RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Aug 2007, 14:02   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Chicks dig RAM
http://www.bit-tech.net/columns/2007...icks_dig_ram/1
Windows Vista has been labelled a resource hog by many and some think this is completely justified because Vista doesn't change the way we interact with our computers. Brett Thomas thinks that it's unjustified and looks back to when PCs weren't as powerful as they are today.
Tim S is offline   Reply With Quote
Old 19th Aug 2007, 14:32   #2
Veles
DUR HUR
Veles's Avatar
Veles will become famous soon enoughVeles will become famous soon enough
My gf keeps saying it just XP with a prettier interface and doesn't know the point of it. I keep trying to explain that there's more to it than that under the hood and she insists "it doesn't effect her" Probably because I'm not too great at explaining it as I've no idea of the inner working of an OS. But then again, there is the point that MS could be feeding us an inferior OS for all I know, we could have another ME. I doubt that's the case though.
I won't be buying Vista for now, I'm waiting to see how WinFS turns out, I heard they're adding it in SP1, I'm pretty tired of the folder system, it was fine back in the day when you had hardly any files, but now with the tinterweb, the amount of stuff the average user downloads is huge, and it's just not really a good way to organise files anymore. You either have one folder filled with everything, which makes it very difficult to find anything, or you have tons of folders to keep stuff organised, but you have the problem now that many files could go in different folders. That's one thing I like the sound of in OSX.
__________________
Veles on: Xbox Live (My Halo stats), Steam Community, Twitter
Originally Posted by Fod View Post
spam gangsters might as well tap into all those machines for their zombie networks.
Veles is offline   Reply With Quote
Old 19th Aug 2007, 14:40   #3
identikit
Ultramodder
identikit's Avatar
identikit will become famous soon enough
We 'tag' things online, why can't we do the same in our OS? Why does a file have to 'belong' inside a single directory? Why is there a desktop? I think software design has a long way to go.
identikit is offline   Reply With Quote
Old 19th Aug 2007, 14:43   #4
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I agree with what you're saying and you can certainly do that with Photos in Windows Vista... there's still a long way to go though.
Old 19th Aug 2007, 14:50   #5
Ramble
Ginger Nut
Ramble's Avatar
Ramble will become famous soon enough
I've heard nothing about WinFS in SP1, and it's more likely that Giuliani will forget about 9/11 than WinFS being shipped with SP1. The project is basically dead (although parts of it survive in MSSQL).
Maybe Windows 7 will have something similar to WinFS.
Why can't you just use the built in search..?
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back.
Ramble is offline   Reply With Quote
Old 19th Aug 2007, 15:05   #6
Fod
what is the cheesecake?
Fod's Avatar
Fod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of light
nicely written article, although a mention and brief explanation of superFetch (the thing responsible for 'hogging' RAM mostly on vista) wouldn't have gone amiss.
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D."
I'm a pretentious git with a camera.
ISPs want to spy on you. Join the fight against phorm
XBL/PSN/Steam ID: FodT
Fod is offline   Reply With Quote
Old 19th Aug 2007, 15:05   #7
identikit
Ultramodder
identikit's Avatar
Because (for want of a better word) it's crap. Why do we have to search anyway? Shouldn't everything be easy to find? Plus to find it you need to know it's name. Windows relies on the fact you know the names of your files and where they are. For instance your financial documents would probably be named finances_06-07^2.xlsl and be in a folder 'Financial' in 'My Documents'. Why? Can't we have tagged files, with dynamic tagging.
Maybe the OS could change as per user task? Not profiles per se, but Work/Play modes.
(Maybe Microsoft should hire me dammit!)
Old 19th Aug 2007, 15:08   #8
Veles
DUR HUR
Veles's Avatar
That's not the problem, I know where everything of mine is, it's just putting it there and clicking though all the folders (or typing in the overly long file path) is the problem. You've got to admit, after using something along the lines of Picassa2, the folder system seems like a horrible choice.
