RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Jun 2007, 11:42   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
HDMI converter for non-elite 360s?
http://www.bit-tech.net/news/2007/06...-elite_360s_/1
XCM claims it is developing a HDMI converter for 360 owners, rendering the elite a bit more pointless.
Tim S is offline   Reply With Quote
Old 27th Jun 2007, 12:05   #2
mikeuk2004
What you Looking at Fool!
mikeuk2004's Avatar
mikeuk2004 will become famous soon enough
Is there something I dont know?? as I dont get the fuss about the HDMI port on Xbox 360
I have my 360 conected via vga and does 1080p so what am I missing????? If its digital audio then is there any point as TV speakers are crap and not may have digital Optical or Digital coax outputs to out put it to your Theatre kit.
My TV does have Ditital optical out and is one of the reasons for my TV purchase, but if your TV doesnt have this, then you can use the Optical output on your vga cable to conect to your theatre.
So as I see it, unless you do get one of the Few TV'S with Digital out then I cant see that HDMI is a usefull requirement.
So what is the fuss?
__________________
-|- Xfire - Mikeuk2005 -|- Xbox Live - Mike UK 2006 -|- Playstation Network - Mikeuk2004 -|-
mikeuk2004 is offline   Reply With Quote
Old 27th Jun 2007, 12:13   #3
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
the fuss is this DRM mumbo jumbo.....
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 27th Jun 2007, 12:46   #4
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
It'll be a poor quality VGA -> DVI upscaler with the audio synced it.
The 360 normal does not have the capability to output DVI properly.
Also: The unit says XCM, but you're written XMC everywhere...
And Team Xtender are claiming it's theirs./
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 27th Jun 2007, 14:20   #5
Joeymac
Multimodder
Joeymac is on a distinguished road
The Elite 360 has a new digital scaler inside... in addition to the analogue one in the current 360. So the only way to get a pure digital signal out of the console is to buy the elite.
With this cable thing, unless you don't have a VGA port on your 1080p TV, this won't offer any advantage. It will probably just degrade the VGA signal. In fact there are only two scenarios that this cable would be of any use.
1. 1080p output for HD DVD but don't have a VGA input (component will output 1080p for games but only 1080i for HD DVD and the difference between VGA and component in this use is practically nothing).
2. Upscaling DVD's...
The only reason to even slightly consider worrying about HDMI is for HD DVD's. Even then by the time the Elite comes to Europe HD DVD players will be half the price.
Joeymac is offline   Reply With Quote
Old 27th Jun 2007, 14:24   #6
DougEdey
DougEdey's Avatar
Joeymac: HD-DVD player for the 360 is £99, HD-DVDs are £12.50. Cheap in my view.
__________________
PSN ID: DougEdey
Twitter
Old 27th Jun 2007, 14:57   #7
Joeymac
Multimodder
Yeah I know, I have one. I was saying about the Elite... for the what the price of the Elite+HD DVD addon... you most likely will be able to buy a proper stand-alone HD DVD player and a normal 360 by the time the Elite comes out here. Or the cost will be near enough to be worth going that route. IF (!).... HDMI is something you really need. If HDMI is not important for your setup then the normal 360 and HD DVD addon would be fine.
Old 27th Jun 2007, 15:45   #8
SNIPERMikeUK
Multimodder
SNIPERMikeUK is on a distinguished road
HMMMmmmmm!!!
Not really sure what to make of this, but we can always see independent tests of the final product before we make up our own minds....so no harm done?!?!
__________________
SNIPERMikeUK
SNIPERMikeUK is offline   Reply With Quote
Old 27th Jun 2007, 16:00   #9
sinizterguy
Dark & Sinizter
sinizterguy's Avatar
sinizterguy is an unknown quantity at this point
If it works then great, if it doesnt, then Ill have to change my X360 when I get my home theatre properly set up. Either way ... Not the biggest thing to worry about.
__________________
Nothing here. Go away and dont bother me.
sinizterguy is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
