RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Jul 2007, 12:23   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Abit IP35 Pro
http://www.bit-tech.net/hardware/200...bit_ip35_pro/1
Abit suggests that the IP35 Pro as an overclocker's wet dream with an attractive price. Thus, it follows in the footsteps of the cult classic AB9 QuadGT and promises to overclock just as well. Let's find out how it gets on...
Tim S is offline   Reply With Quote
Old 12th Jul 2007, 12:34   #2
MR BUNGLE
Shoddymodder
MR BUNGLE's Avatar
MR BUNGLE is on a distinguished road
Looks pretty sweet to me...
I found this section a bit confusing though: (here)
In comparison, Asus has made it so that if the P5K(3) uses the second PCI-Express x16 slot at its x4 bandwidth instead of x1, then the other extra PCI-Express x1 lanes are disabled. This way it gives priority to the included PCI-Express Gigabit Ethernet controllers. You’ll not notice any difference if you are running a 10/100 network, but if you have the infrastructure and rely on Gigabit Ethernet bandwidth, the PCI solution will come out slower, especially if you have a bunch of PCI devices too.
- Thought they were just PCI controllers?
/end minor niggle
MR BUNGLE is offline   Reply With Quote
Old 12th Jul 2007, 12:35   #3
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Rich is referring to the P5K/3 boards which have integrated PCI-E based Gigabit Ethernet.
Old 12th Jul 2007, 12:38   #4
MR BUNGLE
Shoddymodder
MR BUNGLE's Avatar
Whoops - what a TARD!
-sorry Rich-
Old 12th Jul 2007, 12:50   #5
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
When are we going to see thenw uGuru Panels coming out?
Looks like a nice board, and as always, a good review!
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 12th Jul 2007, 13:09   #6
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
I was talking to Abit earlier and was told "soon" on the u-Guru front. Will defo get one in when it arrives.
Bindibadgi is offline   Reply With Quote
Old 12th Jul 2007, 13:38   #7
Mankz
ITS OVER 8000!
Mankz's Avatar
Grr, they sound like my parents. Am I right in thinking that its supposed to be a 5.25" affair?
__________________
Sig'd!
Old 12th Jul 2007, 14:11   #8
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Yup, I cant find a picture of it I took at computex :/
Old 12th Jul 2007, 14:16   #9
Mankz
ITS OVER 8000!
Mankz's Avatar
Shot at 2007-07-12
Is that it?
If so, here is a review.
__________________
Sig'd!
Old 12th Jul 2007, 14:34   #10
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
tis here: http://www.bit-tech.net/hardware/200...re_show_tour/2
Old 12th Jul 2007, 16:58   #11
BUFF
Hypermodder
BUFF is on a distinguished road
Good review as ever.
Are you sure about the warranty section - afaik abit UK & USA have different policies?
Oh & knocking the board for having few USB ports when it supports 12 (albeit 8 x header & " It wouldn’t matter so much if Abit had included another few USB ports provided on a PCI bracket." - they did ) ...
BUFF is offline   Reply With Quote
Old 12th Jul 2007, 18:40   #12
pendragon
I pickle they
pendragon's Avatar
pendragon is on a distinguished road
wow.... i'm very impressed with this board.. I only wish it had SLI .. but really, seems really great for the price
pendragon is offline   Reply With Quote
Old 13th Jul 2007, 02:25   #13
leviathan18
Multimodder
leviathan18 is on a distinguished road
what my friend free cable guy FCG fails to see is that using his method abit will take longer time (more money) to secure the cooling so they wont use nuts screws and washers
__________________
sorry for my english
leviathan18 is offline   Reply With Quote
Old 13th Jul 2007, 06:59   #14
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is on a distinguished road
he did say why not four usb ports on the pci bracket
edit
would the screws actully make that much difference temp wise?
__________________
Hell hath no fury like a hippo with a machine gun.
Woodstock is offline   Reply With Quote
Old 13th Jul 2007, 10:49   #15
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Few PROVIDED USB ports. I can't plug a mouse into pin-outs :P
Abit in total include 6/12 usable USB ports out the box, which means you'll have to find yourself some other PCI brackets etc to use the rest of the ports.
About Abit warranty: I've just been chatting to the guy from Abit Taiwan this morning and apparently it might be different in the UK but the Abit manual, site and forums provide no definitive answer, just most say 3 years.
Screws and temps: take off the shitty thermal pads, lap the base, use a touch of good quality thermal paste and those screws and you'll get a far far better contact. This is true for all boards. Pushpins are cheap and easy to use on the production line but they're oh so very crap: You wouldn't hold a CPU down with a couple would you? Chipsets will soon need a similar security.
Old 13th Jul 2007, 12:39   #16
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
Does it come with 4 or 6 SATA cables? the text says 4 but there are 6 in the picture
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is offline   Reply With Quote
Old 13th Jul 2007, 16:28   #17
BUFF
Hypermodder
chances are that your case has at least 2 more though.
In the US it's 3 years with the first 2 years being free but a $25 charge in the 3rd (they'll also accept a board with physical damage for RMA for a $25 charge which afaik is pretty unique).
Sean@abit UK has said that in the UK it's just 2 years.
Old 13th Jul 2007, 19:28   #18
g3n3tiX
Resident frenchie
g3n3tiX is on a distinguished road
Originally Posted by Article (page 3)
sharing all sharing the same bandwidth.
oops.
Nice board...but a bit of a problem in the firewire department.
mmmmmhhh...unreleased intel C2E..yummy...
__________________
I also have a MTBF.
g3n3tiX is offline   Reply With Quote
Old 18th Jul 2007, 06:54   #19
Max Spain
Minimodder
Max Spain is on a distinguished road
This board is interesting. It is the only P35 based board I have seen that supports setting the command rate. Older Intel chipsets always ran it at 2T. I would expect a noticeable improvement in latency from that setting, but your results showed the opposite. I was wondering if during your review you noticed any performance difference between having 1T or 2T set in the bios???
Max Spain is offline   Reply With Quote
Old 18th Jul 2007, 08:51   #20
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Yep I've just had confirmation that it's only 2 years in the UK.
Hi Max, didn't check mate, there will be some but I can't imagine it's very noticable.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
