there is cooler air for the PSU? All cases should place the PSU at the rear base of the case. It looks like cable routing will be the toughest part of making that case look good. I cant believe they chose to showcase that with such terrible cable management, if they had spent 3 minutes more on that, added watercooling it would really help make the rig look better. Shame that the plastic they have used makes it look so cheap. I know it's £120 but they could have pulled of something a little mory classy...it looks like something from the set of a very bad F Class Sci-Fi movie.
__________________
0ptimizm :PC under review
#18 |
Hypermodder
Ach Coolermaster went wrong when the guys that now form Silverstone left. ATCS cases were great with the understated design and all brushed ali. It just seems to me that now they use their good name to put high prices on lower quality steel/plastic cases.
Silverstone or Lian-Li is the only way forward at the moment.
__________________
Jimmy Carr - "It's easier to get forgiveness than permission" |
#19 |
You there computer man fix my pants
The hard drives looks like there stack sideways at the bottom, which concerns me with regards to keeping them cool due to restricted air flow across them
__________________
| Asus P5N32-E SLI | Q6600 G0 @3.0ghz Watercooled | 8GB Corsair Dominator PC8500 @1066mhz 5-5-5-15 2T | XFX GTX285 | BFG 8800GTS | XFX 9600GT | 1x 128GB Crucial M225 SSD | 5x 500GB Seagate SATA-II | BFG 800W SLI PSU | Logitech Z-5500 5.1ch speakers | 3x Dell S2209W 22"wide TFT's (5760x1080res) | 1x Panasonic 42"Plasma | All working on Win7 Ultimate x64 | |
#20 | |
Gerwaff
| Thread Tools | |
