#341 |
Pump Killer
Damn... So many ppl to thank for the nice responce, so I shall do this in one single sitting!
![]() Thx a lot guys, you all made it worth the while to go this far with this mod. As of now, I'm taking some days off the mod, to get the love back for it! But it will be back, and I will continue this "G5 Retaliation"! And also thanks for the birthday-messages! It was pretty cool, relaxing with family and friends, though I'm not really a fan of celebrating my B-day...
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#342 |
What's a Dremel?
Waterblocks
The waterblocks look good but wont cool any better than a good air cooler! The reasons are laminar flow & the boundary layer. When the water enters the block the water molecules will fill in all the microscopic holes in the copper surface thus creating a boundary layer. The boundary layer is a thin wall of water that won’t move & will affect cooling performance. As water is far less efficient at conducting heat than copper you need to create turbulence in the water as it flows through the block. This will eliminate the boundary layer & increase performance. You can do this by adding pins to the block base. This will not only create turbulence it will create more surface area for the water to flow over & dissipate more heat. You also need to think about how the water will exit the block. The best positioning for the outlet is in the corner. You want the water to contact as much copper as possible so it can cool to its maximum potential. You also want to reinstate laminar flow as it exits the block. The faster & smoother it can exit the block the better. This is the reason the D-Tek fusion is so efficient. Study its layout & you will know what I mean. As you used a manual mill it will be difficult to create pins so you could machine cups in the base to create turbulence or you could create jets for the water to flow through before it hits the block base. Try to position the inlet barb over the centre of the block for maximum contact with the CPU die. These are the reasons why I buy my blocks instead of making them myself. I have access to a manual Milling Machine as a friend of mine has one in his home workshop along with a lathe & many more amazing tools. I could make my own but it would take a hell of a lot designing, time, thought, testing & money. You cannot just make a block & use it, it has to be tested so tweaks & improvements can be made. I am starting a Business later in the year selling hard to find in the UK water-cooling hardware as well as building custom pcs & cases. I will also be selling custom Fan & Radiator grills cut to the customers own design. I would also like to do powder coating & custom painting but I will wait until my business is doing well so I can invest in the equipment. I might then consider making water blocks but I will be employing engineers for this. I would never consider selling a Block until it can at least equal or beat the performance of the best blocks on the market. I don’t mean to criticise your block I am just trying to help you make it better. Anyway enough said as it will probably be bed time by the time you have finished reading this post.
#343 |
Acrylic Heretic
. And all that coming from someone with a post count of 1. ![]() I'm only pokin' fun.
__________________
Latest Builds: LilyPC - in progress • BIO-A10 - MotM Jul. '12 |
#344 |
Pump Killer
Markpg28 <-- Thx for the nice description...
I was actually under the assumption that it had most to do with the surface inside the block... But when that's said, I am in no way thinking of making these for sale or anything else... But one thing is a fact... My E6420 is stock at 2,13 Ghz, and is currently running @ 3,3 Ghz overclocked. With the OEM fan that came along with it, it ran at about 50 degress centigrade on both cores @3,3 Ghz. With the blocks I made, it is currently running @ 22 degrees centigrade on both cores, and the water temp is @ about 24 degrees. I doubt that a fan, even a really good one, would get those temps. And I would love to see you make one of those blocks on a manual mill... I made them on a cnc!
__________________
#345 | |
My E6420 idles @ 27°C on both cores overclocked to 3,2 Ghz cooled by a zalman 9700NT.Lovely project you got going there btw
__________________
| Lian-Li PC-A08 | E6420 @ 3,2 GHz | Asus Radeon HD4890 | MSI P35-Neo | Corsair HX750w | 2TB | 4GB Corsair XMS PC2-8500 |
#347 |
Pump Killer
Very small, might even call it minute, update!
![]() So it seems I got the time, and the spark for modding, again! And even if it's a small update, it's a start! ![]() I have been thinking about the side of the G5, and how it's gonna look, and now I know! You will see it in due time, but here's a sneak preview of how the led's for power and Hdd-activity will look! Right now I use the standard led for power, but that's on the front of the case, and the only thing you see on this case, is the side, hence; I will move it! I will also need to put the display for the watertemp in the side, and since it's black and boring, I'll reconstruct the front, to match the led-thingys! ![]() The display as is/was: The Led-thingys, made of aluminum and plexi, polished: Sry, I find it hard to get a good picture! ![]() How they will roughly sit next to each other, I milled most of the front off the display, to make sure it will flush with the led's, when I create a aluminum frame for it: That's it for now, if nothing else happens, I'll be back tomorrow with yet an update!
__________________
#348 |
Android-x86 User/Modder
Ohhh cant wait to see how it is going to look... Well i hope the update will come before freday af 14 o clock becouse after that time i have 8 hours of travel to get to denmark and woud be nice to see how the frame to the display will look..
