Reply
Thread Tools View Mode
Old 13th Dec 2010, 20:05   #581
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
Originally Posted by Angel OD View Post
The_Gnu <- To be honest, my girlfriend has come to the thought that she want's a watercooled modded PC as well, sometime in the spring next year, so it's probably not the last blocks I have ever made!
I'm not sure what you mean about the PSU. I have no idea if the rails were live or not. All I know is that they are no longer, as it is dead as a duck!
Yay for your girl.
Regarding the PSU. Most PSUs often have one of the power lines (240/110V) through one of the Heatsinks, making it "live", while the other is grounded. Therefore if you would put a piece of metall or your fingers on both of them while the PSU is running... ZAPP!! fried. You mean you didn't check this before you put that block on there?.. in that case you were lucky. Cooling a "live" heatsink can also make a short through the water line and damage other parts.
The PSU you used, do you remember what brand/model?
Nice work with the polishing
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 13th Dec 2010, 20:14   #582
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.
Damn... Never really thought of it like that... It makes good sence, and it might have been pure luck nothing more happened! And maybe the fact that the fluid was mostly non-conductive helped.
Just goes to show you learn every day!
The PSU is/was an Energon EPS-550w.
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 14th Dec 2010, 16:14   #583
Angel OD
Pump Killer
Angel OD's Avatar
Just a small boring update.
Got the top and bottom of the reservoir done today!
A couple of pics of the drilled channels. Inlet and outlet.
Inlet - top:
Outlet - bottom:
Both in beautiful harmony:
Got the day off tomorrow, going to pick up the last of the X-mas presents, and scavenge for a couple of things for "The Catalyst"
Hope to be back thursday with a bit more!
__________________
Old 29th Dec 2010, 14:34   #584
Angel OD
Pump Killer
Angel OD's Avatar
C**P in a box...
I finally got around to mounting the waterblocks on my newly bought 780i!
CPU Block on:
NB/SB and Chipset on:
Only a small problem... The pc didn't boot - Well, the gfx fan just went 100% power, and stayed there... While I was pondering why, I saw small sparks from between the chipsetblock and the 2 resistors to the right of it...
And that was apparently the end of that board...
But fear not my little ones, I just got a great deal on a Zotac 790I Supreme with some nasty OCZ memory!
It works fine, and now I'm in the designfase of doing new waterblock for it. I shall return strongly soon, it's just cold as hell at the workshop, as they shut down the heat between xmas and newyears eve.
I shall leave you with a picture from X-mas eve... Fine lights, wrapped in snow!
__________________
Old 29th Dec 2010, 15:09   #585
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
Want more I still dream of the day when you finish this:P
__________________
p0Pe is offline   Reply With Quote
Old 29th Dec 2010, 16:12   #586
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Ouch! Sorry to hear you killed a board. It looked damned good, though.
Res is looking wild. What have you got planned for the center?
Cheapskate is offline   Reply With Quote
Old 29th Dec 2010, 17:58   #587
ringo
Supermodder
ringo has yet to learn the way of the Dremel
I like your small self made reservoir and the different types of waterblocks. They looks very good.
ringo is offline   Reply With Quote
Old 29th Dec 2010, 19:23   #588
Angel OD
Pump Killer
Angel OD's Avatar
pOPe <- So do I m8... So do I!
Cheaps <- Not sure I understand what you mean, with "planned for the center"?
Could you by any chance mean what goes between the top and the bottom pieces?
If so, I'm making a copy of my old res, so I shall have 2 standing next to each other, on top of .... "The Catalyst" ... Running black liquid through 1, and purple through the other!
The Catalyst will be revealed soon!
ringo <- Ty sir, always nice with a pad on the back!
__________________
Old 22nd Jan 2011, 18:37   #589
Angel OD
Pump Killer
Angel OD's Avatar
It's that time again.
Sorry for the lack of updates, but life and just general feelings of not knowing where to start, has left me down for a while.
But I made a 101 testbench for my stuff to sit on while modding the case and just for general modding, as it takes ages to pull it apart and putting it back together.
But I think I am back for the long run the next couple of weeks at least!
For starters, A little pic of a couple of things that are in the works:
The bottom for the dual res, the tops for dual res, dual pump top, and the chipset cooling block... All sitting on my very unique and beautyful testbench.
The testbench and the hardware in all it's glory:
Let's get to it. The dual pump top - baby pic.
Dual pump top - Milled:
And please remember, the edges that look torn, are not! It's just the protective film.
A better view of the angle:
And one for the road:
I had to figure out how to mount my radiators in the wooden frame I'm building, and after a lot of ideas, I came up with the solution I'm going with now.
There will be 4 pins mounted on the frame, for each radiator. Then you kind of just plug the radiators in on those pins. Kind of difficult to explain. A small pic to hopefully give an idea:
The little mouting pieces, glued on the rads:
I had to make a stencil to make sure they would sit exactly where I wanted them, when I glued them on. It kinda worked, they sit within 0,2 mm of where they are supposed to!
