Old 24th Sep 2007, 00:01   #1
crazydeep74
Hypermodder
crazydeep74's Avatar
crazydeep74 has yet to learn the way of the Dremel
My Mac
I have a apple computer. I need to unzip .sit files for it, but the only problem, I need to be able to install the expander off of a floppy disk and work with Mac OS 8.1
crazydeep74 is offline   Reply With Quote
Old 24th Sep 2007, 03:24   #2
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has yet to learn the way of the DremelFirehed has yet to learn the way of the DremelFirehed has yet to learn the way of the Dremel
What's the question here? Are you looking for a stuffit expander that's compatible with 8.1?
I think, if that's the case, then it's a bit of a stretch today. The easiest route would be to copy the files that need to be extracted to a 10.3/10.4 system that has The Unarchiver installed, extract, then copy them back over. Unfortunately I don't really have a better solution for you, but you're not going to find much that'll run in 8.1 today.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Reply
Tags
apple
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
