Thread Tools | View Mode |
#1 |
Minimodder
Project: Tube Radio PC -- 20 October -- Back From The Dead
Sooooo. I have been planning on doing this for a while, I just finally got it in gear and started ordering all of the pieces to get it started. The first part to arrive, is the wooden cabinet from an old RCA tube radio. Here is what it looked like when it arrived. (The picture is actually the pic from the Ebay auction, I forgot to take any before pics of my own.)
![]() The finish was ok on most of it, but on the front left in the picture you can see how trashed the finish is there, so I knew I would have to refinish it. I pulled off the brass trim off of the opening on the right, and popped off the wooden grille on the left to more easily work on it. A couple hours of mixed hand sanding and orbital sanding later, I have this: ![]() ![]() I think it looks waaaaaaay better, but thats just me. I had to be carefull, because the case is made out of solid wood, but the skin is just a thin laminate of good looking wood on top of generic wood that keeps it together. I wanted to get it sanded down first thing, to see if the finish could be salvaged, rather than dong all of the other modifications that are going to be required to make it a functional computer only to find out the finish couldnt be salvaged, and it would look like crap. Here is a test fit of an older micro-atx motherboard I have just to make sure it is going to fit properly: ![]() The motherboard will go there, with a 120mm fan in the hole behind the wooden grille right over the motherboard, with the hard drives suspended behind the fan over the motherboard. On the other side there is going to be the power supply with the DVD drive in the hole with the brass edging, plus something else i havent come up with =) The thing that pushed me into gear to get this going are the amazing steam punk mods that are showing up on the net. Specifically the amazing steampunk keyboard and the steampunk lcd screen done by the same guy. I am also going to be following his worklogs to recreate a keyboard and monitor of my own to match for this project. I have ordered all of the parts I should need for those too, so in the next couple of weeks this worklog will have the progress of those side projects too. I think it should be a lot of fun, and I am hoping it looks pretty sweet when everything is said and done =) Last edited by s_q_u_e_e; 21st Oct 2008 at 04:10. Reason: Update Title |
#2 |
got some potential here! good luck with this!
__________________
cheapskate is (not) a noob |
#3 |
Supermodder
Hey another wood project. LOL I love wood. Go for it! looking good so far.
| Tale Gunner |
| View Public Profile |
| Find More Posts by Tale Gunner |
#4 |
I *am* a Dremel
Must gett a tube amp inthere for realism.
__________________
4 Men went to mow, Went to mow a meadow, 4 Men went to mow, Went to mow a meadow, ![]() ![]()
#5 |
Multimodder
Wow this is really an old radio dude
__________________
#6 |
Modder
Good luck with this. I think it can be really great with this old radio!
__________________
If the facts don't fit the theory, change the facts. Albert Einstein |
#7 |
da ginger monkey!!!!
looking good keep it up
#8 |
Don't mind me.
nice start,nice work on cleaning up the finish..
__________________
Of all the things I have lost, I miss my mind the most.
#9 |
Multimodder
Nice job on cleaning up the case. I'm interested in seeing where this goes.
What are you planning for the front and lighting?
__________________
Pfaffen Wood Case Mods: Completed: World Map, Fibonacci, Canary Mesa, Molesworth Wood Case Mods: Under Construction: Vogel Haus, Four Hokusai Cases |
#10 |
Multimodder
Nice touch may be an old vacuum tube.
__________________
#11 | |
Supermodder
| Tale Gunner |
#12 | |
Multimodder
__________________
#13 |
Got Wood?
I've always wanted to do this so i will be watching intently. You picked a great looking radio to start with too.
__________________
Completed:Sangaku http://forums.bit-tech.net/showthread.php?t=89638 Completed:Yuugou http://forums.bit-tech.net/showthread.php?t=109996 My case mod website www.nickfalzonedesign.com |
#14 |
Minimodder
Part 2
Okee, today I worked on the internals of the case. First off I measured out the space i have on the inside of the case, and cut a motherboard tray out of 1/4" MDF to fit. I then cut notches around the internal bracing of the case so it would all slide in smoothly.
