RSS
Reply
Thread Tools View Mode
Old 25th Jul 2007, 05:51   #1
radodrill
Resident EI
radodrill's Avatar
radodrill is on a distinguished road
Project: RAD GT (Updated 22-Oct-2007) Up-n-running, 98% complete
I've been working on a Custom acrylic PC case that I designed.
Case features a double sidewall to allow intake air without the need of front holes; also good for cable routing. Designed to hold 2 360mm Radiators; will only use one ATM with a Y-line loop. Stealthed CD slot; will wire the eject button and activity LED to an illuminated pushbutton to preserve the clean look of the front panel.
Here are some pics of the 3D model in it's current state. I'll update with pics of the actual build as well.
Expected Hardware Requirements:
DFI Lanparty UT 680i SLI T2R/G ---- Out of pocket
Intel Q6600 G0 ---- Out of pocket
Creative X-Fi XtremeGamer ---- Out of pocket
2x BFG 8800GTX ---- Out of pocket
2x1Gb DDR2 RAM (been eying the Corsair Dominator PC2-10000)
Lite-On SATA DVD burner ---- Out of pocket
Silverstone ST1000 Modular PSU ---- Out of pocket
500+Gb SATA2 HDD ---- Out of pocket
2x X-Flow Black Ice Extreme III ---- Sponsored by DangerDen
Variable speed D5 ---- Sponsored by DangerDen
20 feet 1/2" ID Tygon ---- Sponsored by DangerDen
2x Brass Fill-port ---- Sponsored by DangerDen
TDX for LGA775 ---- Sponsored by DangerDen
Maze4 chipset block (regular block) ---- Sponsored by DangerDen
875 chipset block ---- Sponsored by DangerDen
2x 8800 GTX blocks ---- Sponsored by DangerDen
2x single-slot PCI bracket for the 8800s ---- Sponsored by DangerDen
Fill-port Reservoir ---- Sponsored by DangerDen
6x 120mm Case Fans ---- Sponsored by A.C.Ryan
Wire-sleeving ---- Sponsored by A.C.Ryan
2x dual 30cm red CCFLs ---- Sponsored by A.C.Ryan
dual 30cm UV CCFLs ---- Sponsored by A.C.Ryan
dual 20cm UV CCFLs ---- Sponsored by A.C.Ryan
Acrylic Case feet ---- Sponsored by Petra's Tech Shop
H2O Dies ---- Sponsored by Petra's Tech Shop
Biocide H2O additive ---- Sponsored by Petra's Tech Shop
AS5 ---- Sponsored by Petra's Tech Shop
36" SATA2 cables ---- Sponsored by Petra's Tech Shop
Sponsors:
radodrill is offline   Reply With Quote
Old 25th Jul 2007, 16:10   #2
papeniglio
Supermodder
papeniglio's Avatar
papeniglio is on a distinguished road
OMG!!!! You're designing your custom case with Pro/E??? Man, you have balls!!!!
__________________
Mauro aka PapeNiglio
PocketR2D2 - ETEN M500 | HanSolo - ACER Aspire 5610 | C3PO - Gateway | Anakin - Wife PC+HTPC | ObiWan - File Server+Play PC | Skywalker - Old Play PC
papeniglio is offline   Reply With Quote
Old 25th Jul 2007, 16:25   #3
radodrill
Resident EI
radodrill's Avatar
Pro/E a lot easier/better than Sketchup
Anyways it's more fun modeling everything myself LOL
Old 25th Jul 2007, 17:13   #4
The_Beast
I *am* The Stig
The_Beast's Avatar
The_Beast is a jewel in the roughThe_Beast is a jewel in the roughThe_Beast is a jewel in the rough
looks really good
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
The_Beast is offline   Reply With Quote
Old 25th Jul 2007, 20:04   #5
Jedda
What's a Dremel?
Jedda is on a distinguished road
Very good idea. You'll get all the fitting together thrashed out before starting building.
You'll avoid a lot of errors doing things this way.
Jedda is offline   Reply With Quote
Old 25th Jul 2007, 20:26   #6
radodrill
Resident EI
radodrill's Avatar
That's the plan isn't it?
I'll have to get a few more parts ordered then I'll add them to the drawing; then it's go time.
Old 25th Jul 2007, 21:15   #7
Jedda
What's a Dremel?
Yeah, I was stating the obvious I guess.
Mainly just saying hello and expressing interest.
