Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Faulty HD 2000-series graphics cards on the loose
http://www.bit-tech.net/news/2007/08...on_the_loose/1
AMD has revealed that there was a fault in some of its HD 2000-series qualification software, leading to faulty cards appearing in the market.
__________________
#2 |
CAMRA ***.
I've only just ordered a HD2600 XT for delivery tomorrow! I hope mines not faulty, is there anyway of telling? Will it just not work at all?
#3 |
Pewlius Caesar
bit-tech Staff
It probably won't work at all, but I can't confirm that for definite.
__________________
#4 |
Hypermodder
its good to know the validation software wasnt validated <_<
| completemadness |
| View Public Profile |
| Find More Posts by completemadness |
#5 |
Geoff Richards
Moderator
I think what Tim means is that IF it's a "faulty" card then he thinks the fault will manifest itself as the card just not working at all - it's not like it will be "only a little flakey".
Whomever you ordered it from should probably be already aware of the issue and sort you out with a replacement (if not, let us know and we'll send The Boys around) |
#6 |
CAMRA ***.
well I installed it, it all seemed alright (i.e. it booted into windows). First thing I did was to try to install the drivers from the CD and it blue screened halfway through... now all it does is post and can't get to the windows loading screen!! Time to post in tech support!!
On a side note, I ordered it through Scan, free postage cheesecake! |
#7 |
6 screens / 1 card
False Alarm: Defective Radeon Report "Completely Untrue"
Saw this yesterday: http://www.dailytech.com/article.aspx?newsid=8374
__________________
It's not about how life treats you, it's about how you treat life. |
| Thread Tools | |
