#1 |
Player Character
bit-tech Staff
Project Enter the USB
http://www.bit-tech.net/modding/2007...nter_the_usb/1
Kurtis Kronk takes us through a quick and simple USB key mod which even a novice can handle and which anyone can have fun with. ![]() ![]() ![]()
__________________
#2 |
Ultramodder
is it friday allready?
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#3 | |
Ultramodder
__________________
| Washfordmonkey |
| View Public Profile |
| Find More Posts by Washfordmonkey |
#4 |
Geoff Richards
Moderator
You've got 2.5 shopping days to order in your cheapo USB stick before spending Saturday morning in the garage with a Dremel in one hand and epoxy in the other
#5 |
I pwn all your storage
I'm doing this with my snowman :P
#6 |
Sierra my delta, bravo!
LOL! That guy's freaking hilarious, especially with the protective gear. :P
#7 |
I *am* The Stig
cool
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
#8 |
I pickle they
good to see some Modding articles on here ..especially simple ones for modding-n00bs like myself
thanks! |
#9 |
Victim of AdvancedModernCapitalism
OMG! all those pubic hairs! you should just get a black keyboard to do a mod like that, no one will notice the hairs...
__________________
Netbook: Asus eeePC 901; 12Gb SDD; Custom Ubuntu 9.04 Minimal Compiz Standalone.
Laptop: Intel Centrino Duo T5500 1.66ghz; 2048mb RAM; ATI Mobility Radeon x2300; Hitachi 120gb iPod Classic 120GB; Maxtor 160GB External; Ubuntu 9.10 x64 and Windows 7 x64. |
#10 | |
Hypermodder
IMO - this doesn't look amazing, i think its quite a cool idea, but it doesn't look right to me ... The notch where the USB connector sticks out makes it look a bit shabby, it needed a tiny bit of filling and a bit of paint to hide it Also, has the board floated up in the glue ? because it doesn't look level to me ... Also where he sanded the edges to flatten it, now looks opaque, and the whole thing needs a light sanding to make the effect right Sorry to be so harsh, maybe I'm just spoilt by the generally amazing front page articles ..... |
| completemadness |
| Find More Posts by completemadness |
#11 |
Monkeymodder
Personally I would have passed on the transparent epoxy back and used a piece of plastic from the side of the keyboard as a bottom cap, that way he wouldnt have had to worry about matching the colour. ah well each to their own when it comes to modding i suppose
__________________
Core 2 Q6600 G0, ASUS P5K3 Deluxe WiFi AP, 2GB ASUS DDR3 1333 8-8-8-20, XFX GTX280, Antec P182
| timmythemonkey |
| Find More Posts by timmythemonkey |
#12 |
Hypermodder
wicked mod, thanks for featuring it bit
Might have to make one myself
#13 |
-Xbox Pwner-
They should make a cap with the ' key.
-CollinstheClown |
| CollinstheClown |
| Find More Posts by CollinstheClown |
#14 |
Multimodder
Enjoyable article with a good result, achievable by many. Top marks
![]() An excellent idea
#15 |
Banned
That was excellent
| specofdust |
| Find More Posts by specofdust |
#16 | |
What's a Dremel?
#17 |
Multimodder
I'm glad most of you enjoyed the article.
![]() I fully realize my mod isn't perfect, but overall I'm pleased with it for what it is. "LOL! That guy's freaking hilarious, especially with the protective gear. :P" --> Thank you, sir! "OMG! all those pubic hairs! you should just get a black keyboard to do a mod like that, no one will notice the hairs..." --> I promise those aren't pubic hairs. Not most of them, anyways. I have really thick hair and lots of it falls out on my desk and keyboard. I have no good excuse for all that food in the keyboard, though. Looking back, I would've cleaned it for the photos - I thought it was funny at the time for some reason, heh. "IMO - this doesn't look amazing, i think its quite a cool idea, but it doesn't look right to me ... The notch where the USB connector sticks out makes it look a bit shabby, it needed a tiny bit of filling and a bit of paint to hide it. Also, has the board floated up in the glue ? because it doesn't look level to me ... Also where he sanded the edges to flatten it, now looks opaque, and the whole thing needs a light sanding to make the effect right. Sorry to be so harsh, maybe I'm just spoilt by the generally amazing front page articles ....." --> No need to apologize. I'm quite aware of the usual caliber of modding 'skeelz' you guys are used to, so I wasn't really aiming to leave anyone in utter disbelief at my amazing craftsmanship. It was more so meant to be entertaining and hopefully to encourage some people to get creative and mod something, even if it's something simple. Now, I should mention that this USB drive looks a bit cleaner in person than it does when photographed - in those close-ups you can see some flaws much easier than you really can when holding it. For example, the notch looks perfectly fine, no filler material is really needed, though perhaps it wouldn't be a bad idea to fill it a little to seal it from moisture in case I throw it in the wash cycle, or a rogue bear pees on it or something. I will admit the backside looks a bit crap - I would do a better job of that if I did this over, for sure. Thanks for your feedback, your criticism is certainly warranted. :-D "They should make a cap with the ' key." --> You know, I thought about that... thing is, I couldn't figure out a good way to do it without molding a custom key myself, because the keys curve away from each other. So the ' key would have to be facing down or something. If you've got a good idea for how to work that, I'm all ears. |
#18 |
Multimodder
I was about to suggest you should've tracked down an IBM M keyboard, and just popped off the key-cap from the Enter key. Then I thought about it, and popped of the Enter on my M keyboard....
You would've had *more* plastic to clear out, not less. It's only the smaller keys that separate from the actual key, so you could re-arrange the letters.... Cool quick-and-dirty mod, though. I've got a 64MB flash I've been thinking about making a new housing for, might go this route, rather than custom fitting clear acrylic...
__________________
Jason A. System: Intel Core2 Quad 6600, 8GB DDR2-800, 2x250GB SATA (RAID-0) Maxtor HDs, 1x500GB SATA HD, 1x160GB SATA Maxtor HD, eVGA 680i MB, Saphire HD 5870, Creative X-Fi Fatality, DVD-+RW DL Lightscribe, 16X DVD-Rom, Thermaltake 1200w PSU, Windows Vista Ultimate x64 |
| m0ng0lh0rde |
| Find More Posts by m0ng0lh0rde |
#19 |
Geoff Richards
Moderator
Maybe we should hold a Mod a USB Key compo so everyone can have a go. Not sure what the prize should be though
#20 |
Pewlius Caesar
bit-tech Staff
another USB key?
![]() I'll have a think of something better than that...
__________________
| Thread Tools | |
