#1 |
Deaf forever to the battle's din
Mouse Mats
Any chance of seeing (preferably) a roundup of available mousing surfaces or just a review of the 'best'?
Dunno if anyone would be interested in this, but I've been looking for a new mat for a while,m and realized I have no idea what to look for...
__________________
ASUS M4A785TD-M Evo | AMD Phenom II x4 955 BE | D-Tek FuZion
4GB Corsair XMMS3-10666 | Corsair TX650 Point Of View 8800GTX | EK FC-8800 |
#2 |
inch-perfect
I was just about to ask this. But I decided not to after some thought for a weak connection with computer hardware/industry. It's at Bit-tech's discretion anyway.
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
#3 |
Hypermodder
Would be nice.
__________________
Athlon 64 X2 3800+ @ 250x10 (1.475v) | EVGA GTX 260 55nm SSC | A8N-SLI Premium | 2x(4GB) Corsair Twinx2048-PC3200C2 | Asus Xonar DX | Antec truepower 550w | Akasa Eclipse-62 DDC12VPlus1, DD TDX, 3/8 tygon r3603 tubing, PA120.2, DD double floppy bay res |
| Bladestorm |
| View Public Profile |
| Find More Posts by Bladestorm |
#4 |
Dont do that...
I haven't used a mouse mat in years. but I guess I should since my last desk had the finish worn off. lasted a few years though, not bad for 100 bucks.
It does raise a question though, are all mouse mats created eaquel? a review would be a good idea. |
#5 |
Mod Master
A mousing surface review would be nice, but they're an absolute pain in the ass to do. The reason I say that is because everyone has different preferences on what type of mousing surface to use. Some like steel pads while others like hard plastic or glass. You also have people who like to use no pad at all. Finally, you have the people, like me, who won't use anything but a cloth mat. On top of that, you then have the choice of using teflon slick pads on the bottom of your mouse or using nothing at all and it becomes a very hard thing to do. Who knows, maybe you'll see a mouse mat roundup soon.
Here's a picture of my mouse pad. I've had this sucker for around two years now and it's still showing very little wear. ![]() That's a MX1000 for size reference. Excuse the blurriness of the picture and the dirtiness of my desk.
__________________
<+DougEdey> you getting PGR4 mitmit? <mitmit> not me, Geoff is probably wanking like a lepper at the thought of it though |
#6 |
Player Character
bit-tech Staff
Well, I have one in right now, so I'll look at getting another few in in the future for a review.
__________________
#7 |
A motorbike of jealousy!
The Steelpad mouse mats are ace. I have one. When you first open the package you feel like you've just spent money on a crappy piece of plastic, but after a while you'll never want to use a standard mouse mat ever again.
#8 |
Banned
If you get a mousemat roundup going, I demand (yes, that's right, I said demand) you go to woolworths and buy their £3.50 square teflon baking tray and include it in the roundup. Coupled with a little blu-tak to stick it to a desk this thing is easily the equal of all those namby pamby £20 mousemats I've tried at LAN's. Plus, it gets uber-ghetto points.
| specofdust |
| Find More Posts by specofdust |
#9 | |
The Real Pacman
bit-tech Staff
__________________
XBL : Shogun Hiren Homepage | HD Tach | Last.fm | DeviantArt bit-tech newsletter | bit-tech Blog |
#10 | |
bit-tech Staff
#11 |
Banned
I assure you Hiren, it works (verified working for about 3 years and counting on my desk). It's pretty awesome and if you add some cellotape to yourmousefeet it's amazingly smooth (even without the tape, it's super duper).
| specofdust |
#12 |
inch-perfect
The problem with a baking tray is the tinny noise when the mouse is sliding around. This is why mats have become increasingly popular, and that they offer superior tracking for the really b*tchy laser optics of new mice.
__________________
#13 |
bit-tech Staff
I've still running an LED mouse, are the lasers much better?
#14 |
Banned
I don't experience any "tinny" noise when the mouse is sliding around. There's a quiet friction noise, but no less than you're going to get when you're moving one object on another, and far less than I get moving the mouse over my desk.
Jamie; Laser mice are often considered inferior to LED mouses since the tech is younger. Eventually they'll definitely be better, but for now a lot of people consider LED mouses to be superior. |
| specofdust |
#15 |
inch-perfect
They allow for much higher sensitivities, but that doesn't translate into better tracking. For lasers, you need a non-uniform surface like an optical would, but you'd need a much more finer grit for that surface since the optics capture a much smaller surface area than an LED mouse would with its camera. Lasers help for very fine, per-pixel movements without having to turn down the sensitivity in software because laser optics natively scan at much higher resolutions, but they are finicky for regular use and even for games.
**edit: get some glossy clear office tape and lay them down width-wise across your desk to create a shiny mouse mat made of this tape. Try using an LED mouse on it and then a laser mouse. Do the same on a sheet of printer paper. You'll notice some very sporadic tracking behaviour.
__________________
#16 |
Player Character
bit-tech Staff
G7 or Razer Deathadder for teh win!!
__________________
#17 |
bit-tech Staff
I want a deathadder!
#18 |
Player Character
bit-tech Staff
Can't have mine :P
__________________
#19 |
I pwn all your storage
You checked that it's still under your hand? Jamie is a ninja
#20 |
Richard Swinburne
bit-tech Staff
| Thread Tools | |
