Thread Tools |
#1 |
Player Character
bit-tech Staff
Intel demos mobile quad-core CPU
http://www.bit-tech.net/news/2007/10...uad-core_cpu/1
Intel kicked off IDF Taiwan with a bang by introducing a new mobile quad-core CPU and two new mobile computing cooling technologies
__________________
#2 |
glourious bacon?
Third para - "The cooling system is based off of compressor technology" - replace with 'on'.
Next person who uses 'off of' gets pushed through an infinite portal. Very interesting tech!
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#3 | |
Officious Bystander
While 45W may be impressive for a quad core CPU, it is hardly frugal in the context of mobile CPUs. And a phase change cooled laptop?! Welcome to the future where you need a car battery to power your laptop for more than 5 minutes.
__________________
Demand Naked DSL in the UK! |
#4 |
Internet Addict
1) What's wrong with "off of". Obviously by asking this, I am not a grammar Nazi. It seems perfectly common place to me.
2) Regarding the battery life, wouldn't you be able to disable the extra cores when you didn't want to use them to conserve power. I mean if you're just sitting in a restaurant posting on a message board or typing up your homework assignment, you don't need all four cores. (Well maybe for Vista? ) But seriously, I thought that dual-cores could already toggle between using one or both-- Surely using just one or two cores would put the battery life in a comparable field to what's already on the market. Please correct me if I am wrong!
__________________
-- Faulken S. Wulf "Under the Willow, he sleeps and dreams, of Heaven." Attempting to post intelligently since the year 2000! |
#5 |
Minimodder
So it's a laptop with a dumbed down phase-change cooling system? Anyone else think that's absolutely awesome?
| drakanious |
| View Public Profile |
| Find More Posts by drakanious |
#6 |
Minimodder
sounds totally sweet, hope they will get it out for sale soon..
#7 | |
Officious Bystander
(2) I don't know. To be fair, the latest generation of Intel processors is phenomenally power efficient compared to what came before, and I understand that they have very low power states and each core can to a limited extent power parts of itself down independently of other cores. However, each core, even in idle state, still requires some juice, so you will definitely not get the same battery life out of a quad core laptop as you would from an otherwise identical dual core running the same tasks. That having been said, you will get more processing power so processor intensive things will happen more quickly, and the difference in battery life on non-intensive tasks might not be too horrendous.
__________________
#8 |
...like a geek!
Moderator
I'm thinking: 45W quad-core CPUs in a desktop. Two of them still would generate only the same amount of heat as a standard quad-core CPU now... nice.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "There is no Real Life, only Away From Keyboard" --gpw111 "...my wife says I can't have any trolls, cause they argue with the dog and eat the fish" --KayinBlack |
#9 |
a.k.a KazeModz
honestly its a laptop, sure the idea of a quad core is neat but is it really needed??? I prefer portability and battery life then being attached to a power plug still, if I wanted that then I would build a PC or buying one of those over priced gaming (desktop replacement) laptops which Im sure is where this core is aimed at but even still not for me.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
#10 |
Traditional Nutter
As much as I enjoy high performance laptops where I can do serious work and play real games away from my desktop, manufacturers really need to work on the overall size. For example, the latest Dell XPS M1730 is bigger and far heavier than my M1710, which is already heavy enough and moving away from my extremely portable HP laptop was a mission itself. Sure, they have SLi and PhysX but carrying a laptop almost as heavy as my weekly Sainsbury shopping isn't what I call... portable or convenient.
Just over 2 hours battery life on my M1710 vs my 4 hours battery life on my old HP and with a 130ish watt power requirement on the M1710, even an in-car charger struggles or refuses to work on it at times. Manufacturers need to look up the meaning of the word laptop
__________________
I'm always wrong until proven right! ![]() Q9450 | Striker II Extreme | Corsair 4GB DDR3 | XFX GTX 280 | Lian Li PC-75 | Corsair HX1000W Auzentech X-Fi Prelude | Logitech G15 / G9 / Z-5500 | 4x Samsung 750GB & 4x Samsung 1TB | HP LP2475W Dell XPS M1710 T7200 | 4GB DDR2 | 7950GTX | 320GB HDD - Apple MacBook T8300 | 4GB DDR3 | 9400M GS | 250GB HDD |
#11 | |
Hypermodder
| completemadness |
| Find More Posts by completemadness |
#12 |
quad fuelled, GTX200 powered
can i put it in my LGA775 and overclock it?
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
| Thread Tools | |