__________________
Old 19th Aug 2007, 15:23   #9
nemesis80
Modder
nemesis80 is on a distinguished road
if it wanted to get bigger and richer by peddling re-dressed start bars, it would be releasing them yearly (or at least bi-annually) instead of employing thousands of the world's best programmers to only release one effort after six years.
Ehrm, win ME?...
__________________
Asus P4P800 SE|P4 3.0E @ 3.6ghz |Utra 1536 mb PC3200 dual channel|Maxtor 80gb| Maxtor 120gb|Saphire X800 pro vivo-> xt pe @550/560|Artic Cooling V4|Thermalright xp-120|Lian Li pc-6077
nemesis80 is offline   Reply With Quote
Old 19th Aug 2007, 15:24   #10
Ramble
Ginger Nut
Ramble's Avatar
We do have tagged files, and the search (in Vista) searches that as well.
Have you used the search in Vista? It's miles better than Spotlight.
__________________
Old 19th Aug 2007, 15:47   #11
identikit
Ultramodder
identikit's Avatar
Yes I have (way back in RC1 days), looking at it now it looks like they've added some features. I'll have to find a demo PC with it on to see for sure. I can't remember it being contextual, as the results it served me back were always pants.
Old 19th Aug 2007, 15:57   #12
Phil Rhodes
Supermodder
Phil Rhodes is on a distinguished road
See, now, that's a really well written article. It doesn't, however, answer one fundamental question: if I were to go out and buy Vista tomorrow, what would I actually get out of it? Well, I'd get an OS that took slightly longer to boot, ran my applications slightly more slowly, used a lot more system resources, and didn't support a lot of my rather specialist video editing hardware.
Yes, Microsoft have a very serious problem, which is that there really isn't a lot of point in embellishing Windows further. It's a very mature, very capable piece of software - I'm no unqualified basher, believe me. I recognise the achievement of bringing (most of) the world's computers together under a common standard, and I recognise the difficulties necessarily presented to corporate ethicists by the fact that standardisation means that exactly one outfit gets to have all the money in this field.
But from my perspective, you're still being incredibly vague on exactly what I'd get out of it. Security, you say, somewhat vaguely. Well, since I have a quarter of a clue, I have never had serious security problems under any version of windows - I've seen exactly two virii, ever, both under win2k, and neither of which made it past AVG.
No. Really. What do I get out of it? There's people on this very forum comparing notes on exactly how little performance shortfall they've manage to achieve. That's some marketing effort from MS. Not only are people not screaming about the performance shortfall - they're actually proud of how much they've managed to minimise it. That takes some real brass neck.
Phil
Phil Rhodes is offline   Reply With Quote
Old 19th Aug 2007, 16:10   #13
quack
\o/
quack's Avatar
quack will become famous soon enough
What's a start bar? I don't think I have one of those! I have a start button and a task bar though.
__________________
Denying Rights to Music lovers.
Denying Rights to Movie lovers.
quack is offline   Reply With Quote
Old 19th Aug 2007, 16:20   #14
Veles
DUR HUR
Veles's Avatar
But look at the computer of John Smith, and you'll see them running a PC with Norton AV, and filled to the brim with viruses and spyware, people like us who can actually look after a PC are in a minority, most people thing their PC is just getting old, so they'll need a new one, when they buy the new one they then transfer the infected files over to that one, the cycle continues. MS don't make OSes for the tech heads, they make it idiot proof, an idiot proof OS is a very difficult thing indeed.
One point the article is making, is that back in the day when XP was released, people were saying exactly the same things, "this eats up too much resources", "this is only a fancy UI upgrade", "this runs everything like ****". All Vista needs, like XP, is time for the developers and PC hardware to catch up, once everything has settled down, and everything is working fine, and it becomes the standard, you'll stop hearing people complain about how much RAM it uses and how little of an improvement it is over XP.