Old 28th Jul 2007, 02:03   #8
radodrill
Resident EI
radodrill's Avatar
Update: Going to get a new system for this case. Planned system specs:
DFI 680i SLI LT T2R/G
Intel Q6600
Patriot eXtreme 4Gb (2x2Gb) DDR2-800
eVga 8800GTX
Creative X-FI XtremeGamer
Black Ice GT Stealth 360 or Swiftech MCR-320
LIANG D5 / Swiftech MCP-655
DangerDen TDX
DangerDen Maze 4 i875 (on Northbridge)
DangerDen Maze 4 680i (on Southbridge)
EK-waterblocks or DangerDen Full-cover 8800GTX block
I'm still waiting on a few case parts but I'll probably get started on the cutting this weekend.
Old 28th Jul 2007, 23:07   #9
radodrill
Resident EI
radodrill's Avatar
Start of Worklog (28-July-2007): MB panel
I spent last night and today working on the motherboard panel.
Sketched panel in Pro/E
Masked the Acrylic sheet and marked the locations for the MB standoffs, RAD, and Front-panel port mounts.
With old MB to verify markings
Drilled pilot holes
Cutting the fan/RAD holes
Finished fan/Rad holes
Drilled out holes to secure the RAD
Illustration of MB standoff mounting
Drilled out and threaded holes for MB standoffs and FPIO mount
Unmasked panel
Mounting of FPIO
Added slots for cable pass-through. All cabling will be routed underneath the MB panel
Test fit of my current MB and FPIO ports
I don't have the new RAD/fans yet so I couldn't test fit those.
If anyone would like to see other detail shots/angles please LMK
Sponsors:
Old 30th Jul 2007, 04:40   #10
radodrill
Resident EI
radodrill's Avatar
Update (29-July-2007): Drive bays
Today I started working on the drive Bays:
Laid out the parts on the masked acrylic:
The cut out panels:
Threaded side panels for drive retention mechanism (will into detail on that later):
Cut drive support rails:
Unmasked 5 1/4 bay panels:
Unmasked 3 1/2 bay panels:
I have to wait on an order from US Plastics before I can glue these parts together.
Sponsors:
Old 30th Jul 2007, 05:23   #11
Teyber
Teyber's Avatar
Teyber will become famous soon enough
wow! i hate acrilic... i always have bad luck lol.
So did you use a heat gun for teh plexi angles?
__________________
cheapskate is (not) a noob
Teyber is offline   Reply With Quote
Old 30th Jul 2007, 06:06   #12
Dean MF
PC Freak!
Dean MF's Avatar
Dean MF is on a distinguished road
Looking very nice so far mate! Just one thing, you must try and keep the plexi masked for as long as possible to avoid scratches when doing future fittings.
__________________
My PC:
ECS KA3MVP Extreme Motherboard : AMD Athlon 64 X2 Dual Core 6000+ : 4 x 512mb DDRII 667mhz RAM : Radeon X1950 PRO GPU : 320 gig SATA2, 120 gig SATA2, 80 gig IDE : Raidmax Volcano 620W PSU : LG 18x DVD Writer with Lightscribe
Dean MF is offline   Reply With Quote
Old 30th Jul 2007, 14:20   #13
radodrill
Resident EI
radodrill's Avatar
I just bought some corner guard LOL
Old 30th Jul 2007, 14:21   #14
radodrill
Resident EI
radodrill's Avatar
Thanks for the tip; I'll keep it in mind
Old 30th Jul 2007, 20:28   #15
The_Beast
I *am* The Stig
The_Beast's Avatar
looking good
__________________
Old 1st Aug 2007, 01:48   #16
radodrill
Resident EI
radodrill's Avatar
Minor update:
Been busy with work the past few days and haven't gotten much done on the case. The good news is that DangerDen is on board to sponsor the Liquid cooling aspect of this case build
Old 1st Aug 2007, 04:34   #17
luis_pedro_Sato
Multimodder
luis_pedro_Sato is on a distinguished road
Good work so far
__________________
Sorry for my bad English and typos...
luis_pedro_Sato is offline   Reply With Quote
Old 2nd Aug 2007, 05:14   #18
radodrill
Resident EI
radodrill's Avatar
Update (01-Aug-2007): Corner Blocks & 3.5" bays
Today I received the 1" Acrylic cubes that I'll use to assemble the main panels of the case
Drilled/Tapped the cubes so that I could screw on the panels
Closeup of one cube
Next I polished the parts for the 3.5" drive bay
3.5" Drive bays clamped and glued
Sponsors:
Old 3rd Aug 2007, 03:25   #19
radodrill
Resident EI
radodrill's Avatar
Update (02-Aug-2007): Drive bays
Finished the 3 1/2" drive bays
Drive retention mechanism; screws on one side with nylon spacers on the ends
Test fit with old drive
Sponsors:
Old 3rd Aug 2007, 03:50   #20
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has a spectacular aura about500mph has a spectacular aura about500mph has a spectacular aura about
very nice acrylic work i must say.
keep up the great work
500mph is online now   Reply With Quote
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
