RSS
Reply
Thread Tools View Mode
Old 16th Aug 2007, 14:21   #1
sethnmalice
Supermodder
sethnmalice's Avatar
sethnmalice is on a distinguished road
future ne[]n - 100% complete!!
So this is my current project I have been working on for the last month n a bit and still a W.I.P. (work in progress).
future ne[]n - futuristic styles with neon elements.
So without futher adue...
I gave everything a real good thinking over and made myself some plans, these plans are prototype sketches of the case, not everything you see is the final idea, everything is subject to change as the project progresses, but its a starting point for future ne[]n.
Front.
Side (subject to change)
Back.
And so begins the project.
I dont have alot of cash and I'm not the most expierienced person behind machinery, So, I decidedto consstruct the case from MDF first, so I could have a better attack plan when I upgraded to ALU.
Cutting it all out...
sethnmalice is offline   Reply With Quote
Old 16th Aug 2007, 14:21   #2
sethnmalice
Supermodder
Then I began to piece it all together making sure my measurements were pretty accurate and so forth.
Working out the DVD Rom tray...
I'm not overly happy with this concept, so I'll keep working on it...
I changed the front panel in these pics to compensate for the new concept of the drive bays, but reverted back to the original way later on but kept the concept idea for the drive bays.
Old 16th Aug 2007, 14:22   #3
sethnmalice
Supermodder
Came up with something like this...
Added the hard drive caddy in aswell (subject to change)
Then got to work on the front facia...
Lets see what it all looks like whacked together...
So thats the basic idea, and theres still a lot to do, and not everything you just saw will be used on the ALU version, this is just a prototype to help me understand things alot better, and also see if its actually achievable, because in some cases the dream is only a dream because one cannot achieve the impossible, I'm trying to achieve the possible
Old 16th Aug 2007, 14:23   #4
sethnmalice
Supermodder
Time to begin the ALU Version.
When working with MDF, you can cut corners so to speak, with ALU its a little bit different unless you have a Laser Cutter or CNC Mill in ur back pocket, well I had neither, nor the cash to make the frame one solid piece, so I improvised.
Not a bad effort.
And got to work on other bits n pieces...
Work on the Rear PSU 'eye candy' piece...
Test fitting some pieces to make sure my measurements are A-OK...
This is one of the ALU sheets I'm working with, its 1 metre square and i spent the day ruling out my lines....200 lines 1 cm apart, took forever to do..
Then I cut it all up and wallah, we have a front panel..
Did some more test fitting...
Back Panel.
Front Panel.
Old 16th Aug 2007, 14:24   #5
sethnmalice
Supermodder
Got my pccasegear order aswell, it consisted of 5 x 80mm quad red led fans, 5 fan grills (which i was going to re-mod n transform into swesome looking fan grills - but they messed the order up) so...(make my own was a better option - but thats down the track), and I got a fan controller aswell, this controller , controls 4 x fans @ 5 volt and 4 x @12 volt and also allows you to have 6 LEDS connected to it, perfect for the ne[]n side of the project (but thats a way away)
-This happened prior to the project commencing, but I was at the local Milkbar and saw something that i though would be perfect for a mod project.
We've all seen turbine fans - you know with the propeller nose on the front of the fan - looks pretty sweet, well, there was this candy thing, and the lid was made from clear acrylic, and wouldnt you know it, fits perfectly on a 80/92 and 120 mm fan, so I bought a few, and modded them to each of my new fans.
Thats the candy thingys in the background with the lids on them.
Now dosnt that look awesome....$2.00 lid and $6.50 fan.....modders bargin
So with my fans all looking pretty sweet, I needed a fan grill, so off i went to draw, and after a few days or so i came up with thse ideas...
I'm going to be using the one on top far right, as it suits my project perfectly, the others are for future mods.
So back to the build...
Time to put some of it together...
I also made a sub frame to re-inforce certain weak spots of the design
and rivetted the whole lot together...
30 rivets per side, total of 120 rivets just for this section, more rivets to follow.
Old 16th Aug 2007, 14:25   #6
sethnmalice
Supermodder
Now to begin work on the frame supports....
Using pre made corner pieces i just cut the size i wanted which was 12mm, same as the frame pieces...
Got a bit creative here.
Then rivetted the lot to the frame pieces...
All the frame pieces done...
Spent some time on the front panel, working out how things should be and lots of measuring and so forth, preparing for other parts that should arrive later on down the track...
Back to the ne[]n side of things, i rigged up some fans to see what they would look like with the propeller noses installed....here's some pics...
Old 16th Aug 2007, 14:26   #7
sethnmalice
Supermodder
I had to make 2 riser beams to match the rest of the case for the laying of the floor plate, so i spent the day doing that...
Then I thought id make myself a fan grill from ALU, but I have to say it didnt work out to well, here's a pic...
It dosnt look the best and I decided I would make it from acrylic as I prefer to work with it...
This is the net result of hours of work (4 hours of filing)...
Looks pretty cool if i do say so myself
Old 16th Aug 2007, 14:27   #8
sethnmalice
Supermodder
Right time to get this case together, but first lets add the PSU support...
Lets get those frame pieces put together...
