RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 2nd Oct 2007, 14:01   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Update: Windows Update update breaks updates
http://www.bit-tech.net/news/2007/10...eaks_updates/1
The stealth update to Windows Update last month managed to break something - the ability to update Windows after using XP's recover feature.
Tim S is offline   Reply With Quote
Old 2nd Oct 2007, 14:05   #2
Ferret
What's a Dremel?
Ferret is on a distinguished road
We need a windows update uptate update!
Ferret is offline   Reply With Quote
Old 2nd Oct 2007, 14:08   #3
oddball walking
oddball walking's Avatar
oddball walking is on a distinguished road
Or an updated update, which reminds me my updates aren't up to date.
__________________
oddball walking is offline   Reply With Quote
Old 2nd Oct 2007, 15:39   #4
leexgx
CPC hang out zone (i Fix pcs i do )
leexgx's Avatar
leexgx is on a distinguished road
lol
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947
leexgx is offline   Reply With Quote
Old 2nd Oct 2007, 15:57   #5
Drexial
Supermodder
Drexial is on a distinguished road
windows updates updates are never up to date as they should be updated to keep the updates up to date.
Drexial is offline   Reply With Quote
Old 2nd Oct 2007, 17:06   #6
gvblake22
mmm, yep
gvblake22's Avatar
gvblake22 is on a distinguished road
Words can hardly describe this situation, so I'll do it with little pictures courtesy of bit-tech...
gvblake22 is offline   Reply With Quote
Old 2nd Oct 2007, 19:57   #7
Buzzons
Mod Master
Buzzons is on a distinguished road
What's wrong with this, they fixed the issue within a DAY! That is good going. There are bugs in some things that remain unfixed for months/years/forever (oracle!)
Updates to the update engine are perfectly fair, you would want the latest one when you decide to get updates etc. (Also, only users with "non legit versions" of windows will have it disabled at home.. offices would uses SUS servers.. so that isn't an issue here)
Buzzons is offline   Reply With Quote
Old 2nd Oct 2007, 21:41   #8
completemadness
Hypermodder
completemadness is on a distinguished road
Originally Posted by Buzzons View Post
oracle!
I love how you say oracle has bugs that last forever/long time
But most of the "non-critical" bugs in windows takes months, if not years to get addressed
I guess the only reasons this was fixed so much is that it breaks a fixing solution for windows XP (which is pretty important for a MS OS) and because after the anger at the update happening, forcing a bugged piece of software on people would have caused an uproar
completemadness is offline   Reply With Quote
Old 2nd Oct 2007, 21:45   #9
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Uh...oracle DOES have bugs that seem to last forever...dunno if you really ever used it, but yeesh.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 2nd Oct 2007, 22:43   #10
GoodBytes
mother into a board?!
GoodBytes's Avatar
GoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of lightGoodBytes is a glorious beacon of light
1- I'm confused, the article talks about winXP or Vista. I see a Vista screen shot.
2- WinXP reparation is crap. It usually creates more problem than it repairs (form my experience) and takes the SAME TIME (close the the minute) then doing a fresh re-install including formating and re-installing yourself all the applications and doing the updates.
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro!
GoodBytes is offline   Reply With Quote
Old 2nd Oct 2007, 22:43   #11
woodshop
UnSeenly
woodshop's Avatar
woodshop is on a distinguished road
i never wana see the word 'update' again...
woodshop is offline   Reply With Quote
Old 3rd Oct 2007, 07:30   #12
completemadness
Hypermodder
I'm just saying, hes bashing oracle when you can bash XP/Vista/MS on topic!
Old 3rd Oct 2007, 07:37   #13
Edvuld
Multimodder
Edvuld's Avatar
Edvuld is on a distinguished road
I guess you don't have that many programs installed then... It's a breeze for those of us that sits a whole day or two configuring all the installed applications ><
__________________
[Done] Beyond The Grave
[Done] Temple Of NOD
Supposed to be Homepage
Edvuld is offline   Reply With Quote
Old 3rd Oct 2007, 12:25   #14
GoodBytes
GoodBytes's Avatar
38 applications installed (just counted).
__________________
Old 3rd Oct 2007, 19:19   #15
Edvuld
Multimodder
Edvuld's Avatar
Ok, I had about 71 of them, anyways, I'm picky about everything and all settings beeing "just right", so it takes me at least a good 8 hours setting everything up on my normal system.
With windows repair I could even exchange the mainboard and CPU without any problem at all, and it'll only take maximum 2 hours total to get the drivers installed and win repaired
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