![]() I then measured the holds for the motherboard standoffs, drilled them and test fitted the motherboard to see if they were correct. they werent all perfectly on center, but they were close enough that I got the motherboard completely screwed down I then slid it into the case to make sure everything still fit.. Happiness =) ![]() ![]() Next I flipped the power supply around a few times to figure out how to place it. I settled with the powersupply on its side, and I will put the hard drive on its side between the motherboard and power supply. That power supply wont be the final one in the case, I pulled it out of my gaming rig just so I could get the spacing correct. A 620 would be a bit of overkill for this box =) ![]() ![]() Time to start boxing in the internals. The only part of this build that will not be attached to the motherboard tray is the slot load dvd player. A little while later, and like magic it is fully assembled with the motherboard installed again to make sure it fit. ![]() ![]() ![]() On to the back plate that will hold the power supply. Everything measured and cut, and again like magic poof its assembled. I did have to drill the mounting holes out a little bit after assembly, things never fit like they are supposed to when you cut and measure everything by hand and then assemble them. Installed the motherboard again and the powersupply, and I am thoroughly happy with how this is coming out. ![]() ![]() ![]() That is all the construction work I got done today. I am feeling pretty good about how the mod is coming along so far. I havent hit any major snags yet, and I cant see where any are going to rear up and bite me on the ass =) Here is a final shot of the front. I have decided that I will not be placing the dvd drive in the brass ringed area. I want this to look completely like a 1950's tube radio, and as I discovered a cd will fit PERFECTLY between the slots on the front. Soooo, instead of putting a 120mm fan there like I was planning, I will instead be putting a slotload slimline dvd player on top, and a 92mm fan below that. ![]() That is where the mod sits at the moment. In the front holes, I want to put a dial in the middle to control the fan speed, with the power and reset buttons on either side. The problem I am running into at the moment is I cant find any that will fit into the theme of the case. A vandal resistant switch would be nice, but the chrome would look out of place. I need something in copper or brass, anyone have any ideas? Another thing that would work is some kind of momentary dial, so i could just twist it to the left or right and that would be the power switch. @Tale Gunner Wood cases do seem to be all the rage these days, I think its just cause wod is so great to work with and mold to what you want done to it. I am liking how your Cherry Wood case is shaping up! @Pfaffen First I am really enjoying what you are doing with your Fibonacci Sequence Project, it looks great so far. For the front I am going to put in the dials I mentioned, and then in the brass ringed area I am thinking about putting an old volt gauge in there, wired up to the fan and fan controller to show how much voltage is going to the fan, and still look something like the radio dial it would be replacing. That in the middle, and then maybe an old vaccum tube on each side, lit from below with an orange LED connected to hard drive activity. @Greensabbath I think the radio looks pretty good too, thanks for looking =) Your amazing case mods are one of the things that has me excited about doing a case mod again, I havent done anything major like this in four or five years. @Everyone Thanks for all of your comments, and as always suggestions are always welcome =) |
#15 |
I *am* a Dremel
Nice job so far! Ive always wanted to do this kind of mod but I can never find the right radio shell. As for switches, take a look at the ones mashie used in his radio project http://www.mashie.org/casemods/anemone1.html . They fit that case really well and they would suit yours too. Keep it up!
#16 |
Mod Master
ooo I definitely like how its going, but I would ahve to say, make a tube headphone amp and have that actually working and up in the front
__________________
I'm the Redneck Kbot, I leave my christmas lights up all year long. |
| ConKbot of Doom |
| Find More Posts by ConKbot of Doom |
#17 |
Dead account.
I like where this is going man. Looking SWEET.
Off-topic: Anyone else notice us woodworking bit-techians gather together? I recognize a couple faces here.
__________________
Not posting on this forum anymore... |
| Morphine-Kitty |
| Find More Posts by Morphine-Kitty |
#18 |
Multimodder
That is awesome!!! Well done for the support brackets inside.
I especially like the DVD/CD slot. It is a great touch. Keep up the great work.
__________________
#19 |
Multimodder
Love it. Ya'll's (tale gunner, greensabbath, and a couple other guys) wood projects have really got me excited, and especially these conversion mods have helped me to think about my planning/layout a lot. Thanks a ton for the entertainment, and information. You've helped in more ways than you. Thanks again!
| davidbacsik |
| Find More Posts by davidbacsik |
#20 |
Multimodder
I did a quick and dirty search on ebay for radio knobs and found these. http://search.ebay.com/search/search...e=search&fgtp=
It would be easy to use a modern cherry switch or something simmilar and attach these knobs as buttons or dials etc.
__________________
Project: The Answer (Full 4 player MAME cabinet) |
| Tags |
scratch build ![]() |
| Thread Tools | |
| View Mode | |
