#1 |
Pewlius Caesar
bit-tech Staff
Lian-Li V350
http://www.bit-tech.net/hardware/200...lian-li_v350/1
We love all cases great and small, so it's only fair that we have a look at the new MicroATX case from Lian-Li. But is the V350 a new miniature champ or just a very small shrimp in a very big ocean? We find out in our comprehensive review of this brand new case.
__________________
#2 |
CK is God!!!
i like it looks like an excellent case for my 690g
which PSU did you use?
__________________
Gaming Box:: q6600 @3.0 :: 9800gtx :: Abit IP35 :: 4gb :: 1.4TB :: akasa eclipse :: Win7 Development:: PhenomII 955BE @3.2 :: 4200 :: asus M4A785 M Evo :: 1.25TB ::Win7 Media Centre :: q6600 @3.0 :: x1950pro :: asus p35 epu :: 8gb :: 320 GB :: Lc17B :: Win7 server:: I7 860 :: p55 gd65 :: 3450 :: 8 TB :: 8gb :: Rebel 12 :: server 2008 R2 |
#3 |
Banned
Deleted
#4 |
Player Character
bit-tech Staff
Yep, an Ultra X3 600W. Well spotted Tile!
__________________
#5 |
Supermodder
"Taiwanese equivalent of John Romero running around shouting that βDesign is law!β as minions churn out incredibly gorgeous PC cases of all shapes and sizes."
John Romero shouting design is law??? I just can't work out how horrifying that sentence is. John Romero, is and always will be a complete muppet so please NO! Interesting case though but not a patch on a shuttle it seems. |
#6 |
Player Character
bit-tech Staff
Believe it or not, Design is Law used to be the slogan of Ion Storm.
http://www.penny-arcade.com/comic/1998/11/25
__________________
#7 |
Richard Swinburne
bit-tech Staff
We've found a newest height of geekdom - quoting a slogan from a late 90s game and referencing a PA cartoon parodying it.
Winn0r! |
#8 | |
I'm not a modder.
Great review, I think I will be avoiding that then...
Whats with Quote:
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#9 |
Player Character
bit-tech Staff
Well, it's obviously three larger pictures shrunk down into one. I tried for ages to get the balances and levels and detail just right on the larger pictures, but couldn't quite manage it. In the end, since the first two were already seen essentially I just skipped it to the middle pic and hope nobody would mind. If its that important to you I can sort out the other two pics individually.
__________________
#10 |
Why not? I own a domain to match.
Joe, that's most definitely a firewire 400 port on the side, not an e-SATA (bottom of p2, there was also a typo somewhere, on instead of one or something).
Anyways, nice review. I wouldn't mind seeing that kind of mini-case being used for that mid-tower Mac thing all of my fellow fanboy breathren have been hoping for *braces for impact*
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#11 | |
Player Character
bit-tech Staff
Fixed...
__________________
#12 | |
whatever
those cases are made to put hw in once, place it in your grannies living room and never open it again...
so it doesnt really matter if they arent the easiest ones to work with on the inside....
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#13 |
Player Character
bit-tech Staff
It does if your granny spills tea on it.
__________________
#14 |
Eat my...
I had a v300 and got rid of it because of those stupid little screws on both side pannels. They really are a PITA to get in when the whole frame is bent slightly.
On a plus, they have rubber mounted HDDs so they shouldn't shake rattle an roll and two nice intake fans.
__________________
PSN: koola-uk |
#15 |
Old Computer Tech
First step after assembling a system in a Lian-Li case (or before if you want to save some extra work), is to replace all the fans that came with the case with something like the Silenx or Silverstone low noise high cfrm units. The stock Lian-Li fans are quiet but provide virtually no air flow. It is also worth noting that removing the stock intake and exhaust aperatures on the case (a hole saw works well), will signifcantly increase the efficiency of the replacement fans. Lian-Li cases are elegant, however they do require modification to provide effective cooling.
| rgsaunders |
| View Public Profile |
| Find More Posts by rgsaunders |
#16 |
Multimodder
Thats far too big, i'd much rather have something like a Silverstone Sugo.
#17 |
Minimodder
Maybe we should try to blend the case.
__________________
-xpaladin |
#18 |
mother into a board?!
I never understood the point of having your optical drive on the side, now you can't put it on a corner a desk which is in the corner of a wall.a either you will not have access to the power button or the optical drive tray.
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro! |
#19 |
Pewlius Caesar
bit-tech Staff
__________________
#20 |
a.k.a KazeModz
huh well its not to bad of a case when your really look at it, and looks like there is a little more room to work with then the smaller SF cases out there, Im currently using a TT Lanbox Lite and its a nice size but a tight fit to work with everything and I shoved a water cooling system in mine too lol
__________________
Current Rig: RubyRED
Lian-Li A05B (2) Swiftech 220 Radiators (2) D5 Variable Pumps (2) Res and a whole lot of modding Retired Rig: Project F.E.A.R. TT Lanbox Lite Swiftech H2O-120 Q6600 G0 OC@3.6ghz 2900XT 4gb SuperTalent Memory |
| Thread Tools | |
