RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Jun 2007, 09:24   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
AMD 45nm CPUs expected 2H08
http://www.bit-tech.net/news/2007/06...nm_cpus_2h08/1
AMD CPUs on a 45nm process are set to arrive as soon as 12 months away, but by then will it be too little, too late?
Tim S is offline   Reply With Quote
Old 25th Jun 2007, 09:48   #2
RedDethX
Multimodder
RedDethX is on a distinguished road
It'll be interesting when they finally bring something out that can compete with C2D!
__________________
Intel Core 2 Duo E6550 @ 3GHz || OCZ SLi DDR2 PC6400 @ 856MHz || XFX GeForce 8800GT 512MB @ 715MHz Core/1725MHz Shader/2000MHz Memory || XFX 680i LT SLi || WD Caviar Blue 16MB Cache 250GB HDD SATAII x2
RedDethX is offline   Reply With Quote
Old 25th Jun 2007, 12:03   #3
MR BUNGLE
Shoddymodder
MR BUNGLE's Avatar
MR BUNGLE is on a distinguished road
Very interesting...
That's a helluva leap, process-wise from AMD (and IBM I guess) - they must be looking to tape out 45nm chips pretty soon to hit that timeframe...
Providing this goes according to plan, it should bring AMD back into the running in both price, and performance per Watt.
If AMD's Fusion GPU-CPU initiative also goes to plan, then things should really be looking up for them!
MR BUNGLE is offline   Reply With Quote
Old 25th Jun 2007, 12:55   #4
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Well fusion will be a progression: first of all it'll be two discrete units on the same die, with basic interlinking to reduce latency by a whole load, just like the integrated memory controller. Next they'll use common features and finally they'll become just a single entity: a CPU that does GPU or GPU that does CPU.
Bindibadgi is offline   Reply With Quote
Old 25th Jun 2007, 13:23   #5
MR BUNGLE
Shoddymodder
MR BUNGLE's Avatar
- So probably just HT or on-die PCIe links to start with then...
I thought they were heading more towards having the GPU as a seperate core alongside x86 cores: I didn't think that the requirements of running x86 code and GPU code were similar enough to fully combine them..?
- Otherwise, I would've expected to see something moving in this direction sooner..?
Old 25th Jun 2007, 18:41   #6
2JSC
Multimodder
2JSC's Avatar
2JSC is on a distinguished road
With a CPU/GPU combo chip... does this mean you won't need a seperate GPU card?
I'm really hoping for AMD to pull something sweet out by the end of this year, it half over and nothing spectacular has come out yet.
__________________
He's no different than the rest of you organisms... shooting DNA at eachother to make babies.
2JSC is offline   Reply With Quote
Old 25th Jun 2007, 20:45   #7
Ramble
Ginger Nut
Ramble's Avatar
Ramble will become famous soon enough
Short for AMD. This will be interesting.
Traditionally AMD has always been a process shrink behind and still faster. I don't think gaps like this are anything to worry about.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back.
Ramble is offline   Reply With Quote
Old 25th Jun 2007, 21:01   #8
devdevil85
Hypermodder
devdevil85's Avatar
devdevil85 is on a distinguished road
^^I agree Ramble. AMD has always been right behind Intel and their CPUs have usually out-performed Intel's, so I, too, don't think there's too much to worry about...
devdevil85 is offline   Reply With Quote
Old 26th Jun 2007, 02:13   #9
potoguise2
What's a Dremel?
potoguise2 is on a distinguished road
amd relaxed with the gain they achieve for too long, now intel outpaced them, so they will have to redouble their effort to stay competitive.
i'm awaiting their native quadcore chips so i can upgrade from my present 4400x2 athlon
potoguise2 is offline   Reply With Quote
Old 26th Jun 2007, 02:48   #10
completemadness
Hypermodder
completemadness is on a distinguished road
I expect HT, because PCI-E is handled by the NB and not the processor, the processor only has an HT link
i agree, it seems a bit odd, i mean, with a combined solution the processor is more expensive, and the GFX is not upgradable as easily
so to upgrade 1, your talking about a much larger cost increase, plus often upgrading a proc is made worse due to new socket complications
completemadness is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