__________________
Crazy dane, gotten home from the cold. |
#349 | |
Is the daddy!
i think you need to look at the internals of the blocks again, the water is broken up by many edges inside the block. Angel OD, its coming together nicley, go on give us another update!
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#350 |
Pump Killer
I'm baaaaack!
![]() As promised, another update, but a small one though, didn't have much time, and things tend to take more time than you think! At least, more time than I think! ![]() And since I started out in a stupid way when making the frame for the temp display, it took about an hour to get it done! But here goes: A piece of 3mm aluminum, milled to 2mm (was to lazy to go cut some 2mm ), and the sides milled to a 23 degree angle:Done, mocked up, just on the backside of the panel: One more for the road: BTW, take a look at the surface of the whole panel, I messed it up trying to polish it, so I just sandblasted the whole thing (without the frame and lip) and you see the result! Actually came out pretty well, it even looks like the frame! A friend is comming by for the weekend, so I dunno if I'll have the time to mill the holes for the display and the led-thingys tomorrow, and next week is vacation time! But time will tell when the next update will be!
__________________
#351 |
The Keeper of History
Check me on this? Top of the door above the latch slide pieces and display towards the front, then buttons?
![]() John
__________________
My deepest gratitude to this community.
#352 |
Acrylic Heretic
Angel, that bevel for the screen looks sooo nice. I'd love to have access to that equipment you use, but that goes without saying... Awesome!
__________________
#353 |
Pump Killer
Jhanlon303 --> I'm not sure if I understood you right M8... I'll try to go through this...
You, of all people , ofcourse know how the side looks on the G5, and the pics show the inside! The stuff will be mounted on the outside, since the case is sitting "sideways" under my flatscreen... But they are not buttons, they are just a nice way to mount leds for the power, and for hdd activity! I hope this answered your question? If not, you will find out on next update! ![]() E.E.L. Ambiense --> Thanks M8... I aim to please! (As I tell women... ) But you're quite right, it's pretty cool to have access to the machinery, funny I never thought of using it for modding before I stumbled over this site!
__________________
#354 | |
Acrylic Heretic
__________________
#355 |
↓ Don't trust that face!
Hmm,
-LED plugs: -custom bezel: ![]() -Sand blasting: ![]() -Crazy guy post: Is this the guy that was scamming people claiming to sell watercooled laptops? The only thing that post lacked was a threat to sue you for using his ideas!![]() This thread really does have everything now!
__________________
#356 |
Pump Killer
E.E.L. Ambiense --> I know what you mean...
Expecially since I've been a "nerd" the last 12-13 years... But on the other hand, I've had good use of knowledge/machines/ideas since I started as an aprentice in 1998! And I know a lot of ppl who've been very happy that I do what I do! I know this is off topic, but hey! This is my thread! LOL Just a couple of things I saw while looking around in my appartment!: The sofa table, I made it from a 30mm mdf, milled 4 pices of stainless steel in to it, and integrated 3 tealight holders into it... And btw, it weighs about 80 pounds! lol A pair of dices, made from aluminum with brass inserts... And yeah, they need a good polishing, they're 8 years old or something like that! I've made billions of pieces of stupid stuff... ![]() This also includes the audio systems in my cars! Which is probably the craziest things I've done!
__________________
#357 |
Pump Killer
Cheapskate --> LMAO!
Watercooled laptops? Hmm... If it wasn't for the fact that my laptop is owned by my workplace, that would surely be my next project! I just got about 1500$ back from the tax-people, but I have another mod in mind for most of that money, so no laptop in sight to be watercooled! he he... I know the sandblast will darken, but luckily it's on the inside of the sidepanel! I would have give it a clearcoat, if it was on the outside! BUT!!! Be aware! If you sandblast an area that size, and only on one side, it WILL bend the material! I'm sorry I don't have any pics of it, but I'm not kidding when I say it was about 10 mm bend, from end to center! And stainless steel is even worse! So I had to straighten it out by hand! Btw... If he would have threatened me with a lawsuit... I would have just told him I live in a country where THAT is not possible!
__________________
#358 | |
Now... with more CNC!
Outstanding work man! I really love the way this is coming together.
__________________
#359 | |
John
__________________
#360 |
Pump Killer
jhanlon303 --> OMG... I haven't really done anything to the metal itself, apart from cutting the plate which holds the cd-drive and Hdd's... But I didn't experience anything like that... But then again, I had it on a saw, with everything sort of clamped down, so I wouldn't get any surprises...
I know what you mean! But a modder will never park! (as we both know!)
__________________
| Tags |
| case mod |
| Thread Tools | |
| View Mode | |
