Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
IBM and TDK partner up to make MRAM
http://www.bit-tech.net/news/2007/08...to_make_mram/1
The memory type that replaces flash memory in many applications could be MRAM, which has been in R&D since the 1990s.
__________________
#2 |
Supermodder
Sounds very promising, once the storage capacities increase to more real-world requirements.
#3 |
Heathen
will be interesting to see how the power usage turns out as well esp if there are possible plans to replace hard drives at some point in the future. Of course power usage will also affect heat and as a result access speeds.
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever. |
| Almightyrastus |
| View Public Profile |
| Find More Posts by Almightyrastus |
#4 |
Spoon? What spoon?
I want to see how they plan to sheild against severe EMI and outside sources of magnetism.
if they can successfully do both then it might replace ECC memory in number crunching stations for CAD and the like, where the improved speed would lead to faster analysis times. |
| Bluephoenix |
| Find More Posts by Bluephoenix |
#5 | |
I pickle they
#6 | |
Supermodder
Interesting stuff! Good to see more alternatives to the old hard disk
![]() PS: noticed a typo in the last paragraph. Quote:
#7 | |
/dev/null
Faradays Cage to the rescue
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't |
#8 |
Hypermodder
I'm guessing that huge antiferromagnet (or whatever) has something to do with it not getting destroyed by EMR
| completemadness |
| Find More Posts by completemadness |
#9 |
Spoon? What spoon?
a Harddrive is not that sensitive to magnetism when on or off because you have to drag a magnet across the disc (or across the side to it for perpendicular recording) to realign the cells and create read errors. with the MRAM, any severe EMI could cause a bit change (and subsequent read error) based upon the design shown.
| Bluephoenix |
#10 | |
Hypermodder
Correct
| completemadness |
#11 |
Spoon? What spoon?
personally tried it with a half-dead disc, and it is indeed correct.
| Bluephoenix |
#12 |
Hypermodder
| completemadness |
#13 |
Spoon? What spoon?
I meant that I tried running a magnet at 90 degrees to the disc, on a half dead perpendicular recording drive, and more sectors turned up with errors.
so that would be me who's right. but you did have a point, which is why I resorted to physical testing in the first place!
| Bluephoenix |
| Thread Tools | |
