Thread Tools |
#1 |
Player Character
bit-tech Staff
PS3 apparently immune to over-heating
http://www.bit-tech.net/news/2007/08...over-heating/1
After surviving some rather severe stress tests, it seems that the PlayStation 3 is almost immune to normal over-heating issues. Well done, Sony!
__________________
#2 |
H to the U to the G to the O to the B
Get the hell away from my console with that flamethrower!!!
__________________
TrustedReviews.com - things I write about for a job |
#3 | |
Hypermodder
The cable has 2 layers of insulation ..... (and if it did get condensation there would be a big bang aswell) How can i get "too moist" ?????!?!?!?! |
| completemadness |
| View Public Profile |
| Find More Posts by completemadness |
#4 |
I Mod, Therefore I Own
Only 50C? That's hardly hot now is it when you consider that Athlon XP's would frequently idle at that temperature.
They need to wrap it up in layers of towels and let it bake itself and see how long it lasts then.
__________________
#5 |
Multimodder
49C ? you call that a sauna?? you cant even get sweaty there. normal sauna is usually 80-100C... then again, the sauna would probably have burned down after 108h of that kind of heat
![]() sony has done quite a good job tho. ![]() @completemadness maybe its not the wires themself but the plug/connector or what ever you call it. as for the sluggish performance, thats quite normal, my cellphone usually gets extremely sluggish when nowboarding with -17 to -35C although i think it might just be the screen itself
__________________
| -equilerex- |
| Find More Posts by -equilerex- |
#6 |
Multimodder
It was probably in the end of the connector where it connects to the system, plus insert materials in cables usually has a hygroscopic rating to tell how much moisture it attracts from the air around it.
#7 | |
Hypermodder
50oC was the ambient temp (the temperature of the air being blown onto the cooler) the Athlon XP would be way hotter than 50oC if the ambient was 50oC.The PS3 is only air cooled, thats pretty good going, a lot of PCs wouldn't stand up to it.
__________________
Into Gaming and around Bristol, UK, Click Here |
#8 |
Acrylic Heretic
I can personally attest to it's capability of whisking heat off. The thing gets hot! I'd say it was money well-spent on Sony's part for hiring those experts that designed the heat pipe system in the thing. It certainly exhausts toasty air, that's for sure. But that means the system is working correctly. I've let it fold for a couple days straight, not one hiccup.
__________________
Latest Builds: "Movie Sign!" CheckMate - MotM May '09 |
| E.E.L. Ambiense |
| Find More Posts by E.E.L. Ambiense |
#9 |
Madeira's banana is the best!!!
[hint]M$ FOR THE SAKE OF F*** MODIFY YOUR XBOX360 COOLER NOW OR YOU WILL FEEL THE WRATH OF THE GODS OF HARDWARE AND GAMING!!!![/hint]
PS3s cooling system is rather impressive.... the first time i saw it open i was all OMFG HUGE!!!!
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#10 | |
Acrylic Heretic
__________________
| E.E.L. Ambiense |
#11 | |
What's a Dremel?
( 49C ? you call that a sauna?? you cant even get sweaty there. normal sauna is usually 80-100C..!! ) D'uh... You will get burned or even get into a boiled meat to get into a sauna with 80 - 100 Celsius temp. You mean 80-100 Fahrenheit ..!! Primary School Dropout..!! |
#12 |
Multimodder
No Air Conditioning in the house so on hot days (35C outside) my room gets up to 45C. The fans on the PC switch to full, but it seems to handle it OK.
I wouldn't call that "extreme" conditions, but it is definitely higher than average temps, heh. Aggies |
#13 |
Multimodder
#14 | |
Multimodder
Excuse me, what? He seems to be from Estonia, and as he has the same kind of sauna habits as we Finns do, he isn't lying. I go into a sauna that's at 80-100C. It's not that bad, because it's so dry. If you didn't understand how you can survive in a sauna without getting burned, maybe you should actually check for some facts before you go out saying stuff you have no clue about. Thank you. [/ot] now: that ps3 is pretty impressive imo. 50 degrees celsius is about 25 degrees more celsius than the temperature that regular xboxses fail under, while idling/doing nothing. so yeah. well done on that one, sony.
__________________
the world is not enough, i gotta have modding too. |
#15 |
Supermodder
Wikipedia:
Under many circumstances, temperatures approaching and exceeding 100 °C (212 °F) would be completely intolerable. Saunas overcome this problem by controlling the humidity. The hottest Finnish saunas have relatively low humidity levels in which steam is generated by pouring water on the hot stones. This allows air temperatures that could boil water to be tolerated and even enjoyed for longer periods of time. Other types of sauna, such as the hammam, where the humidity approaches 100%, will be set to a much lower temperature of around 40 °C (104 °F) to compensate. The "wet heat" would cause scalding if the temperature were set much higher. But it's worth bearing in mind that the humid air of a sauna is actually somewhat more conductive of heat than might be considered normal. |
| Phil Rhodes |
| Find More Posts by Phil Rhodes |
#16 |
Spoon? What spoon?
while it might be immune to overheating, my friend's had an interesting failure about 2 weeks after it launched.
we heard a high-pitched whine, and then a bang. when we looked at the console, the radial fan had shed all of it's fins through the back of the case (through the aluminum heatsink) and the fins then lodged themselves in the drywall behind it. claymore V2.0 = PS3
| Bluephoenix |
| Find More Posts by Bluephoenix |
#17 |
Supermodder
Surely the colder a PS3 gets the faster it should go?
#18 | |
depends..... if something is made to run at a certain range of temperatures it will not run that great outside that range....
__________________
#19 | ||
Multimodder
#20 |
Hypermodder
Finally something positive for the PS3.......
I want to see competition! The 360 has the software, while the PS3 has the hardware.....now let's hope both consoles get the best of both worlds because we, the consumers, will win. |
| devdevil85 |
| Find More Posts by devdevil85 |
| Thread Tools | |
