RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Jul 2007, 12:51   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Xilence X1 gaming case
http://www.bit-tech.net/hardware/200...ence_x1_case/1
Is the Xilence X1 a stupidly named tin box, or a brilliantly built gaming case with an annoying name? We find out.
Tim S is offline   Reply With Quote
Old 3rd Jul 2007, 12:58   #2
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
We've already noted that the case opens from the right panel and not the left, as is usually standard, but having a quick glance at the innards reveals that the motherboard must also mount upside down, with the power supply at the bottom
Couldn't that have been noted from the outside?
Also with the testing, isn't there a trend now for 2GB+ RAM on systems? So testing with 2GB of RAM may be more pertinent although not make much of a difference.
Was the PCI slot at the top of the case usable? Or did the case design make it redundant?
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 3rd Jul 2007, 13:07   #3
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
CardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to behold
It is noticeable from the outside if you stop to consider it, but we're a little slow sometimes
I just had a quick look and the top slot still looks useable though, not redundant at all I don't think.
__________________
CardJoe is online now   Reply With Quote
Old 3rd Jul 2007, 13:21   #4
DougEdey
DougEdey's Avatar
From the angle of the shots it looks like a card with caps may not make it in. Is there any chance you could test this please?
__________________
PSN ID: DougEdey
Twitter
Old 3rd Jul 2007, 13:31   #5
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
I've just looked and if the card is within ATX spec it'll fit. It's just like installing a PCI card into the bottom slot of any other ATX case, just this is now upside down.
Bindibadgi is offline   Reply With Quote
Old 3rd Jul 2007, 13:39   #6
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
Originally Posted by Article
We're not going to point fingers or place blame about it, but frankly we're of the opinion that it's your fault and you should all compensate by buying us lots of nice stuff. I for one have always wanted to own a pony.
J'ai LOLlé
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 3rd Jul 2007, 14:18   #7
cjmUK
Old git.
cjmUK's Avatar
cjmUK is a jewel in the roughcjmUK is a jewel in the roughcjmUK is a jewel in the roughcjmUK is a jewel in the rough
with brushes from my manly bracelet leaving faint marks
Lol. I'll take your word for it.
On a serious note, how hard can it be to design a case finish that doesn't scratch when you look at it and doesn't magnify fingerprints? I'm not on about this case specifically - loads of modern cases are shiny-but-delicate rather than practical. Must a more robust finish look rubbish?
Since I built my current PC last year (see sig), I've become a real snob regarding components. I don't always advocate the most expensive components, but I'm no longer inclined to use cheapo, sub-standard components. It's suddenly made my hobby very expensive.
And I think that one of the things I'm most picky about now are cases; apart from the usual suspects (Antec, Lan Li, Cooler Master, etc) there are few cases that I can stomach - which is ironic given the beige plastic crap that I've owned in bygone years.
As for the X1, it *does* look plastic-y and cheap, but compared to many other cases, IMHO is does have a reasonable clean look about it. I think too many cases try to hard to add facets and features. Not surprising comments from someone who owns a P180 perhaps.
__________________
P180B, Q6600 [with Thermalright HR-01+/Noctua NF-P12], 8GB OCZ Reaper PC2-8500, EVGA GTX 260 SSC, 3.75TB worth of Samsung F1s, running on Windows 7 RC
cjmUK is offline   Reply With Quote
Old 3rd Jul 2007, 15:58   #8
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin will become famous soon enough
It's a modified version of the sunbeam and sansun cases - so yes that top slot works just fine. If you've got the stones, you can drill out 20-something rivets to take off the left-top panel to manage wiring.
__________________
Desky
E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690
Tulatin is offline   Reply With Quote
Old 3rd Jul 2007, 17:25   #9
ChiperSoft
Minimodder
ChiperSoft is on a distinguished road
We've already noted that the case opens from the right panel and not the left, as is usually standard, but having a quick glance at the innards reveals that the motherboard must also mount upside down, with the power supply at the bottom.
Looking closer at the insides shows that the case has a total of seven tool-less expansion slots, located at the top of the case since the motherboard has been oddly flipped.
How is it that a bit-tech reviewer has never heard of Reversed-ATX? This isn't even a new concept, modders have been doing it for years.
To me, that's the most attractive element of this case. Boxy design that'll be easy to mod, but already reversed so we don't have to spend time doing it ourselves.
ChiperSoft is offline   Reply With Quote
Old 3rd Jul 2007, 17:26   #10
Tulatin
The Froggy Poster
Tulatin's Avatar
Problem to reversing is that heatpipe'd motherboards are suddenly useless.
__________________
Desky
Old 3rd Jul 2007, 17:28   #11
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I know of at least one manufacturer that claims its recent boards work fine upside down.
Old 3rd Jul 2007, 18:16   #12
trig
sweet sweet hangin joben
trig's Avatar
trig will become famous soon enough
do you guys have rosewill cases over there?
