Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
900W to 1100W PSU Group Test
http://www.bit-tech.net/hardware/200...test_july_07/1
Those with mighty power requirements need an equally mighty power supply. After spending thousands of your hard earned cash on some high end components, surely you want to top it of with a PSU that'll stand up to the task? We check out six units rated between 900W and 1100W.
__________________
#2 |
Richard Swinburne
bit-tech Staff
Article Edit: After speaking to Nanopoint again it appears our wires got crossed and the SilverPower SP1000 PSU was £150 INC VAT not Ex VAT. Scores and article adjusted accordingly.
#3 |
ITS OVER 8000!
Where are the PCP&C's and the Silverstones!
#4 |
Minimodder
Make sure you need one of those big boys before you buy one. I got a 650 Watt PSU with my system I built last year w/ Core 2 Duo, 2 GB PC 800 RAM, nVidia 7950 GX2 1 GB, 2x 250 GB SATA drives, TV Tuner, front USB, etc.... and the max power consumption does not peak above 215 Watts. Could have got a 450 Watt PSU and would probably have been fine :-S
#5 |
Richard Swinburne
bit-tech Staff
Didn't have them at the time of testing. We'll be looking into them in the future but they're not currently on the cards out of the 9 I've got coming to review.
PCPCs have only just come available too :P |
#6 | |
Supermodder
#7 | |
Revelation Machine
total waste of money unless you have a massive hard drive array or some obscenely expensive gfx setup
__________________
Marching Into History, Marching Into War, Marching Into History To Function As A Whore "Don't Fear Citizens! TAD KNOWS HIS RAID!" |
#8 | |
Richard Swinburne
bit-tech Staff
#9 | ||
inch-perfect
The drop-down box for the page index needs a minor adjustment:
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
#10 |
Revelation Machine
Lol, sorry bud, haven't even read it yet, was just meandering through threads
__________________
#11 | ||
Serious about coffee
Moderator
afaik the PCP&C is also rated at 1kw for higher temps and 24/7 use and the PCP&C is, well, its a PCP&C ![]() Quote:
| Mister_Tad |
| View Public Profile |
| Find More Posts by Mister_Tad |
#12 |
Richard Swinburne
bit-tech Staff
It keeps going afaik but it's only rated to 620W because they want it to be silent, which it is
Otherwise the heat and noise start to crank up.
#13 |
Don't panic!
Nice review, and thank you for putting that note in at the beginning about PSU ratings and what people actually need, a lot of people see quad-core and SLi G80's and think they need 121 jigawatts!
![]() Interesting about the Corsair PSU, I'll definately move that one higher up the list on my next upgrade.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains... |
#14 | ||
Mod Master
Isn't it true that a PSU is likely to be more efficient when it's not working near 100% load? ie, buying a bigger PSU like this and running it at less than 50% load may actually be MORE efficient than getting a 430W PSU and making it work like a slave to maintain your power requirements? Can you lovely Bit-Techers try running a test like this to confirm or refute this idea?
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64 Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF. Quote:
#15 |
Richard Swinburne
bit-tech Staff
Yea. But there's arguments over it: should you run at PSU at 50-75% and not stress it too hard? Or, do you buy what you need citing that it says it can do that so that's what it should be capable of.
#16 | |
Supermodder
http://www.silentpcreview.com/article692-page4.html |
#17 |
Supermodder
y would you anyone but a select few need one of those? corsair hx620 is enough. another way to make money.....
__________________
just got me a macbook, but it can play cod4! Last edited by pillow; 9th Jul 2007 at 23:10. |
#18 | |
So Say We All
__________________
Hell hath no fury like a hippo with a machine gun.
#19 | |
Mod Master
I like the Corsairs PSUs too (since I have one) but I think they're manufactured for Corsair by Seasonic anyway aren't they?
they're deffo made by another company anyway.
__________________
#20 | |
Richard Swinburne
bit-tech Staff
Wood: Last time I checked Brett swears by them I've always owned Enermax personally.
| Thread Tools | |
