RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Sep 2007, 11:56   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
PC Audio 101
http://www.bit-tech.net/bits/2007/09/12/pc_audio_101/1
The MP3 is by far the most popular way to listen to music on your PC, but it's not the best way. We have a look at lossless audio and explain how to get the most out of your music.
Tim S is offline   Reply With Quote
Old 12th Sep 2007, 13:01   #2
The_Pope
Geoff Richards
Moderator
The_Pope's Avatar
The_Pope is on a distinguished road
Windows K-mixer needs to resample and otherwise mess with the original sound to before sending it through to your sound card. Chances are, if you’re playing CD quality audio (44kHz), Windows is resampling it to 48kHz, processing it (volume, balance, tone, etc) then resampling again back to 44kHz and sending it to your sound card.
I don't mean to be funny, cos I'm a bit of a n00b when it comes to this sort of thing, but after reading the above statement I had just one question: why? I *do* understand why this sort of technique is a bit rubbish, but I don't understand why it does it, especially since there are ways to avoid it doing it.
The_Pope is offline   Reply With Quote
Old 12th Sep 2007, 13:10   #3
neonplanet40
Supermodder
neonplanet40's Avatar
neonplanet40 is on a distinguished road
I cant find the ASIO drivers for the X-Fi Fatality. Anyone know where to get them? The search engine on creatives website is woeful.
Neon
__________________
Home Entertainment =Sony Bravia 40V3000, Onkyo 605, Playstation 3 and Acoustic Energy EVO NEO 5.1 Speakers
My System=Asus P5K Premium, Pentium Core 2 Quad @ 3200Mhz (everyday use), 4GB OCZ Goldlines, 74GB Rapter and 320GB WD, XFX 8800GTS Overclocked, Enermex Liberty 620W, Auzentech Prelude 7.1, Akasa Eclipse-32,Samsung 22" Widescreen LCD
neonplanet40 is offline   Reply With Quote
Old 12th Sep 2007, 13:38   #4
Seraphim Works
Multimodder
Seraphim Works's Avatar
Seraphim Works is on a distinguished road
Alas, if only I had the money for a low cost setup, denon amp and a couple of b&w bookshelf speakers....
Damn you Joshua Moore, now I'll end up trying to get a new audio setup as well as upgrading the pc!
__________________
From a 4.0Ghz P4 to a 3.3Ghz Q6600, thank god for price wars...
Seraphim Works is offline   Reply With Quote
Old 12th Sep 2007, 13:47   #5
stoff3r
Multimodder
stoff3r is on a distinguished road
so my integrated soundcard has both optical and coaxial digital outputs. whats the word on those? will the sound become "lossless" in terms of computer-interference and crappy windows decoding? i am planning to send the signal to my amp but haven't got around to what cable to buy...
stoff3r is offline   Reply With Quote
Old 12th Sep 2007, 14:23   #6
yakyb
CK is God!!!
yakyb's Avatar
yakyb is on a distinguished road
well im still using winamp2.93 and i have to say im not all that impressed by it (i only use it because its quick) ill check out foobar when i get home
__________________
Gaming Box:: q6600 @3.0 :: 9800gtx :: Abit IP35 :: 4gb :: 1.4TB :: akasa eclipse :: Win7
Development:: PhenomII 955BE @3.2 :: 4200 :: asus M4A785 M Evo :: 1.25TB ::Win7
Media Centre :: q6600 @3.0 :: x1950pro :: asus p35 epu :: 8gb :: 320 GB :: Lc17B :: Win7
server:: I7 860 :: p55 gd65 :: 3450 :: 8 TB :: 8gb :: Rebel 12 :: server 2008 R2
yakyb is offline   Reply With Quote
Old 12th Sep 2007, 14:25   #7
Bogie
Banned
Bogie is on a distinguished road
I remember having ASIO drivers up before on an old creative X-Fi driver. Now they are nowhere to be seen.
Anyone have any ideas how to get ASIO working on X-Fi cards?
I have X-Fi Elite Pro?
Bogie is offline   Reply With Quote
Old 12th Sep 2007, 14:27   #8
Bogie
Banned
PS. Anyone know any good foobar skins and where to get them please?
Old 12th Sep 2007, 14:31   #9
Bogie
Banned
Am gonna try these:
http://www.asio4all.com/
Old 12th Sep 2007, 14:36   #10
Bogie
Banned
Didn't work.
Old 12th Sep 2007, 15:07   #11
Bluephoenix
Spoon? What spoon?
Bluephoenix's Avatar
Bluephoenix is on a distinguished road
The ASIO drivers are built into the manager software with everything else.
simply set it to audio creation mode and it will change the handling to ASIO, which you can then use with the winamp plugins (then play FLAC and rock all night )
note however that only the X-Fi Platinum and X-Fi Elite have the ASIO drivers built into the manager software, the Fatality had that removed to lower the cost compared to the Elite
Bluephoenix is offline   Reply With Quote
Old 12th Sep 2007, 16:01   #12
wharrad
Hypermodder
wharrad's Avatar
wharrad is on a distinguished road
Not quite sure on the technicalities within a soundcard (does the sound get passed through a DAC, processed and then back through a DAC) but that 'should' be the best option. However, you'll then need to spend a good amount of money on an external DAC before your amp/speakers to simply get back to the quality you would have had just using the onboard DAC. Of course though with some cash an external DAC will be better... Just depends on how far you want to take it.
Oh, and people tend to state that CoAX is the better option for a digital out.... Although if the sound is passed digitally I'm not completely sure why!!
Regarding the article, congratulations! You need stones to write that... Out of all fanboy, over the top arguements I've been part of, audio always generates the most 'debated' forums!
