#1 |
Brett Thomas
Asus Xonar D2
http://www.bit-tech.net/hardware/200...sus_xonar_d2/1
Asus has hit the sound card market with all guns blazing, but should the mighty Creative start sweating as another computing behemoth lands the heavyweight Xonar D2 into the PC audio market?
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
Yehehehessss!
First!
Edit: But seriously. Good review. I remember being interested about this a while back. In the end though, since I'm no audiophile, integrated hd audio is fine for me. |
#3 |
Hypermodder
The Midi Inputs are a surprise to me.
__________________
http://img195.imageshack.us/img195/1466/goldie.gif |
| wafflesomd |
| View Public Profile |
| Find More Posts by wafflesomd |
#4 | |
What's a Dremel?
Any1 knows if NV will launch a SoundStorm again? |
#5 |
Sierra my delta, bravo!
Microsoft are trying to rid themselves of the red ring of death, and ASUS are trying to display it with arms wide open.
#6 |
Ultramodder
I think there is no more inventions and performance inmprovement to gain with any soundcards/onboard audio since about 5 years ago. In fact there is nothing improved/changed/different. They all perform the same, all have the same features and options. the 0,0004 % difference is not going to be heard by anyones ears. (not on pc speakers anyway) You can only see visual differences on the computergenerated graphs. (see! brand B is better then brand A, it has a 0,000001% higher spike in loudness graph) It is just gimmicks, kitch whatever you want to namen it. Like; orange/green/bloo glowing cards, gamer-names branding and the useless "plug-led-indicators" for your wirings, because you setup your speakers and let it be there for years unless you change a mobo, or are moving your gear to a new house whatever. But then its still useless, because why would you move stuff around in the absolute dark, hitting your head against anything under you desk, tripping over your officechair or some lost footpeddals from your racing steer...
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#7 |
THIS IS THE Best sound card I ever saw! **** Creative cards.. WOW I want one. DAM, Thanks so much.
__________________
GigaByte Triton 180|GigaByte EP45-UD3LR|Intel Q9450|Transcend 4GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|3TB WD Green The King Of CK Appreciation Society Group
| ComputerKing |
| Find More Posts by ComputerKing |
#8 |
Tories ftw!
Hmmm, not everything it was billed to be, maybe the encoding will be faster on the D3 version!?
Not entirely sure what to go for now, Bindi, from what you have said, it is a good allround card, but the Sondigio (sorry if the spelling is wrong) one sounds like it is just as good, but half the price (from what I have found after the googeling). Am I to take it that the Creative offerings are not worth it at all? As a casual gamer I am more concerned about movie and music quality, the games I just need to hear it and not get distorted, and from that view the Xonar sounds pretty good, but is there a better option for less? Because this looks pretty solid
__________________
Goose ![]() Q6600, Striker Extreme, 4GB 6400C4 Dominator DHX, Raptor X, 2x400GB spinpoints, BFG 8800GTX OC, Stacker 830 Evo, HX620, Nova T 500, Freezer 7 Pro Last edited by Mother-Goose; 3rd Sep 2007 at 13:57. |
| Mother-Goose |
| Find More Posts by Mother-Goose |
#9 |
Madeira's banana is the best!!!
that asus card is really pimp.... and those leds in the back really help
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#10 |
When did I get a custom title!?!
spdif was specificly designed for cheap fiber connections and 75ohm phono cable. Oxygen free cables are a scam, they have never been shown to be any better than non oxygen free cables (it's claimed that oxygen free is better as patches of copper oxide form diodes inside the cable and so the cable has a different impedance for one phase of the ac signal to the other producing distortion but this is complete BS). The included cables should be fine, most of the time spdif works without proper 75ohm cable anyway.
Regardless spdif is more of a consumer digital audio standard, the clock is derived from the data stream (to save money by just using two stand wire) and as such it's quite common to have the reciving device sensing the signalking level at the wrong time and thus getting incorrect data (thus distortion). I2S is a better standarrd and is what is used between cdplayer transports and their DAC's but I don't see any consumer cards with this connection standard (probobly because it would use the entire back plate up).
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#11 |
btw does this thing have linux support?
__________________
#12 | |
Hypermodder
__________________
| wafflesomd |
#13 |
Spoon? What spoon?
that 0,000001% percent can actually make a difference when you're outputting mixes at 2900 watts
![]() the midi is good, and I might get one because of that (more ASIO outputs! )
| Bluephoenix |
| Find More Posts by Bluephoenix |
#14 |
Multimodder
I have been looking around for a decent sound card that "LOOKS" good.. hehe.. might install one of these in the HTPC ... might not also.
Kewl review.
__________________
DiBRoM
#15 |
Richard Swinburne
bit-tech Staff
Not yet, but I've just spoken to Asus and the guy believed it was in the pipeline.
#16 |
Me!
I couldn't seem to tell from the pics and text. Where do you plug in the optical spdif?
Secondly: Does this board output surround over spdif optical? Did you test it with a surround reciever? Thanks
__________________
Quickr! Clickr to my Flickr! Canon camera stuff. Some aluminium PC, an HTPC and a MBP 17".. |
#17 |
Richard Swinburne
bit-tech Staff
I don't have a surround receiver but it does support it as well as Dolby Live and DTS:Connect.
The RCA jacks are dual jack with optical, the adapter for a Toslink is supplied in the box. |
#18 |
Multimodder
After I am doing reading the reviews on this soundcard and if everything is GOOD, you better believe that I will be ordering it as soon as I get some money in my hand. The hell with creative. they god some serious problems over there.
Thx for the Review! P.S. Fusion
__________________
CM Stacker 830 Case| Corsair 620HX Power Supply| Intel Core 2 Extreme QX9770 at 3.2GHz | Asus Maximus Formula SE Motherboard| 4GB G-Skills System Ram | EVGA 8800GT Graphic Card | Asus Xonar D2X PCI-E Sound-Card | Hauppauge HVR-1800 MC | 4 WD Hard-Drivers Total Storage 2.4TB | Logitech DiNovo Keyboard and Logitech MX Revolution Mouse (Air Mouse Coming Soon) | Logitech Z-5500 Digital Sound System | And So On...
#19 |
Hypermodder
Those backlit jacks are amazing, setting up under a LAN desk and at home is a pain in the arse!
#20 |
I Mod, Therefore I Own
no pci-e version?
| Thread Tools | |