Wohooo.....when youve gone from MDF to ALU, it just screams out at ya, and this did....beyond anything i could have imagined...
But lets not forget the prototype, I will still be using it, for top , bottom and side panels and anything else i can think of along the way...
T W I N - N E [] N S
I had to rebuild it, as i took some of it apart while templating certain parts...
Added corner pieces so now its all ready for the next stage - top , bottom and side panels and anything else ive missed.
I added in some extra support rails to the base of the frame, the reason for this is that under other configuration, the rivets woulld have been in the way of the sliding motherboard tray, this way they arent, although the rivets are now visible, but a cathode on either side would conceal them.
Floor Plate in and secured, also strengthened the overall case too.
Got to work on the DVD Rom 5.25 drive bays...
Going from the MDF to ALU version, things went a bit haywire and I didnt keep the original plans but went with a new idea, but simular to old idea...
I still have alot more to do, currently this is completely up to date, so today I have added in the front mesh so i can rivet the 5.25 bay in because once it goes in i cant manipulate my hands around to add the mesh later, bit of a bummer but thats the way it has to be, and also the top frame bars will be in place by tomorrow.
Ohh...almost forgot, finished one of the front fan grills too...
I hope you have enjoyed the read and the view thus far, feel free to add a comment to two, and I will be back in a few days with another update.
Cheers
Seth
Old 16th Aug 2007, 14:56   #9
karbonKid
Modder
karbonKid is on a distinguished road
Awesome project, will be keeping an eye on this.
karbonKid is offline   Reply With Quote
Old 16th Aug 2007, 16:07   #10
Matteh117
-LoGiSTiX-
Matteh117 is on a distinguished road
That looks frickin' awesome!
I've never seen someone plan a mod so well. I wish I could cut my own metal, but I'd never be able to do this much.
Good luck with the rest.
Matteh117 is offline   Reply With Quote
Old 16th Aug 2007, 18:11   #11
SPQQKY
Evil Modder
SPQQKY's Avatar
SPQQKY is an unknown quantity at this point
Nice work. If you don't mind me asking, what are you using to make your cuts?
__________________
I could be bounded in a nutshell and count myself a king of infinite space, were it not that I have bad dreams.
Core2Duo E8400 @ 4GHz - Gigabyte GA-EP45-UD3P - 4 x 2 GB G.Skill Pi Black-6400C4 - eVGA GeForce GTX 260 - Auzentech X-Plosion
1 x 250GB and 2 x 300GB Barracuda - LaCie 1TB BD - Corsair CMPSU 620HX - etc., etc.
SPQQKY is offline   Reply With Quote
Old 16th Aug 2007, 19:56   #12
Cheapskate
know-it-all b*stard...
Cheapskate's Avatar
Cheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud of
Wow... -and the way you posted makes it feel like you did it all in a day! I feel like I just got off a rollercoaster. Whoo! I'm gonna read it again!
I can't wait to see this finished, spinning-glow-nipples, and all!
Cheapskate is offline   Reply With Quote
Old 16th Aug 2007, 19:58   #13
Lupo_IM
ItaliaModding staff
Lupo_IM's Avatar
Lupo_IM is on a distinguished road
wow!!! great mod man!!!
__________________
not only 'Pizza & Mandolino'
Lupo_IM is offline   Reply With Quote
Old 16th Aug 2007, 20:06   #14
SPQQKY
Evil Modder
SPQQKY's Avatar
Except those candy covers aren't acrylic, most likely polyethyline or polystyrine, in which case they will yellow in the light in no time.....May want to consider painting them.
__________________
Old 16th Aug 2007, 21:26   #15
Cheapskate
Cheapskate's Avatar
My guess would be polyprophelene blend. They needed something that wouldn't stain red from contact with the... whatever the hell that stuff was.
Old 16th Aug 2007, 22:29   #16
SPQQKY
Evil Modder
SPQQKY's Avatar
Yeah, you know.......polyprofilacticalene........
__________________
Old 17th Aug 2007, 00:20   #17
Duste
Sierra my delta, bravo!
Duste is on a distinguished road
:O
I'm beginning to think this'll make it's way on to Bit-Tech's front page, amirite?
Duste is offline   Reply With Quote
Old 17th Aug 2007, 00:33   #18
dacust
What's a Dremel?
dacust's Avatar
dacust is on a distinguished road
No doubt!
__________________
-dan
My programs don't have bugs, they just develop random features.
WaterPlant worklog - in progress - Bit-Tech article - WaterPlant site - Home Page - PowerPlant PC - Designing
Don't worry about your english. This is an international forum. That's what makes it great. If I don't understand, I'll ask. Just MOD ON!
dacust is offline   Reply With Quote
Old 17th Aug 2007, 00:37   #19
Supra55
Banned
Supra55 is on a distinguished road
Yes you are I certainly believe its going straight to mod of the month. Definetly watching and voting for this one, Subscribed
Supra55 is offline   Reply With Quote
Old 17th Aug 2007, 02:55   #20
TNash
Supermodder
TNash is on a distinguished road
Wow! Really impressive. I like the fan cover designs. They're all really cool, and really well thought out!
TNash is offline   Reply With Quote
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