I think that's it for now. Unfortunately I havn't had time to test the pump top, as I forgot it at work...
If time is willing, I might get some more done tomorrow, and get to test it.
__________________
Old 23rd Jan 2011, 12:14   #590
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
That's looking fantastic Angel! and this has to e one of the sexiest acrylic pictures yet
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 23rd Jan 2011, 13:45   #591
Angel OD
Pump Killer
Angel OD's Avatar
Ty very much Editor22!
I just found a small fabrication flaw in the pump top... No inlet hole!
Luckily that's a minor setback!
Should have time to stay late after work tomorrow, and get some stuff done!
__________________
Old 24th Jan 2011, 07:38   #592
fluxtatic
Supermodder
fluxtatic has yet to learn the way of the Dremel
Originally Posted by The_Gnu View Post
Yay for your girl.
Regarding the PSU. Most PSUs often have one of the power lines (240/110V) through one of the Heatsinks, making it "live", while the other is grounded. Therefore if you would put a piece of metall or your fingers on both of them while the PSU is running... ZAPP!! fried. /snip
Maybe that explains why I've never seen a w/c'd PSU. I always thought that would be a good idea, since that's one of 'last frontiers' of w/c'ing. That is, it's one of the only parts that needs a fan on it, even in a fully w/c'd box.
Just the same, Angel, please figure out how to do this, so I can steal the idea
This is awesome, keep it up!
fluxtatic is offline   Reply With Quote
Old 24th Jan 2011, 16:42   #593
Angel OD
Pump Killer
Angel OD's Avatar
fluxtatic <- Sorry, but I'm done with messing with PSU's for the time being! Sick and tired of them!
But on a different note, I almost finished the bottom for the dual reservoir today.
I know, I know, picture or it didn't happen!
In all it's glory, still sitting in the mill. Just threw in one of the bottom parts of the res itself, to give an idea how it will end up:
Did a quick assembly of one of the reservoirs, again, just to see how it will look... Still some holes missing, but not a long way to go on that.
That's it for today. Tomorrow I am occupied elsewhere, but wednesday should bring yet an update! Enjoy, and mod on!
__________________
Old 26th Jan 2011, 18:09   #594
Angel OD
Pump Killer
Angel OD's Avatar
Well, I promised you an update, and here it is!
I finished the setup for the dual reservoir, and the 2nd res.
The other that fits in there, is sitting beautifuly and doing it's job on the rig as we speak. So it's just a matter of disassemble, and assemble:
Got the last holes punched in the dual pump top:
And---- I got a great start on the Chipset block for the 790i:
Setup on a block for milling:
The paper on top, is just a 1/1 scale copy that I glued on to make it easier to cut it out before milling...
Somewhere in the proces:
End of the cnc-milling part - Still needs some work, hoping to get it done tomorrow!
Soooo... Until tomorrow, I shall bid thee farewell.
__________________
Old 26th Jan 2011, 20:45   #595
masterchief9615
PC builder / Modder
masterchief9615's Avatar
masterchief9615 has yet to learn the way of the Dremel
Looking good!
__________________
CPU: Intel i7 930 @ 4.2GHz Motherboard: ASUS Sabertooth X58 RAM: CORSAIR DOMINATOR 6GB Power Supply: Cooler Master Silent Pro M 850w Storage: 74GB Raptor + 1TB Storage GPU: EVGA nVidia GTX 460 @ 900MHz Watercooling: CoolIT Vantage ALC System
masterchief9615 is offline   Reply With Quote
Old 27th Jan 2011, 10:05   #596
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Just awesome stuff Angel. I've been looking and learning.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 27th Jan 2011, 20:26   #597
Angel OD
Pump Killer
Angel OD's Avatar
Masterchief9615 <- Ty very much.
Attila <- Coming from you, that might be the greatest compliment I've ever received in here! With the mods you've acomplished, I doubt very much I can teach you anything!
But thanks a bunch sir!
Tomorrow is friday, and I should get some more done, and the cooling tower "The Catalyst" should be further on it's way!
__________________
Old 27th Jan 2011, 21:15   #598
Editor22
E22.BIZ
Editor22's Avatar
Always so impressive to see your CNC work Angel will we ever see what you use it for on a normal day?
__________________
Store: E22
Old 27th Jan 2011, 21:26   #599
Raiden
Portuguese reviewer
Raiden's Avatar
Raiden has yet to learn the way of the Dremel
Impressive work !!!
Keep the updates coming..
Raiden is offline   Reply With Quote
Old 28th Jan 2011, 12:49   #600
The_Gnu
8-bit addict
The_Gnu's Avatar
You are making some really nice pieces as always. You really makes me wanna go and give pleximachining a try, looks fun.
I was wondering about the reservoir top and bottoms, have you been polishing them or did you use a perfect cuttingspeed to produce that nice finish. In this picture I mean:
*EDIT Sorry.. I saw you posted the answer to my question on the previous page. Anyway.. greate results. Keeptt it up
__________________
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
