Thread Tools |
#1 |
Brett Thomas
Seagate releases new hybrid drive
http://www.bit-tech.net/news/2007/10...hybrid_drive/1
Many of us have been looking forward to the hybrid drive - part NAND flash memory, part platter drive. Seagate has finally delivered its offering, aimed at the laptop segment.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
I'm not a modder.
Shame they are not doing the Barracuda 7200.11 in sizes less than 500gb, it would be nice to have one as a boot drive instead of the Raptor i have been dreaming about.
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#3 |
The Froggy Poster
What's wrong with a half TB bootable? They're cheap...
Sadly, the .11's are pretty difficult to find atm - for us Canucks, NCIX has the 750s and 1Ts - but no 500s yet. They have the PSD's too... but all special order.
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
#4 |
Officious Bystander
--Fixed, thanks! - Da Dego
__________________
Demand Naked DSL in the UK! |
#5 | |
I'm not a modder.
__________________
#6 |
mother into a board?!
I heared the end results of this hybird drive disappoint:
http://www.dailytech.com/Seagate+Hyb...rticle9195.htm
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro! |
#7 | |
Brett Thomas
Remember how we are always talking as consumers about cramming more benefit in the same power envelope? Well, you could use that flash to speed up the drive but keep the battery life constant, or you could recognize you're working on a laptop drive and try to keep performance the same while bringing down power draw. Seagate chose the latter, and personally I think it was a wise decision.
__________________
#8 |
Multimodder
The initial reviews I've seen of anything related to the "ready" technologies haven't really impressed me TBH. Brett have you got a link for the battery life savings you mention? Would be interested to know what the "true" bottleneck is to performance with flash based technologies like Readydrive and readyboost. Is it the speed of the flash, the amount of flash, the OS Drivers or something else? I have no doubt that hybrid drives and SSDs will play a key part in the future of storage so will be interesting to see how the market develops.
#9 |
CPC hang out zone (i Fix pcs i do )
the size of the flash is to small to make much performance or batt life
it at all when the OS is heavy and bloted (it work wunders on XP tho 128mb boot the rest for other programs if it was supported) the cache on the disk needs to be 1gb to start off from and 2gb if you want the hdd to stay not spinning for longer times as thats what haveing flash on the hard drive is for so the hard disk can stop spinning for longer and save power 256Mb or 1gb can not do that with 2gb of flash on the disk that you will find optons for hard disk power down more offen as well the Flash is faster access times then an laptop hdd and the Flash can have faster data rates then the laptop disks more so when there is random access going on (0.2ms flash / 10-15ms hdd with an Masive impact on file random read performace) its more an problem with the hard drive Vista ReadyDrive cant work well at all with 256mb of flash its likey trying to run vista with 512mb of ram its to small to be usefull unless vista ReadyDrive uses it for Small files Only like it does for rederyboost (usb sticks)
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947 |
#10 |
Hypermodder
I still don't understand this tech
How is constantly starting/stopping the drive going to help anything, id rather have less battery life then my HDD dieing after a year |
| completemadness |
| View Public Profile |
| Find More Posts by completemadness |
#11 |
Hypermodder
that's just it, due to the solid-state flash holding the most accessible/needed data the HDD is accessed less, which in turn draws less power and less noise
I just wish they bring an SSD out for desktop usage.....faster read/write times for OS's and games if there's enough flash memory available.....I seriously can't wait..... |
| devdevil85 |
| Find More Posts by devdevil85 |
#12 | |
Mod Master
How would these work in raid?
My new Toshiba X200 lappy should arrive tomorrow and just for shits n giggles I was planning to put in a couple SSD drives in raid 0. Only problem with that is HUUUUGE cost (and I'm currently a poor student ).So if you could use these in raid to combine the cache it would be handy. Can't see it working though since the raid controller basically makes the two drives appear as one. Would be interested in knowing for sure though.
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64 Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF. Quote:
#13 |
6 screens / 1 card
What's the life expectancy of the flash portion (under heavy use)? What happens if / when that part (with limited read / write cycles) dies? The extra level of cache is interesting but how safe is it? Those are the questions that would keep me from buying. Could they use a DRAM module instead?
__________________
It's not about how life treats you, it's about how you treat life. |
#14 | |
Hypermodder
And when it gets asked for something not in flash (or when the flash is full of stuff to write) the disc has to be spun up - and that has to mean the disc will be spinning up and down all the time, which must wear it out pretty fast |
| completemadness |
#15 |
I *am* The Stig
flash mem is too small to do anything
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
#16 |
What is a Dremel!?
Moderator
The Flash memory isn't meant to hold all your data. Why do you think hard drives have cache in the first place?
The Flash holds only frequently accessed data - the core files of the operating system for example, or any other files you might have open. When most people use laptops they tend to do one thing for a reasonable period of time, such as write a Word document or browse the Internet. 256MB of cache is enough to hold any files that are frequently accessed during these activities and eliminate frequent referral back to data on the platters of the hard drive. Also, sorry to be a cpemma ( ), but the article should read "waiting with bated breath" rather than "baited".
__________________
"Nothing is more practical than a good theory" - Kurt Lewin |
#17 |
Modder
OK so it's perhaps not enough for Vista, it's perfect for XP, but how would this affect much smaller operating systems? I'm running DSL on an old laptop that sorely needs a new HDD to drag some life out of it! Performance isn't an issue at all, it's only used for dull stuff, but a little more battery life never hurt, and it'd be something worth salvaging if the thing died!
#18 | |
Mod Master
Do you need drivers to make the drives work properly?
ie, will it work in Linux and XP etc or does it need Vista's new cache-boost type stuff? Also, can you manually control what goes in there? You might want to put specific things in there to make it faster for what you want to do rather than what the system thinks you might do. ie, games etc. And anyone know the answer to the previous question about RAIDing these?
__________________
#19 |
You need Vista to take full advantage of it. under XP or other OS it might work, but just as a normal HDD.
__________________
| Thread Tools | |
