Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Lab Update: Nvidia nForce 680i SLI
http://www.bit-tech.net/hardware/200...rce_680i_sli/1
The latest P30 BIOS for Nvidia's nForce 680i SLI chipset claims to offer a whole host of performance and overclocking improvements, so does it give a new lease of life to an ageing chipset?
__________________
#2 | |
Multimodder
__________________
"No keyboard found: Press F1 to continue..." |
#3 |
Modder
How does its overclocking performance compare to P35 on the newer BIOS?
#4 |
Minimodder
That is a disappointing bios "upgrade." I wouldn't be surprised if they just loosened the chipset's internal timings. When I read the description, I was hoping that they had added GTL adjustments, but this bios is just a way to inflate their mhz numbers to make ppl think 680i is a better overclocker than P35, even though performance is now worse
A custom bios is a way better option.
#5 |
What's a Dremel?
#6 | |
Richard Swinburne
bit-tech Staff
#7 |
KEEP IT CLEAN!
Is there any difference with this update to the standard packaged bios im running?
Oh, how difficult is it to update a bios? Thanks Sam
__________________
The Rig: i7 920 D0, Gigabyte EX58-UD5, 12GB DDR3 1600mhz, BFG GTX295, Samsung 64gb SSD, WD 640gb Black, Samsung F2 Eco 1TB, Dell 3007WFP, Windows 7 RC.
The Netbook: Samsung NC10 Black, Intel Atom, 2gb DDR2 |
#8 | |
Web Developer
__________________
Current Computer: eVGA 780i Motherboard | Q6600 Core2Quad | eVGA GTX260 896Mbs 216-core | 2x Seagate 500Gbs | 8Gbs OCZ Platinum DDR2 800 | Creative XtremeGamer X-Fi | Thermaltake Armor Case Custom WordPress, ZenCart, Joomla, vBulletin, etc installs and skinning, PM/E-Mail for a quote
#9 | |
Richard Swinburne
bit-tech Staff
Sam: boot your board, on POST check the P number at the top: that's your BIOS version. Updating should be as easy as any other board. |
#10 |
Web Developer
Well I have the very first generation board from eVGA (when they boards had the data corruption problems), switching to Quad eventually but the minor performance drop doesn't really seem worth "upgrading" (if you can call it that considering it's mostly a down-grade) only to have slightly better overclocking ability.
__________________
#11 |
Richard Swinburne
bit-tech Staff
Depends how old your BIOS is I suppose. It's only a minor performance drop but the overclockability is far greater as well as CPU recognition for correct voltages etc.
#12 |
Web Developer
So it's worth it? I only have an E6300 for now, waiting on the Q6600 to drop to it's intended price
__________________
#13 |
Pewlius Caesar
bit-tech Staff
If you're upgrading to a quad-core, I'd drop the new BIOS on personally (especially if you're looking for better OCing).
__________________
#14 |
So Say We All
hmmm and then it could get lost in postage and end up at my house
__________________
Hell hath no fury like a hippo with a machine gun.
#15 | |
KEEP IT CLEAN!
Anyone got a link to the EVGA bios update at all? If i update it, will it affect my raid setup? One reason why i have not updated. Thanks for any info. Sam
__________________
#16 |
Richard Swinburne
bit-tech Staff
Um, it shouldn't affect the RAID setup and if it does you should be able to go back in and re-initialise it.
NB: Should
#17 |
Minimodder
nice board,.. and for this one watercooler for BOTH pwms allready exsitst
![]() alu+plexi http://www.garageworks.de/bilder/hwluxx/kuehler.jpg delrin + cu http://img267.imageshack.us/img267/3196/imag0066xn4.jpg |
#18 | |
What's a Dremel?
hi there.. nice wb , can you tell me where i can buy then? send pm if you need |
#19 |
Minimodder
here are some more pictures of the new revision :
Delrin / Cu Andreoid |
| Thread Tools | |
