#1 |
Pewlius Caesar
bit-tech Staff
MSI P35 Diamond
http://www.bit-tech.net/hardware/200..._p35_diamond/1
MSI's P35 Diamond features the same CircuPipe cooling system as the P35 Platinum, but comes with a few added features like a PCI-Express X-Fi, a SkyTel Skype card and DDR3 memory. Do these ingredients create a better board than the Platinum?
__________________
#2 |
Stopp the Relix guy
you can't use this motherboard without a graphic card?
some special fans in the circuit heatpipes would have been nice quite much PCI slots are used if you trow everything in which is in the box
__________________
Gaffa-Tape is a very simple modding device ![]() <sings>I'm from AUSTRIA</sings>and NO we have no kangaroos ![]() Microsoft NEVER stopped the beta phase of any of its operating systems i will not apologize for my language skills |
#3 |
Ultramodder
Is it just me or are most of the higher class motherboards coming short of expectations, and not worth it when you consider price?
#4 |
VGChartz PR Manager
this is supposed to be a high class motherboard? im not impressed.
__________________
http://thebladeclan.com |
#5 | |
So Say We All
wholly crap crossfire 1600*1200 is an incredible boost.
__________________
Hell hath no fury like a hippo with a machine gun.
#6 | |
Pewlius Caesar
bit-tech Staff
I think the problem for most high-end boards at the moment is making the choice between DDR2 and DDR3 - if you head into the realms of DDR3, you're going to be classed as expensive because that's exactly what DDR3 is. There's no way to get around that.
__________________
#7 |
So Say We All
correct me if im wrong (i must be) but wouldnt 16 * 4 (total of 20) use more pci express lanes then 8 *8 (total of 16)
__________________
#8 | |
Pewlius Caesar
bit-tech Staff
__________________
#9 | |
Richard Swinburne
bit-tech Staff
So Crossfire data has to navigate and fill the DMI between NB and SB, unlike X38 which is all connected to the NB so the whole thing should be lower latency. |
#10 |
So Say We All
edit: ingnore
__________________
#11 |
So Say We All
edit: ingnore
__________________
Last edited by Woodstock; 25th Sep 2007 at 12:20. Reason: grr whyd it post then again |
#12 | ||
So Say We All
i see said the blind man to the deaf monkey
__________________
| Thread Tools | |
