RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Sep 2007, 14:40   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Be Quiet! PC Noise Absorber Kit
http://www.bit-tech.net/modding/2007...absorber_kit/1
Is your PC too noisy? Tried everything from low noise fans to silent PSUs and quiet hard drives and it's still not good enough? How about a foam kit to cover the inside of your case as well!
Tim S is offline   Reply With Quote
Old 9th Sep 2007, 15:02   #2
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
So, If it weren't for the hole in the side of your case, do you think it would be any better?
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 9th Sep 2007, 15:05   #3
ComputerKing
ComputerKing's Avatar
ComputerKing is a jewel in the roughComputerKing is a jewel in the roughComputerKing is a jewel in the rough
mm I agree with this "prevention is better than a cure" as Bit-Tech said, Because this thing make the case ugly.. And why waterproof! Who the idoit will wash his computer with water! It's useless thing really... This is my view and my thinking..
Thanks BT for the review.
__________________
GigaByte Triton 180|GigaByte EP45-UD3LR|Intel Q9450|Transcend 4GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|3TB WD Green
The King Of CK Appreciation Society Group
ComputerKing is offline   Reply With Quote
Old 9th Sep 2007, 15:13   #4
capnPedro
Deaf forever to the battle's din
capnPedro's Avatar
capnPedro has much to be proud ofcapnPedro has much to be proud ofcapnPedro has much to be proud ofcapnPedro has much to be proud ofcapnPedro has much to be proud ofcapnPedro has much to be proud ofcapnPedro has much to be proud ofcapnPedro has much to be proud of
there's moisture in the air. If it's not waterproof, you can get mould growing in it.
These kits aren't totally useless. My HTPC was quiet. Real quiet; 1 Coolink SWiF-801 (7v) (9dB) and 1 Noctua NF-S12-800 (10v) (<5dB). In an attemp to get it quieter, I cut up one of the "egg crate" foam tiles you glue to walls for a recording studio or whatever and stuck in in my case. It made a noticeable difference in reducing the fan noise (or at least 'bouncing' it out the back of the case, instead of the front). It didn't affect the HDD noise, though. Different pitch/frequency I guess.
So in my experience, the foam works. But only under limited circumstances. So, £20 is a bit much, but £4, like I paid is more like it. It looks like crap though, I wouldn't want it in a case with a window.
__________________
ASUS M4A785TD-M Evo | AMD Phenom II x4 955 BE | D-Tek FuZion
4GB Corsair XMMS3-10666 | Corsair TX650
Point Of View 8800GTX | EK FC-8800
capnPedro is offline   Reply With Quote
Old 9th Sep 2007, 15:15   #5
Mankz
ITS OVER 8000!
Mankz's Avatar
Also, I'd actually be quite interested in some of the blue stuff.
Old 9th Sep 2007, 15:19   #6
Zut
Multimodder
Zut is on a distinguished road
From the article...
A CPU might not reach 75ºC but we've just last week recorded the temperature of PWMs on a Shuttle motherboard in a new XPC hitting 100ºC!
A new XPC eh? Can we expect a review of the SP35P2 next week then?!
Zut is offline   Reply With Quote
Old 9th Sep 2007, 15:24   #7
atanum141
I fapped to your post!
atanum141's Avatar
atanum141 is on a distinguished road
Fantastic exactly what ive been looking for coz the Akasa stuffs not enough and pricey.
__________________
Welcome to Thunderdome, B*tch
XBL: atanum141
atanum141 is offline   Reply With Quote
Old 9th Sep 2007, 15:28   #8
ComputerKing
Oh right, Thanks for clear this to me
__________________
Old 9th Sep 2007, 15:29   #9
Spacecowboy92
Gettin' Lazy
Spacecowboy92's Avatar
Spacecowboy92 is on a distinguished road
One day, I'll fill the hole in my Aurora with Acrylic. I rember I asked in the modding section before about Noise absorbtion foam and you basicly said the same, fans, hard drives and heatsinks first. Not for me I think.
__________________
Spacecowboy92 is offline   Reply With Quote
Old 9th Sep 2007, 15:36   #10
p3n
Hypermodder
p3n is on a distinguished road
Might be interesting to see if you can drown out HDD's in one of those zalman passive cases for a completely silent PC
p3n is offline   Reply With Quote
Old 9th Sep 2007, 16:20   #11
Bluephoenix
Spoon? What spoon?
Bluephoenix's Avatar
Bluephoenix is on a distinguished road
if nothing else it makes for a nice internal finish, might use some of this for sound deadening when I'm running on silent setting, or as an interior backdrop for the components when on display.
Bluephoenix is offline   Reply With Quote
Old 9th Sep 2007, 17:38   #12
Loggitt
What's a Dremel?