Personally like an external Amp and bookshelf speakers on the desk over anything with PC Speakers written on them, but I'll always state that you'll never get the same quality out of a computer than you will from a good CD seperate with a brick on top. There's simply too much going on electronically in a computer. In fact, last time I was looking for a hi-fi that could be classed as in a 'sensible' budget I remember audiophiles telling me about how the circuit boards are even 3 degrees out of plain to reduce interference!
As one piece of advice I give to anyone thinking about getting better sounds from a computer - check Richersounds (if you're in the UK) and just see if you can get a basic amp and bookshelf speakers for the same price of your 'Obber loud fau1it3y edition 7.1 pc speakers'. Yeah the amp take up more space... but really not anymore than a sub and 5 other mini speakers. I'll also shave my entire body if a 7.1 set sounds better - even for movies (no comparing a 20 year old Amstrad to a 7.1 Mordaunt-Short system just to see the shaving please!).
On the otherhand however, you already have a computer if your on these forums, and so a large part of the cost is already spent and articles like this are a great way to introduce people into the audio world, who would have otherwise missed out.
__________________
Jimmy Carr - "It's easier to get forgiveness than permission"
wharrad is offline   Reply With Quote
Old 12th Sep 2007, 16:03   #13
Renoir
Multimodder
Renoir is on a distinguished road
I believe from my reading that it's due to the fact that windows mixes together all the audio streams being played on the pc e.g. music, windows sounds etc and so needs to get them all to the same sample rate. In addition I'm not sure the article was right when it said kmixer resamples from 44.1-48-44.1. I believe it merely resamples from 44.1 to 44.1. Josh am I totally wrong? In addition creative cards have traditionally resampled all 44.1 content to 48 due to the audio processor not supporting 44.1 streams natively. Not sure if that still applies for the X-Fi (think it does but is done better due to more horsepower) but it was one of the big advantages of cards based on Via envy chipsets due to them not resampling 44.1 content to 48 but rather they just sent the 44.1 straight to the dacs.
Using onboard digital per se will not avoid the kmixers resampling and in addition many onboard codecs have traditionally resampled from 44.1-48 much like the creative cards mentioned above (again not too sure about the latest codecs?)
Hope that helps
Renoir is offline   Reply With Quote
Old 12th Sep 2007, 16:07   #14
maha_x
What's a Dremel?
maha_x is on a distinguished road
WOW
Had to register just to comment... Now I was familiar with foobar before but not asio and wow, I can tell the difference clearly now between foobar and winmediaplayer on my logitech Z3 speakers which are not exactly hifi...
I read that the audigy has quality problems cos it allways has to go internally to 48khz, so going from 44.1 to 48 was bad cos of the small difference. So now I can directly upsample to 24/96 that has plenty of detail for upsampling. Standard windoze audio sounds clearly muffled now...
Thanks alot for this info!!
maha_x is offline   Reply With Quote
Old 12th Sep 2007, 16:07   #15
Rocket733
Austerity - It's the only way
Rocket733's Avatar
Rocket733 will become famous soon enough
Great guide for a beginner in computer hi-fi. Another low cost usb dac option is the silverstone EB01; while not as high end as the 0404 it does a great job for about $80 (us).
Rocket733 is offline   Reply With Quote
Old 12th Sep 2007, 16:30   #16
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
After saying this: "A few upgrades and tweaks down the line, all of my music is ripped in lossless, and in nearly all cases, the difference between 320k MP3 and FLAC is apparent" I feel I'm forced to ask you for some setup-details. I have some doubts about anyone hearing the difference, and atleast I like to hear on what kind of setup do the differences appear?
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 12th Sep 2007, 17:18   #17
RTT
bwarp
Moderator
RTT's Avatar
RTT is a jewel in the roughRTT is a jewel in the roughRTT is a jewel in the rough
Welcome to bit-tech
__________________
This post is non-negotiable. All terms and conditions apply.
Arguing on the internet is like competing in the special Olympics. Even if you win you're still a retard.
RTT is offline   Reply With Quote
Old 12th Sep 2007, 17:36   #18
Bluephoenix
Spoon? What spoon?
the one best thing to do with any soundcard is to mod an EMI shield onto it.
I did it with my X-Fi (was an absolute pain) but ultimately worth it.
the best soundcard for those who don't want to deal with a lot of external gear is the X-Fi platinum. set it to ASIO mode (to avoid all the processing that can cause artifacts) and use the playback methods outlined in the article.
as for those asking if their MP3 will become 'lossless' quality by using external equipment, the answer is no. MP3 is MP3 and as such will always sound like crap.
Old 12th Sep 2007, 18:25   #19
pendragon
I pickle they
pendragon's Avatar
pendragon is on a distinguished road
i'm in the 'can't hear a difference' camp, so i'll be happy to stick with the MP3/onboard audio for now...
however, I would like to also recommend ExactAudioCopy ..great program.
pendragon is offline   Reply With Quote
Old 12th Sep 2007, 19:08   #20
hughwi
Hypermodder
hughwi's Avatar
hughwi is on a distinguished road
well Josh, I would just like to say that having recently upgraded both my hi-fi equipment and my computer audio equipment in my latest step up the audiophile ladder, it is great to read such a well presented, thought out and ultimately unbiased (excepting the alliance to foobar, EAC and FLAC which make sense) article. I have been using foobar and ASIO to play my music for a while now (ever since i upgraded my speakers) however i did not know about EAC, and can i just say it eats my old CD ripper for breakfast! I can now clearly tell the difference between one of my albums ripped in FLAC and mp3, wheras before i went back to 192kb/s mp3 as i couldnt hear the difference over FLAC. I guess now i am going to have to go out and purchase a new 500gb monster hard drive to store all my FLAC on!!!!
hughwi is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
