RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Aug 2007, 11:59   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Faulty HD 2000-series cards... or not?
http://www.bit-tech.net/news/2007/08...ies_graphics/1
So, there are apparently no faulty HD 2000-series Radeon graphics cards on the loose and no one knows why there was such a fuss in the first place?!
Tim S is offline   Reply With Quote
Old 10th Aug 2007, 16:48   #2
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
Merge Threads?
http://forums.bit-tech.net/showthread.php?p=1532787
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Old 10th Aug 2007, 16:56   #3
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is on a distinguished road
Aren't all HD2000 series cards defective, in that their performance is woeful, they draw an obscene amount of electrical power, and they are quite handsomely put to shame on all fronts by their nVidia counterparts?
Maybe they have a short circuit across half the pipes - would explain the horrendous power draw and underperformance!
__________________
Demand Naked DSL in the UK!
mclean007 is offline   Reply With Quote
Old 11th Aug 2007, 01:40   #4
Gravemind123
avatar not found
Gravemind123 is on a distinguished road
Well, the lower HD2000 cards that were supposedly having these issues actually use less power then the nVidia cards, but yes, their performance is as much of a let down as the 8600/8500 series of cards are. I hope that the mid-range comes back to life in the next generation.
__________________
E4400 - Asus P5B-Plus - Antec NeoHE 500 - 4GB OCZ SLI XTC - EVGA 8800GT - 250GB WD + 320GB Seagate
Lian-Li PC-61 - Zalman Cooling - Creative GigaWorks T20 - AG Neovo M-17
Dell XPS M1330 - T8300 - 4GB Ram - 8400M GS - 250GB HDD
Gravemind123 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
