Thread Tools |
#1 |
Player Character
bit-tech Staff
Thermal analysts examine Xbox 360
http://www.bit-tech.net/news/2007/08...ine_xbox_360/1
Japanese thermal design experts take apart an old Xbox 360 and one which has been repaired this year to check just what's going on inside Microsoft's beige box. (not)
__________________
#2 | |
Hypermodder
The fan is small because they want to make the console small, if the console is only 60mm high, there is only room for a 60mm fan Larger fans shift more air at the same DB levels (and therefore, shift the same amount of air at lower DB levels) Also, if the gfx heatsink is such a problem, why the hell didn't MS use a slimline DVD drive, which would at least 1/2 the space required for it .... |
| completemadness |
| View Public Profile |
| Find More Posts by completemadness |
#3 |
I pwn all your storage
http://forums.xbox-scene.com/index.php?showtopic=580504
That shows what happens when you make simple mods to the 360. |
#4 |
in luv 2.0
I checked the Videos on Youtube when some Japanese guys took the PS3 apart , and it was as shocking difference as Driving the Mercedes Benz Maybach and a Yugo, and i refer here that PS3 is the Mercedes ;F , the PS3 interior looks like it was build to last , while X360 was so messed up like i would see and poorly made DIY PC , the motherboard of X360 is only 5 or 6 layers thick , for such a hardware it should be at least 7 layer PCB. Also the solder points are poorly made , it simply looks like someone was running around inside with a hand solder. To simply put it i don't know a single person from my friends that had x360 and he didn't had to RMA it. Either the Dvd drive fails or the Ring of Death comes to play. Anyway i have seen some i486 based PC's back in my old days that had been better build then this plastic "toy" box.
__________________
"i'm illegal,like a bomb thats ready to blow" |
| Bl4ckM0onk3y |
| Find More Posts by Bl4ckM0onk3y |
#5 | ||
UnSeenly
#6 | |
in luv 2.0
__________________
| Bl4ckM0onk3y |
#7 | |
Neither Patrick nor Sparta
damn the Graphics LSI can get over 100*C. thats insane. and the fact that nothing changed with the repair is quite ridiculous.
__________________
#8 |
Hypermodder
Seriously, how does a thermal expert arrive at the conclusion that small fans are ever quiet? Small fans have annoying high frequencies and need to spin faster to push the same amount of air as a larger one.
Also, the 100 C thing isn't necessarily bad as long as it's built to withstand that temperature. I'm not sure if it is, I'm just saying it's okay as long as its within specs. |
#9 |
Hypermodder
My friend's 360 is seriously on it's last leg and we can't play it anymore without it freezing every 10 seconds and it doesn't matter what game we play it still does it. I would be so mad if I was my friend. He spent $499 on his Premium system in 2005 and for it to already be giving out and for him to now have to spend $100 and be w/o his system for a little over a month is just horrible. Not to be a fanboy (like everyone thinks I am, but am NOT) has the PS3 had any issues like this since its launch?
| devdevil85 |
| Find More Posts by devdevil85 |
#10 | |
Supermodder
#11 |
here... take a slice of my pie
nope. even at currys, we have rammed it in a glass cabinet that is locked, and its on demo nearly 24/7. hasn't crashed once.
i wish MS would improve the cooling. its easily done.
__________________
Im a MAC |
#12 | ||
Multimodder
Just some thoughts... |
#13 | ||
in luv 2.0
__________________
| Bl4ckM0onk3y |
#14 |
What you Looking at Fool!
Touch Wood mine is ok apart from the random crash with certain games.
__________________
| mikeuk2004 |
| Find More Posts by mikeuk2004 |
#15 |
Rainbow Warrior
Was hoping to get an Xbox 360 at some point but the thermal issue keeps cropping up. Is there any noise from microsoft that they will address this problem in a future release?
__________________
The difference between fiction and reality? Fiction has to make sense. " Tom Clancy Last edited by Bungle; 6th Aug 2007 at 20:31. |
#16 |
CPC hang out zone (i Fix pcs i do )
the Xbox is noisy full stop them fans are to noisy to start with
if M$ say yes it was an fault with the Xbox thay will probably get sued allot (if not many USA peeps have already tyred to) dono why thay have not resoved this problem by makeing an new Xbox 360 that does not have these problems, Xbox 360 is the most unrelible console ever made and i not buy one untill its resoved with an revsion Bigger heat sink mite lower the temps an little bit but that Revew of an Xbox was an little lame due to the fact he did not bother to test the New Xbox 360 heat sink as well
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947 |
#17 |
Hypermodder
/\ Why would they waste their time testing out the "new" 360 when "to [their] surprise, the composition of the repaired Xbox 360 looked completely the same as that of the Xbox 360 purchased in late 2005. It turned out that Microsoft provided repair without changing the Xbox 360's thermo design at least until May 2007."
| devdevil85 |
#18 |
The reports of the modified cooling didn't come till June/July anyway.
#19 | |
Hypermodder
Hrm, bit-tech paraphrased the bit about the fan being made smaller to reduce noise ? the actual comment seems to be :
__________________
Athlon 64 X2 3800+ @ 250x10 (1.475v) | EVGA GTX 260 55nm SSC | A8N-SLI Premium | 2x(4GB) Corsair Twinx2048-PC3200C2 | Asus Xonar DX | Antec truepower 550w | Akasa Eclipse-62 DDC12VPlus1, DD TDX, 3/8 tygon r3603 tubing, PA120.2, DD double floppy bay res |
| Bladestorm |
| Find More Posts by Bladestorm |
#20 |
Minimodder
Well after my 360 being returned from repair for ring of death, it has a new second HS installed so MS are addressing this issue.
It appears that this is only being done after June, so it would be interesting to see a re-evaluation of the article with the new HS, which is now being installed. |
| Thread Tools | |