MS weren't gonna keep slapping plasters onto windows 95 forever you know, otherwise they'd be like those chavs who stick a V6 into a Saxo, sure, it might be really powerful, but the chassis isn't designed for it, you'd have been better off saving your money and buying a proper car.
__________________
Old 19th Aug 2007, 17:25   #15
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Nexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud of
I wonder how many people who criticise Vista have actually spent some time with it... I have, and I must say that it certainly has a few improvements over XP in how the GUI works --and I'm not just talking about it looking pretty. It is actually a bit more intuitive to use.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"There is no Real Life, only Away From Keyboard" --gpw111
"...my wife says I can't have any trolls, cause they argue with the dog and eat the fish" --KayinBlack
Nexxo is offline   Reply With Quote
Old 19th Aug 2007, 17:32   #16
iwod
Minimodder
iwod is on a distinguished road
Originally Posted by Nexxo View Post
I wonder how many people who criticize Vista have actually spent some time with it... I have, and I must say that it certainly has a few improvements over XP in how the GUI works --and I'm not just talking about it looking pretty. It is actually a bit more intuitive to use.
All the way from beta till a few months ago I have been using Vista. There are a few things that it definitely improved and more intuitive to use. But those are very minor changes in my opinion and doesn't add up to its flaws. Control Panel ( Links Hell? ) And the new Start Menu are two of them.
Under the hood it is all good. Direct X 10, WPF, upcomig XAudio 2, better memory management etc. But UI wise i think it has definitely gone a step backward.
iwod is offline   Reply With Quote
Old 19th Aug 2007, 17:33   #17
Glider
/dev/null
Glider's Avatar
Glider has a spectacular aura aboutGlider has a spectacular aura about
Exactly... Most people spend too few time to make a conclusion. I myself tried Vista and liked it. Don't get me wrong, it's still not my cookie, but compared to XP it is a huge improvement.
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't
Glider is offline   Reply With Quote
Old 19th Aug 2007, 17:36   #18
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
you basically like vista because it justifies your way over powered PC, that prior to vista you were feeling slightly sheepish about the power consumption of? you keep saying that vista is better but why is it?
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 19th Aug 2007, 17:53   #19
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
I didn't buy 4GB of RAM to see 256MB used, nor did I buy a quad-core processor to see three sit idle and one sit at 20% load.
Quite right, but neither did you buy it for Vista, you bought it for gaming or video editing or so you could say that you have 4GB of RAM and a Quad core processor. Vista only needs 1GB, and will run on a single core processor with Intel Graphics
I have used Vista since RC1 and in general I am pleased, but then I don't mind having the occasional problem, and can usually sort them out. Vista is however a huge problem for the not so computer literate: my granddad bought a new computer with Vista and has had loads of problems, his printer wouldn't work, ViaVoice wouldn't work etc etc, and he had to bring it on holiday so I could sort it out for him. So IMO it is not ready for general release, or needs to have a prominent health warning on the box for people like him.
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is offline   Reply With Quote
Old 19th Aug 2007, 17:58   #20
KypD
Multimodder
KypD's Avatar
KypD is on a distinguished road
It's obvious Vista isn't just a pretty new face, but you assert that it's a GOOD thing to be taking up more resources, because it's pointless to have 4gb and use a tiny fraction. Now this is all fine and dandy, of course hardware's capabilities will expand exponentially, but the vast majority of users won't upgrade for QUITE some time. I don't want to install Vista on my current mediocre setup (3.0p4, 6600gt, 1.75gb) and then instantly have a more sluggish......everything.
For example: My friend's girlfriend purchased a new laptop about a month or two before vista came out. I forget the exact specs but it was a pretty swanky piece of equipment, and ran BF2 easily. She then took it somewhere to have Vista installed, and she HATES using it now. (she IS computer savvy btw) She doesn't hate it because of the GUI or functionality, but because it takes forever to even open internet explorer.
__________________
Well glory be, the funks on me, Bubba G;
Keep that funk alive!
Well uh, back in 1975, we're just trying to keep that funk alive.
Do that funk!
KypD is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
