Thread Tools |
#1 |
Brett Thomas
AMD Quad Core CPUs arrive in August
http://www.bit-tech.net/news/2007/06...re_in_august/1
AMD today announced that its "native" quad core CPU, codenamed Barcelona, will start arriving on shelves in August.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
Disgruntled kumquat
Looking forward to this... I'm planning my next system to be a drop-in upgrade to an AM2+ Barcelona.
__________________
The intellitxt demon fell dead, Sir Tim's lance embedded in its heart. The fair land of Bit-Tech was free from its influence once more. And there was much rejoicing. |
| Techno-Dann |
| View Public Profile |
| Find More Posts by Techno-Dann |
#3 |
Multimodder
Awesome!
__________________
Intel Core 2 Duo E6550 @ 3GHz || OCZ SLi DDR2 PC6400 @ 856MHz || XFX GeForce 8800GT 512MB @ 715MHz Core/1725MHz Shader/2000MHz Memory || XFX 680i LT SLi || WD Caviar Blue 16MB Cache 250GB HDD SATAII x2 |
#4 |
What's a Rotary Power Tool?
I'm really hoping that more games become multi threaded, I know its not straightforward for the programmers - but if processor development keeps on heading in this direction...
I thought AMD was creating a technology where it would figure out a way to let one thread's math be spread accross two cores? Was i loosing it? |
| coniferous |
| Find More Posts by coniferous |
#5 |
I *am* a Dremel
A new AMD chipset motherboard, then 1 of these babys. i can't wate
__________________
Main: AMD X2 3ghz, x1900xt, DFI NF590SLI, 4gb pc2-8500 [Watercooled]
Retro: AMD Barton 2ghz, 9600xt, 512mb pc-2700 Animal Crossing: LGTTC - 2492-7863-6464 Member of CK Appreciation Society Group |
#6 |
Mod Master
surly comparing the opterons to the C2D range is a bit stupid? it should be compared to the clovertown xeons (Xeon 53XX) series, which are already quad core etc etc, as well as the upcomming (when ever it is??) release of the one after clovertown based around the 45nm core and on die memory controller (much like the new Itaniums from intel)
#7 |
inch-perfect
Now I have got to see Barcelona's performance claims substantiated in the enterprise world. AMD's primary market, it appears, is the server market. If the Barcelona is as big of a success as Sledgehammer and Barton (oh, we remember the wildfire popularity they caused in the enterprise world), we could should be in for one hell of a ride come the Agena derivatives!
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
#8 | |
Richard Swinburne
bit-tech Staff
On die memory for Intel isn't expect until Nehalem next summer. |
#9 |
You think you know me.
Cant wait to see these tested and hopefully they will live to the hype. However I'll prob end up getting a Quad core 2 when the price drop happens soon.
#10 | |
Supermodder
__________________
(Phenom II 940)(Foxcon A7DA)(8gb OCZ DDR2 800 )(8800gt aka hair dryer)(Big yellow case, CPU, GPU)(Enermax Liberty 500w)(lite-on DVD-RW w/LightScribe)(Seagate 300gb sata)(Seagate 320gb x2)(WD 200gb)(Dell 3007WFP 30"LCD, 19" Samsung, Acer 1280x720 projector) |
#11 |
Supermodder
I run Premiere and After Effects all the time, both of which are fully multi-threaded.
Mmmmmm. Bacon. Phil |
| Phil Rhodes |
| Find More Posts by Phil Rhodes |
#12 |
Minimodder
what i want to know is... what will these things end up costing on launch?
if i can pick up a Q6600 for ~€266 from the 22nd of july, then what will a 2.0 GHz quad core amd cost me in august? The way i figure there is no way AMD can compete on price/performance with intel, even with barcelona. If 2.0 is the best they can do in august, they would have to sell their top end desktop chips for ~$250 for them to come close to being competetive with intel. Either way, if they do end up launching at low-low prices, and performance doesnt end up sucking, i might not get a Q6600 and switch back to AMD instead, but im not holding my breath |
#13 |
Mod Master
Bindi, dont the current/soon to be done Itaniums have onboard memory controllers? Also, does Nahlem actuall conform to the 45nm shrink / 8 cores etc?
#14 |
The Froggy Poster
I make no speculations for or against it - as the men over at XS says - one thing matters, performance. If it gets asshandled, then it'll be a laughing stock like the HD2900s. If it dominates, than this will be just like when the Core 2's crashed the AMD64 scene.
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
#16 |
Multimodder
you're not losing it...i remember that rumor too. I think, though, soon after the rumor surfaced, AMD made a statement saying that it was false.
#17 |
Don't feed the trolls
I believe you are speaking of reverse hyperthreading where some one claimed AMD was working on a process that would allow a fully working logic unit to dump some of the executions to idle logic units. All most the same thing that Intel was doing with Hyperthreading but Intel added logic units to do so.
What you are describing is fine multithreading where software is written to divide the workload between core equally. fine multithreading such as the Povray test can take advantage of more than one core and the work output scales. Scaling means that instead of doing the work of 100% of the single cores clock cycles dual cores or more can do 200% of the work that a single core can do. |
#18 |
Hypermodder
45nm Phenom sounds like a good jump for me......cause I've got 90nm right now.... man do I love Moore's Law!
| devdevil85 |
| Find More Posts by devdevil85 |
| Thread Tools | |
