RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 22nd Aug 2007, 11:45   #1
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
CardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to behold
Ken Levine responds to BioShock widescreen issue
http://www.bit-tech.net/news/2007/08...screen_issue/1
BioShock widescreen cropping got you down? Well then here, help yourself to the Levine-Apology Plasmid!
__________________
CardJoe is offline   Reply With Quote
Old 22nd Aug 2007, 11:48   #2
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul has a spectacular aura aboutBauul has a spectacular aura about
I bet you it gets fixed in the first patch.
__________________
Pentium 4 CPU 3.4 Ghz | 1Gb + 2x512Mb Corsair DDR2 667 Mhz
Sapphire Radeon HD 4770 512Mb| WD Raptor 36Gb, Seagate 300Gb | Asus P5LD2 SE
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 22nd Aug 2007, 11:51   #3
Phil Rhodes
Supermodder
Phil Rhodes is on a distinguished road
Well that's astonishingly easy to fix anyway, isn't it? Just wind up the FoV angle. Probably a one-line code change.
Phil
Phil Rhodes is offline   Reply With Quote
Old 22nd Aug 2007, 12:07   #4
Jamie
bit-tech Staff
Jamie's Avatar
Jamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of light
Nice to see a response, hopefully he will announce that they will not be changing anything.
__________________
bit-tech hosted by tsohost.co.uk
twitter | flickr | xbox live | last.fm | moot
Jamie is offline   Reply With Quote
Old 22nd Aug 2007, 12:15   #5
Ramble
Ginger Nut
Ramble's Avatar
Ramble will become famous soon enough
And I thought avatars were only meant to reach 85x85. For shame.
Hopefully they'll fix the bug.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back.
Ramble is offline   Reply With Quote
Old 22nd Aug 2007, 12:17   #6
K
say whoa
K's Avatar
K is on a distinguished road
That's a pretty negative reaction. It contradicts what the developers originally said about widescreen too.
A good fix would be the option to play in either FOV in widescreen, HOR+ or VERT-, it's a ridiculously simple fix either way.
__________________
15GB 3G iPod - 16GB 3G iPhone
24" iMac - 2.66 GHz - 4GB RAM - 640 GB HDD - 500GB WD MyBook - 40" Samsung M87
K is offline   Reply With Quote
Old 22nd Aug 2007, 12:24   #7
Jamie
bit-tech Staff
Jamie's Avatar
Don't get me wrong, I'm all for getting more FOV in the game but games don't make themselves and at some point there was a decision to extend vertically onto 4:3 and not to give widescreen more FOV than standard format.
__________________
Old 22nd Aug 2007, 12:29   #8
K
say whoa
K's Avatar
Before or after they confirmed the complete opposite?
__________________
Old 22nd Aug 2007, 12:38   #9
BioSniper
I Mod, Therefore I Own
BioSniper's Avatar
BioSniper has a spectacular aura aboutBioSniper has a spectacular aura about
There is a slight typo in the article;
Apparently, the game will display perfectly in 4:3 ration
May want remove the N on the end of ratio there.
__________________
My Flickr :: Bit-tech Flickr
Wii: 1792 1527 2926 7945 :: Xbox Live: BioSnipr :: PSN: Biosnipr
BioSniper is offline   Reply With Quote
Old 22nd Aug 2007, 13:12   #10
Vakuum
What's a Dremel?
Vakuum is on a distinguished road
I just hope they fix the AA issues in Vista so I can enjoy this game even more
Seems WinXp users are able to force AA on this game, but no luck for vista users as of yet in either dx10 or dx9.
Vakuum is offline   Reply With Quote
Old 22nd Aug 2007, 13:34   #11
Jamie
bit-tech Staff
Jamie's Avatar
I bet the confirmation came from someone who didn't know or didn't bother to find out what the developers had or were doing.
