Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 17th Oct 2007, 02:24   #1
speedfreek
Ultramodder
speedfreek's Avatar
speedfreek has yet to learn the way of the Dremel
Transfering Steam Saved Games?
What is the best way of transferring your saved games from one computer to another? I have all my games beat but all on different computers and I don't want to play all the way through all my games on each computer I play on.
What I want to do is copy my saves in HL2, EP1, GMod, and all the others to my laptop so I don't have to run through it all again, its not that I don't want to but I don't have the time.
So what files need to be moved and where, I tried doing it before but unsuccessfully.
__________________
Q6600 | HD5870xxxUBERversion | 6gb of RAM | Several TBs of hdd
now my server|Athlon 64 3700(2.64ghz)|7800gs|2gb XMS 2-3-3-6|2tb+ total HD space... In raid|I have a problem.
Laptop: HP EliteBook, its fast!
speedfreek is offline   Reply With Quote
Old 17th Oct 2007, 03:07   #2
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has yet to learn the way of the DremelFirehed has yet to learn the way of the DremelFirehed has yet to learn the way of the Dremel
Copy the files in the following dir, or something equivalent:
C:\Program Files\Steam\steamapps\EMAILADDRESS\portal\portal\S AVE
C:\Program Files\Steam\steamapps\EMAILADDRESS\half-life 2 episode one\episodic\SAVE
etc
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 17th Oct 2007, 04:39   #3
mrlanrat
Multimodder
mrlanrat's Avatar
mrlanrat has yet to learn the way of the Dremel
etc
Or replace the name of the game with any other game. the saves are always located somewhere in a folder called SAVE.
mrlanrat is offline   Reply With Quote
Reply
Tags
pc
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
