Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Nvidia pulls 162.15 driver from nZone
http://www.bit-tech.net/news/2007/07..._beta_driver/1
On Friday, Nvidia pulled the 162.15 driver from its nZone portal after a number of complaints from end users.
__________________
#2 |
Multimodder
There were problems with 32 bit XP as well. After installing the beta driver on my system I started to get BSOD's and experienced slowdowns. My AVG Free software stopped working as well. It did greatly improve playback of HD DVD's on my X2 3800+, 7800 GT system. That is when it worked. Finally I had to reinstall windows as the system just died and refused to boot into windows.
__________________
A8N SLI Prem., X2 3800+, 2GB Corsair PC3200, XFX 7800 GT, Lian Li PCV-2000B Case, Antec True Blue 480watt PSU sleeved, 74 GB WD Raptor HD, 160 GB Maxtor HD, Pioneer A09 DVD Burner, Cendyne 106S Slot Load DVD Drive |
#3 |
You there computer man fix my pants
I have not tryed those drivers, thankfully it would seam, but 3.5SE in future should you experience such issues, i would recomend booting into safe mode and using a tool called driver cleaner pro, to totaly clean the nvidia drivers from your system, so you may freshly install the previous drivers.
This should prevent you from having to reinstall the entire OS at least .
__________________
| Asus P5N32-E SLI | Q6600 G0 @3.0ghz Watercooled | 8GB Corsair Dominator PC8500 @1066mhz 5-5-5-15 2T | XFX GTX285 | BFG 8800GTS | XFX 9600GT | 1x 128GB Crucial M225 SSD | 5x 500GB Seagate SATA-II | BFG 800W SLI PSU | Logitech Z-5500 5.1ch speakers | 3x Dell S2209W 22"wide TFT's (5760x1080res) | 1x Panasonic 42"Plasma | All working on Win7 Ultimate x64 | |
#4 |
Ultramodder
Weird... I had read (in the "how its meant to be played" developer program interview on BT) that NVIDIA have a gazilion different systems to test games for the gamedevopers. Why did they not use it to test the drivers on these machines first before making a beta. I bet they will make sure it would not crash on these machines in comparison to the public betas that bring down beta adictive consumers pc's
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#5 |
Mod Master
well they are _beta_ drivers so they can be as buggy as nVidia wants them to be, hence er, the um Beta tagging? Agreed people should submit bug reports on the driver, but to remove it means far less bug testing can now go ahead and as such the next revision may still have some bugs in that could have been removed this dev cycle
#6 |
Supermodder
I would probably have tried them, if my 8800 hadn't kerploded
__________________
Current Rig: i7 D0 2.66GHz, 6GB 1066MHz Corsair "Dominator", 285 GTX. |
#7 |
Ginger Nut
I installed them on Vista, but I can't be bothered to remove them.
They work just fine for me though.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back. |
#8 |
Hypermodder
i dont see the big news here
Sure they had bugs in them, but they are beta drivers, and you have to take them with a pinch of salt, and if the drivers have a big flaw, its best that nvidia stop distributing them until a fixed set are made |
| completemadness |
| View Public Profile |
| Find More Posts by completemadness |
| Thread Tools | |
