Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
EVGA nForce 650i Ultra
http://www.bit-tech.net/hardware/200...e_650i_ultra/1
Gaming on a budget? Cheap motherboards worth the bother? Well the new nForce 650i Ultra chipset seems to fit the inexpensive bill quite nicely, and not everyone needs SLI! We test EVGA's board to see if it's really worth spending a few monies instead of a lot.
__________________
#2 |
Madeira's banana is the best!!!
cheap and weak.... remembers me my evil asrock board, how i hate it for being weak, at least it had lots of features. that back side looks very barren and it is greeeeen, my old asrock was dark blue and was cheaper.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#3 |
I pwn all your storage
Cheap board should have parrallel and serial on the I/O at least, it'd save money from running extra cables and making extra PCI-blanking plates
#4 |
CAMRA ***.
Not a bad review, but I found the gaming section a bit weak. I understand why it was coupled up with a budget card and so on, but given that not a single other board it was compared with shared the same card, it failed to give a proper indiction of its relative performance. It seemed almost pointless including the results from other motherboard/card combos as they added nothing IMO.
If you're comparing gfx cards against each other then it makes sense to test a variety of cards. When comparing motherboards surely it makes sense to keep as much as you can the same, including the gfx card - especially when looking at game performance? The fact that it got beaten by every other board was not surprising given they housed a 7900GTX. |
#5 |
I feel your presents.
Aye, that does seem a bit of a strange decision.. why not do another run of gaming benchmarks with the 7900 card plugged in?
A budget setup doesn't necessarily mean *everything* has to be a few notches behind technologically.
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#6 |
Richard Swinburne
bit-tech Staff
I see your point, I just don't have anything in the lab to compare it to. The Gigabyte and board has gone back already and I only just found the MSI P6N Platinum again.
The 650i Ultra is specifically designed for the 7600GS. In hindsight I should have tested with an E6300 and 7900 GTX, perhaps, or given I found the MSI far sooner I might have had time to put that together with a 7600GS and E6300. The gaming performance in high res is GPU limited anyway, if anything the 7600GS is a representation in there. It's a point noted, but I find it hard to review mainstream boards since companies tend to want to keep the hardware. If you really want, I can throw the board back on when I have time and do a 7900 GTX and E6300 with the 650i but the MSI will take far longer since I've got to start from a scratch installation. |
#7 |
Supermodder
I like the position of the Pci slots on this here board. Moast of Nforce 500-600 series boards the pci's slots are smushed together, near a potential dual slot GPU, or in the middle of two pci express lanes. This one is breazy-Mc-easy. Plenty ov room for tv tuners, sound cards, and what have you.
I don't consider this board a bargain for US pricing... Considering a 680 ultra from EvGA is 25 bones more... 25 dollars is not a lot when you weigh in what Joe consumer gets on a 680 ultra. Flawless review, and the new color-coated graphs have grown on me. I'd really like to see a nice laptop review from you guys soon, the last one was from rock and had a whole lotta creepy skulls on it... note: for those of you using a mac, you can make that badgi's avatar go in slow motion if you click on the scroll bar really fast like...
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs |
#8 |
Multimodder
I just looks like it is missing a lot of stuff. It looks like a low end Intel mother board
__________________
CPU: Intel i7 920 | RAM: 6GB OCZ Reaper DDR3 1866MHz | Mother Board: Asus P6T | Graphics: Dual BFG GeForce GTX295 rev.B Quad SLI | PSU: Antec TPQ-1000 | CPU Cooler: Cooler Master V8 | Hard Drives: 500GB Seagate Barracuda, 500GB WD Caviar Black, 1TB WD Carviar Green | Optical Drive: Pioneer DVR-216D | Case: Cooler Master HAF 932 | Monitor: LG W2343T 23" | OS: Windows 7 Pro 64bit |
| ./^\.Ace./^\. |
| View Public Profile |
| Find More Posts by ./^\.Ace./^\. |
#9 | |
sweet sweet hangin joben
__________________
I love me some me e8400 @ 4.45 ghz..ac freezer 7..2 gigs patriot extreme 1150 mhz..abit ip35-pro..xfx 4770 with asus top bios @ 926 core/1077 memory..antec p182b..corsair hx620..seagate 500 gb 32mb cache THE best site ever...1600 signatures under the same avatar...time for a new one
#10 |
Multimodder
Maybe for a sec...i thought rich will use 8600 GT or GTS.I mean that will give the better idea for the latest things.
__________________
AMD Athlon 3200+(2000 MHz) Winchester (Cooler Master Hyper 48),MSI RS482M4-ILD,Kingston KVR 512x2(1024MB)400MHZ,Gainward 6800 GS 256MB GDDR3 @ 425/1000,250GB WD Caviar 2500JS,80GB Seagate Barracuda,Lite-on DVD/RW,Cooler Master 430Watts PSU. www.sunehrepal.com http://www.technewstime.com |
| keith_j_snyder2 |
| Find More Posts by keith_j_snyder2 |
#11 |
Weekend Junkie
hmm.. i like.. I still run an EVGA 7800GS AGP on a p4p800s-e mobo. might be time to upgrade to this board and a 8something series card. Couple that with a Samsung or LG 22" inch tft and that should keep me happy for a few years. just dont know which gfx card. 88 or 86.
And i like it oldskool (yes skool ) watercooled ofc.
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard. |
| Spaceraver |
| Find More Posts by Spaceraver |
#12 | |
here... take a slice of my pie
strange way of testing gaming performance, almost pointless imo
__________________
Im a MAC |
#13 | |
Minimodder
The parallel port on the other hand? Good riddance I say. |
#14 |
Richard Swinburne
bit-tech Staff
E6300, 7900 GTX scores added for comparison
#15 |
So Say We All
i sure as hell hope theres a labelling mistake on the photoshop graph
__________________
Hell hath no fury like a hippo with a machine gun.
#16 | |
Pewlius Caesar
bit-tech Staff
__________________
#17 | |
__________________
#18 |
What's a Dremel?
I can't find anything in documentation about a connector on this mobo for the PC case speaker but I see a 4-pin connector near the audio connectors in the corner of the board that fit the connector that my case has for the speaker. Any ideas?
Also, if I want to connect my CD/DVD player to the mobo to get audio (with either a 2 or 4-pin connector) can I do that? Again, nothing in documentation. In my other systems without integrated audio, the sound card typically has a place to plug this connector in. |
#19 |
Richard Swinburne
bit-tech Staff
PC Speaker? Why do you need it? Boot problems? It'll likely be on the front panel pin out. I've not seen anyone use an old 4-pin connector for the DVD/CD player in YEARS, now it's all done over the normal IDE/SATA digital connection in all OS' and software I can think of. Or do you mean a separate external devise, like a stand alone?
| Thread Tools | |
