RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 16th Jul 2007, 09:44   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
OCZ DDR2 memory group test
http://www.bit-tech.net/hardware/200...ry_grouptest/1
OCZ DDR2 Memory comes in quite a range: from classic XTC to the watercooling capable FlexXLC to the latest Reaper HPC modules. We tested one of each to find out how they all stack up.
Tim S is offline   Reply With Quote
Old 16th Jul 2007, 10:15   #2
yakyb
CK is God!!!
yakyb's Avatar
yakyb is on a distinguished road
not impressed with the reaper thats good to know i was thinking of getting them over the standard 8500+ SLI editions but probably wont now
would have been good to see a direct comparison between the two tho to compare the cooling technologies
__________________
Gaming Box:: q6600 @3.0 :: 9800gtx :: Abit IP35 :: 4gb :: 1.4TB :: akasa eclipse :: Win7
Development:: PhenomII 955BE @3.2 :: 4200 :: asus M4A785 M Evo :: 1.25TB ::Win7
Media Centre :: q6600 @3.0 :: x1950pro :: asus p35 epu :: 8gb :: 320 GB :: Lc17B :: Win7
server:: I7 860 :: p55 gd65 :: 3450 :: 8 TB :: 8gb :: Rebel 12 :: server 2008 R2
yakyb is offline   Reply With Quote
Old 16th Jul 2007, 12:58   #3
Lian Li Lover
Multimodder
Lian Li Lover is on a distinguished road
You complained slightly that when not watercooling the flexXLC, there would be nasty insulating air inside the heatsinks. Surely that could be solved by putting some water in the heatsinks and sealing off the ends of the barbs? It wouldn't perform as well as if the 'sinks were solid metal, but the water should be much more conductive than air. Still a bit of a hassle though.
Lian Li Lover is offline   Reply With Quote
Old 16th Jul 2007, 13:01   #4
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
sure, that's certainly a solution but one many might be wary of should it leak
Bindibadgi is online now   Reply With Quote
Old 16th Jul 2007, 13:14   #5
Lian Li Lover
Multimodder
Just as likely to leak as normal water cooling.
edit: actually, the water would expand as it got hotter and could put the seals under lots of pressure and is thus a bad idea unless you left some room for it to expand.
Old 16th Jul 2007, 13:24   #6
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
That and unless you find bungs specifically made for it I meant, whereas normal watercooling should use good tubing and clamps.
Old 16th Jul 2007, 14:00   #7
Lian Li Lover
Multimodder
Something like this
Old 16th Jul 2007, 14:48   #8
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Blocking water in there would be dangerous IMO - it'll be like what happens when you run a watercooled system without the pump turned on... pressure builds up and things eventually burst.
Old 16th Jul 2007, 20:50   #9
masteroffm
What's a Dremel?
masteroffm is on a distinguished road
this is what I imagine routing the tubes would be like on the flexXLC
Tim S, do you have a larger version of your avatar, I am a bunny person and that picture is awesome.
masteroffm is offline   Reply With Quote
Old 16th Jul 2007, 21:16   #10
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
http://icanhascheezburger.files.word.../07/attack.jpg
Old 17th Jul 2007, 05:15   #11
Nature
Supermodder
Nature's Avatar
Nature is on a distinguished road
Flawess review in itself. But I'd like to see a really low end module tested with higher end group to see the actual diference in the benchmarks... no site does this. The benchmarks as they are now, are so scrunched together in the graphs, that it seems that you would buy the memory specific to your applications as some are stronger in some different games, encoding, audio tasks, etc, or just pick one which is cheap because there isn't much of a statistical difference across the board.
Like this piece of shoddy.
http://www.newegg.com/Product/Produc...82E16820159010
What happened to le Foums!?
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs
Nature is offline   Reply With Quote
Old 22nd Jul 2007, 16:28   #12
completemadness
Hypermodder
completemadness is on a distinguished road
but as all the barbs point up, when your trying to loop up your going to get in the way of the other set
OCZ should supply a block to get water in 1 side and out the other with 1 barb (sadly i don't think mobos are standard so it wouldn't actually work, plug as OCZ have barbed it already its will be hard to do anyway
As to the article, to me the first few graphs i looked at made no real sense, you had the memory all mixed up in different places, some at the top, some at the bottom, some in the middle, however the graph doesn't go fastest to slowest, so IMO it just seems to be a bit of a jumbled mess
here's a picture showing what i mean
as you can see, i have linked up the same modules, their all over the place, but the entire lot isn't ranked fastest to slowest, so i really don't understand how you ended up in this crazy ordering system
completemadness is offline   Reply With Quote
Old 22nd Jul 2007, 17:04   #13
LeMaltor
>^_^<
LeMaltor's Avatar
LeMaltor will become famous soon enough
They are ordered by speed 800mhz, 1066, 1142, 1151.....1250 :P
__________________
Welcoming the riff-raff since February 2009.
LeMaltor is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