__________________
Old 22nd Aug 2007, 14:33   #12
Silver Shamrock
Banned
Silver Shamrock is on a distinguished road
The confirmation came from Chris Kline, a lead programmer. This has been pointed out to you in a previous thread and even says so in the actual article itself.
Silver Shamrock is offline   Reply With Quote
Old 22nd Aug 2007, 17:28   #13
wafflesomd
Hypermodder
wafflesomd's Avatar
wafflesomd is on a distinguished road
Who cares?
wafflesomd is offline   Reply With Quote
Old 22nd Aug 2007, 17:56   #14
mikeuk2004
What you Looking at Fool!
mikeuk2004's Avatar
mikeuk2004 will become famous soon enough
Originally Posted by wafflesomd View Post
Who cares?
Exactly
Everyone else, Shut up and play the dam game. Id be more worried if the game is a flop than the aspect ratio.
On another note. What does FOV mean? I hate all these abbreviations.
__________________
-|- Xfire - Mikeuk2005 -|- Xbox Live - Mike UK 2006 -|- Playstation Network - Mikeuk2004 -|-
mikeuk2004 is offline   Reply With Quote
Old 22nd Aug 2007, 17:57   #15
Jamie
bit-tech Staff
Jamie's Avatar
Yes because he has a good track record for being correct doesn't he.
Originally Posted by Chris Kline
Theres support for full scene Anti Aliasing and Anisotropic Filtering with HDR and Shader 3.0 on the newer graphics cards like the Nvidia 8000 series and the later Ati ones
Originally Posted by mikeuk2004 View Post
Exactly
Field of view
__________________
Old 22nd Aug 2007, 17:59   #16
Awoken
Gazing at the stars
Awoken's Avatar
Awoken is on a distinguished road
FOV - Field of view probably
__________________
Saving for a new desktop and laptop (Ooooh! Is that Windows Mobile 7 and Android 2 around the corner?)
Awoken is offline   Reply With Quote
Old 22nd Aug 2007, 18:03   #17
mikeuk2004
mikeuk2004's Avatar
ah, now I get you Cheers for clearing that up.
__________________
Old 22nd Aug 2007, 18:16   #18
ElZog
Defeater of Satan's Transformo Sofa
ElZog's Avatar
ElZog is on a distinguished road
It's the use of securom that is annoying me, rather than this problem which has already been fixed (a member of the 2k forums has apparently made a patch for it). I hope the anti securom patches come soon (from official or otherwise sources) as I really hate software like that when I am a legitimate owner of the game (securom limits the user to 2 installs of the game, including on the same computer if the OS is changed). Also I hear the limited edition DVD and soundtrack are really crap and many of the figurines are arriving broken.
Game should be awesome, but seriously, so many things have suddenly popped up today.
__________________
All those moments will be lost in time, like tears in rain.
ElZog is offline   Reply With Quote
Old 22nd Aug 2007, 18:20   #19
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
No, the issue has been responded to.
Basically this is what happens when you use securom.
Install Game -> Securom checks server -> Server says 0 have been installed -> Securom marks game as installed -> Servers record it as #1
Install game -> Securom checks server -> Server says 1 have been installed -> Securom marks game as installed -> Servers record it as #2
Install Game -> Securom checks server -> Server says 2 have been installed -> No more installs
Uninstall Game #1 -> Securom checks server -> Server says 2 have been installed -> Securom marks game as uninstalled -> Server goes to #1
Install on 3rd PC -> Securom checks server -> Server says 1 have been installed -> Securom marks game as installed -> Server records 2 installs
Basically it's 2 concurrent installs, you MUST uninstall the game before reformatting or upgrading hardware
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 22nd Aug 2007, 18:25   #20
Fod
what is the cheesecake?
Fod's Avatar
Fod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of light
that should probably time out after, say, 3 months...
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D."
I'm a pretentious git with a camera.
ISPs want to spy on you. Join the fight against phorm
XBL/PSN/Steam ID: FodT
Fod is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