__________________
I love me some me e8400 @ 4.45 ghz..ac freezer 7..2 gigs patriot extreme 1150 mhz..abit ip35-pro..xfx 4770 with asus top bios @ 926 core/1077 memory..antec p182b..corsair hx620..seagate 500 gb 32mb cache THE best site ever...1600 signatures under the same avatar...time for a new one
trig is offline   Reply With Quote
Old 3rd Jul 2007, 19:18   #13
DeX
Mube Codder
DeX's Avatar
DeX is on a distinguished road
Excuse me but are you sure that the front panel is hydraulic? It certainly wouldn't take hydraulics to allow the panel to slide smoothly downwards. Now if the panel slides upwards that would require some sort of external force. But I think you will find that there is just a cog and rail of teeth that the door slides along that makes it slide smoothly at a constant speed.
__________________
Play my game: Shyguy's Cave of Death!
If you dont have the time to check your spelling and grammar, you dont have the time to post! -Liquid K9
DeX is offline   Reply With Quote
Old 3rd Jul 2007, 20:18   #14
The_Gnu
paper clip, tyre, gum....done
The_Gnu's Avatar
The_Gnu is on a distinguished road
hehe that power button must be the ugliest one I've ever seen.... reminds me of one of those child toys where you are supposed to push a large colored button to make an animal of the same color pop out from a box. I doubt that button will be left unmodded if someone decides to mod this case. And I'm also so tired of all these X's. It was cool when xbox 1 was released but nowadays it's just a proof of lac of fantasy.
/GNU
__________________
Project: ProtoHype
Project: Widescreen Projector
Guide: How to brush Aluminum
"To invent, you need a good imagination and a pile of junk." -- Thomas Edison
The_Gnu is offline   Reply With Quote
Old 3rd Jul 2007, 20:58   #15
greensabbath
Got Wood?
greensabbath's Avatar
greensabbath is on a distinguished road
IMO reverse ATX is the only way to go (you get to see the pretty side of the vga/ physx/sound card. I have two Asus Motherboards, the Commando and P5N32-e sli and both have heat pipes and both work great. Even when they heatpiped mobos are right side up though, those heatpipes get really toasty.
greensabbath is offline   Reply With Quote
Old 3rd Jul 2007, 20:59   #16
HugoB
H to the U to the G to the O to the B
HugoB's Avatar
HugoB has a spectacular aura aboutHugoB has a spectacular aura aboutHugoB has a spectacular aura about
Joe didn't say "I've never seen this before" he said it's odd, which it is... It is not common for a manufacturer to invert a motherboard.
__________________
TrustedReviews.com - things I write about for a job
HugoB is offline   Reply With Quote
Old 3rd Jul 2007, 21:05   #17
Tulatin
The Froggy Poster
Tulatin's Avatar
Problem is that heatpipes work in a very specific way: Unless wicked, heat travels upwards along the pipe, while cool liquid travels downward. Thus, on a non wicked ASUS mobo, you now have to trust the southbridge to dissipate all the spare wattage from down below it - mosfets and northbridge inclusive.
__________________
Desky
Old 4th Jul 2007, 03:33   #18
Sebbo
Multimodder
Sebbo's Avatar
Sebbo is on a distinguished road
One thing we did notice though was that the case doesn't have a reset button anywhere
might this be the elusive reset button? http://www.bit-tech.net/content_imag...1_case/b22.jpg
might be a bit difficult to tell from the symbol since everyone uses something different
i'd consider getting that case if i really need a case to mod...that hd rack will have to go through (though it seems to be holding up the shroud?)
__________________
If you and dead people know hex, how many people know hex?
Obligitory PC spec's:
Intel Core i7 920, ASUS P6T Deluxe, 12GB Corsair Dominator PC-12800, Sapphire HD5870, WD Velociraptor 300GB HLFS, Samsung Spinpoint 1TB, Creative X-Fi Titanium Fatal1ty Pro, Logitech G15 and G9, Logitech Z-5500 5.1 speakers, Dell 2408WFP 24" monitor
Sebbo is offline   Reply With Quote
Old 4th Jul 2007, 05:08   #19
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
I think you might be on to something Sebbo (I which case I'm a little disappointed by the reviewer)
However. Did anyone else see the power button and think it should be glowing? - maybe add a voice saying "I'm afraid I can't let you do that Dave"
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Old 4th Jul 2007, 07:05   #20
zr_ox
Whooolapoook
zr_ox's Avatar
zr_ox is on a distinguished road
Thats correct about wicked heatpipes, but I know that Asus heatpipes have been wicked for 1½ years due to the increasing popularity of reverse ATX cases.
I'd imagine that all other manufacturers followed this trend as well. I would be very surprised to hear of any current motherbords incorporating unwicked heatpipes.
I could not agree more. I recently bought the Stacker 830 (black) and the quality of finish looked great, it was however not durable at all, finger prints were no biggie though. The case easily picked up scratches to the point that after 2 months it looked like it was 1½ years old and had been home to three different pc's. I then upgraded to a Silverstone TJ09 and could not be happier. The finish is second to none, it does not pick up finger prints too easily and is very durable.
As for the case reviewed, I hate it.
__________________
0ptimizm
:PC under review
zr_ox is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