Loggitt is on a distinguished road
You should have asked me about it, first. I used the Akasa stuff several years ago. It did absolutely nothing to reduce noise, but made my case's inside temperature (motherboard temp) just keep rising and rising as the hours wore on. The junk absorbs heat and doesn't dissipate it out through the side of the case it's glued to. Bummer! Even though I have no experience with the currently reviewed product, after reading your review, I won't recommend it, nor would I use it. Like you stated (thank you), once it's on, it's on forever. Unless, of course, you like to torture yourself! LOL
Loggitt is offline   Reply With Quote
Old 9th Sep 2007, 18:11   #13
g3n3tiX
Resident frenchie
g3n3tiX is on a distinguished road
Originally Posted by Article
it's all strawberries and waffles
cheesecake ?
Good product seconded by an apparently good manual.
Interesting buy, I'd say. And I like the way it looks like when done. The Dark matting is cool !
__________________
I also have a MTBF.
g3n3tiX is offline   Reply With Quote
Old 9th Sep 2007, 18:17   #14
Spacecowboy92
Gettin' Lazy
I used the ghetto elastic band mod on my harddrive. Completly silent now, exept for the rest of the computer that is.
__________________
Old 9th Sep 2007, 19:06   #15
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
So how much difference did it actually make? In my computer, fans are the biggest noise producer (but thats because I have a cheap case and cheap fans and it has a window)
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is offline   Reply With Quote
Old 9th Sep 2007, 21:48   #16
Irvine
Multimodder
Irvine's Avatar
Irvine is on a distinguished road
I suspended my hard drive with an elastic band, and it made a HUGE difference, quite honestly. I built my latest rig for silence, and I thought it was quiet, until I later suspended the hard drive. Apparently, the hard drive vibrations carry through the case and essentially amplify them, so removing the source of the vibration will remove the case vibrations.
__________________
abit IP35 Pro|E6600@3.3|7900gs@585/780|2GB Corsair DDR2 800|WD 250GB|X-Fi XtremeGamer|Zalman VF-900|Modded Zalman CNPS9500
Irvine is offline   Reply With Quote
Old 9th Sep 2007, 22:19   #17
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
TR, yes.
Bindibadgi is offline   Reply With Quote
Old 10th Sep 2007, 00:15   #18
cpemma
Ecky thump
Moderator
cpemma's Avatar
cpemma is a glorious beacon of lightcpemma is a glorious beacon of lightcpemma is a glorious beacon of lightcpemma is a glorious beacon of lightcpemma is a glorious beacon of light
Just for info,
Originally Posted by SPCR
The brand name (Be Quiet!) appears to be owned by Listan GmbH und Co. KG of Germany, which also distributes other computer component brands such as Cooler Master, Arctic Cooling, Zalman, AeroCool and MB/Papst fans. It also offers a line of products such as fans, cases, case accessories, water and air cooling, and cables under the name of Revoltec (Revolution Technology). The brand appears to be fairly well distributed in the EU, but not in North America, where search engines turned up no retail visibility.
Their PSU seems to be genuinely low-noise, modular too.
__________________
Nobody's perfect.
But being a Yorkshireman is as close as you can get.
cpemma is offline   Reply With Quote
Old 10th Sep 2007, 03:57   #19
wafflesomd
Hypermodder
wafflesomd's Avatar
wafflesomd is on a distinguished road
I'd buy it.
I'm looking to silence my pc anyways.
wafflesomd is offline   Reply With Quote
Old 10th Sep 2007, 11:34   #20
Xir
Supermodder
Xir's Avatar
Xir will become famous soon enough
Heh...Heheh...Heheheheh-HAAAA!
I knew the seventies were returning in furniture design, but now the nineties are returning to Bit-Tech ;-)
1998 we spent getting dual-celeron boards to run and overclocking them and having to cool them with like 10 40-60mm fans. (yeah, we were grateful for 80mm fans back then.)
1999 we spent soundproofing the things because they quickley became unbearable. I must've fitted about 6 cases with the stuff you show here. (or was it in 2000?)...and many others with cheaper alternatives...carpet, insulating sleeping mats, bitumen roof covering (essentially the lower 2 mm of your test mat only stickier)
My start into modding, really ;-)
Eventually we (I) learned, soundproofing:
makes more heat makes more cooling makes more noise makes more soundproofing andsoonandsoon. Also makes for heavy cases (back then when to play in a network, we actually had to get together)
Leaves 2 possibilities:
a) Live with lower power: Noise is best canncelled out by avoiding it in the first place, this means usually avoiding dual garphicscards, 10.000rpm harddrives and overclocking.
b) Live with decreased portability: Go for watercooling, maximum power at low noiselevel.
Xir
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C
Xir is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
