RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Jul 2007, 12:01   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Zalman Z-Machine GT1000
http://www.bit-tech.net/hardware/200...chine_gt1000/1
The Zalman GT1000 may look gorgeous, feel gorgeous and have more doors than that hallway of infinite doors in The Matrix (you know the one), but how will it far in our rigorous testing? Find out within.
Tim S is offline   Reply With Quote
Old 26th Jul 2007, 12:44   #2
[cibyr]
Sometimes posts here
[cibyr]'s Avatar
[cibyr] is on a distinguished road
I bought one of these, took the sides off and crawled through it as your article suggested. Unfortunately, I cut myself during the process and as such will be suing bit-tech for one meelion dollars!
__________________
I guess aTrack being no longer supported by bit-tech means it really is dead...
[cibyr] is offline   Reply With Quote
Old 26th Jul 2007, 13:27   #3
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
Does a GTX8800 fit? (or 2)
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 26th Jul 2007, 13:46   #4
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
There is plenty of room
Old 26th Jul 2007, 13:55   #5
Amon
inch-perfect
Amon's Avatar
Amon is on a distinguished road
One reason that puts this case in the "too expensive" category: it doesn't appear to fit anything larger than an ATX mainboard for what you pay. Looks good otherwise.
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals
Amon is offline   Reply With Quote
Old 26th Jul 2007, 13:55   #6
DarkLord7854
Web Developer
DarkLord7854's Avatar
DarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to behold
Was very interested by it.. till I saw the price
__________________
Current Computer: eVGA 780i Motherboard | Q6600 Core2Quad | eVGA GTX260 896Mbs 216-core | 2x Seagate 500Gbs | 8Gbs OCZ Platinum DDR2 800 | Creative XtremeGamer X-Fi | Thermaltake Armor Case
Custom WordPress, ZenCart, Joomla, vBulletin, etc installs and skinning, PM/E-Mail for a quote
DarkLord7854 is online now   Reply With Quote
Old 26th Jul 2007, 14:21   #7
Meanmotion
Supermodder
Meanmotion's Avatar
Meanmotion is on a distinguished road
Joe wasn't as won over by this case as I was. Personally, i think it's gorgeous!!!!!! The quality of construction is without rival and some of the little touches are shear genius. Sure it doesn't fit other form factors and some of the scibbling on the side looks a bit out of place but overall I'd say it's worth every penny.
As for how the hard drive bays work. Each bay is surrounded by rubber cushioned metal rollers that enable you to simply slide the hard drive into place. A final roller then fits over the end of the disk to lock it into place.
To mount the disks on the bottom bays, you attach four special rubber coated screws to the sides of the hard disk then mount the screws in the clamps that are fixed to the bottom of the case. The 'traditional' stacked hard drive bays can accommodate four drives so you shouldn't need to use these bottom mounts unless you're a serious storage nut.
__________________
Athlon64 X2 4400+ || A8N SLI Premium || 2Gb Corsair XMS Pro || 2*40Gb Raptor (striped) || 250GB External || Radeon X1950Pro || WinXP
www.OutForBlood.co.uk || www.4Qradio.com || www.EdwardChester.co.uk
Meanmotion is offline   Reply With Quote
Old 26th Jul 2007, 14:31   #8
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
you pay for quality.....
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key!
DXR_13KE is online now   Reply With Quote
Old 26th Jul 2007, 14:38   #9
Mister_Tad
Serious about coffee
Moderator
Mister_Tad's Avatar
Mister_Tad is just really niceMister_Tad is just really niceMister_Tad is just really niceMister_Tad is just really nice
Zalman joins the ranks of companies that make l33t cases
Who on earth had the idea to plaster Z-MACHINE all over the sides *sigh* , cant wait for a OMG FARTAL1TAAH PWNZ J000!! edition of this'un
Hideously overpriced and no PSU? 6/10 for value is being pretty damn generous imo.
You do pay for quality, but nearly £100 more than lian-li's top dogs?
Mister_Tad is offline   Reply With Quote
Old 26th Jul 2007, 15:08   #10
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Yes, but consider what you get: aluminium is very expensive and the sides are really thick!
Bindibadgi is offline   Reply With Quote
Old 26th Jul 2007, 15:10   #11
DarkLord7854
Web Developer
Then can I just buy it without the thick side panels and a 150$ discount?
__________________
Old 26th Jul 2007, 15:15   #12
Meanmotion
Supermodder
Meanmotion's Avatar
Lol, this is based on a case originally designed by/for Fatal1ty, http://www.quietpc.com/gb-en-gbp/products/cases/gt1000.
They may do another Fatal1ty variation on this one again, who knows.
Er, no PSU? You kidding me! You pay £150 for an uber PSU anyway, how on earth do you think a PSU could be incorporated into that price?!
__________________
Old 26th Jul 2007, 15:15   #13
Mister_Tad
Moderator
Mister_Tad's Avatar
the panels are thick indeed (a bit like the panels on the newest lian-lis in fact), but its still 50-70% more expensive than an otherwise top of the line (and far better looking imo) case from lian-li, antec et al.
What I'm saying about the PSU is that if it did have a decent PSU with it, it may justify the price. Its £100 more than most very good cases, which can pick up a pretty damn good psu.
Old 26th Jul 2007, 15:24   #14
tk421
Idiot.
tk421's Avatar
tk421 will become famous soon enough
i think i screwed up years ago when i bought my pc-71.
all other case seem to fail in comparison. don't get me wrong - this one comes close ... but i'm not much for the company logos screened all over.
when i get around to building a new box, i am at a total loss as to which way i will go. i don't think the price tag is justified in this case. if it was 200$, i would consider it. 350$ - no bloody way.
__________________
:gamebox: e7400@3.5 (333x10.5)|MSI Neo3f(p43)|2x2gb pc6400|HD4850 (512)|1.6tb across 4 hdd|CM590|westie lcm-22w3|
tk421 is offline   Reply With Quote
Old 26th Jul 2007, 16:56   #15
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
It's the same with the PC60: it was what, £65 6 years ago? Now it sets a benchmark for cheap cases that no one else has yet attained imo.
Old 26th Jul 2007, 17:13   #16
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
PC-60 was £80-£100 4 years ago. I know because I bought my PC-61 for £80 and thought it was a right bargain.
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 26th Jul 2007, 18:43   #17
wafflesomd
Hypermodder
wafflesomd's Avatar
wafflesomd is on a distinguished road
Stupidly high price.
wafflesomd is offline   Reply With Quote
Old 26th Jul 2007, 20:41   #18
Snaek
Multimodder
Snaek's Avatar
Snaek is on a distinguished road
Looks pretty good but "Z-Machine"? Seriously?
Snaek is offline   Reply With Quote
Old 26th Jul 2007, 23:44   #19
Darkangel
Multimodder
Darkangel is on a distinguished road
bit daft having the front fans so close against a solid drive cage.
Darkangel is offline   Reply With Quote
Old 27th Jul 2007, 14:31   #20
ChromeX
Ultramodder
ChromeX's Avatar
ChromeX will become famous soon enoughChromeX will become famous soon enough
awesome looks, horrible price!
__________________
3Ghz P4E, asus P4C800E-deluxe, 2GB OCZ (2x1024), Sapphire HD 3850, SB audigy 2 zs
ChromeX is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
