Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
DisplayPort: A Look Inside
http://www.bit-tech.net/bits/2007/10..._look_inside/1
There's a new display interface coming to town soon and we felt we needed know more about DisplayPort. After talking with some VESA members at IDF, Tim Smalley takes a deep dive into the technology and pops up on the other side...
__________________
#2 |
Deaf forever to the battle's din
DisplayPort? Bah! I haven't even moved onto DVI yet.
(New monitor soon, though) IMO, a new standard is a bad idea; it just adds confusion for the end user. Which cable do I need? Which port do I use? Will this TV work with my (HD?)DVD player? And so forth. I've yet to see the disadvantage of VGA, but then again I'm going to be needing a new monitor pretty soon, and DVI offers higher resolution. Otherwise, I don't really see why we're moving on - it just seems like manufacturers want a new specification to fatten their wallets. Somehow.
__________________
ASUS M4A785TD-M Evo | AMD Phenom II x4 955 BE | D-Tek FuZion
4GB Corsair XMMS3-10666 | Corsair TX650 Point Of View 8800GTX | EK FC-8800 |
#3 |
Trust the Computer
The annoying thing is, the laptop I bought 2 weeks ago has a VGA port. For goodness sake, why? DVI uses analogue signals as well, it just means my brand spanking new monitor isn't being used properly.
<A88> |
#4 | |
Pewlius Caesar
bit-tech Staff
![]() I see what you're saying, but there will be dongles for every major PC display interface (i.e. D-L DVI, DVI and VGA), meaning that it'll just "work" with devices using those connectors in much the same way as DVI to VGA converters work. Thus, I don't see why that is going to be a problem. Additionally, DisplayPort is designed to stop people having to worry about what connector or cable they need - they will just need DisplayPort in the future because it'll be supported by both notebooks and desktop PCs. At the moment we've got a situation where notebooks use LVDS internally and the majority have a VGA port (externally). Aside from Apple's notebooks, it's only really the Santa Rosa notebooks (released in May) that introduced a digital connection (be it DVI or HDMI). On the desktop front, things are a bit simpler, but still there's DL DVI, DVI and VGA... HDMI is more CE orientated, but it has made its way onto PC components that are CE-orientated. I certainly understand your scepticism, but this wouldn't be accepted by consumers if it wasn't backwards compatible with existing designs. If you go back to PCI-Express, that was "forced" onto the industry - I don't think the same will happen with DisplayPort, as you can handle backwards compatibility very easily.
__________________
#5 |
CPC hang out zone (i Fix pcs i do )
i think DisplayPort is an very good idea tis going to take 3-5 years before it probly takes off (users get new pcs)
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947 |
#6 |
ITS OVER 8000!
I'd be happier if it had screws in the connectors...
#7 |
Pewlius Caesar
bit-tech Staff
It's got a latch instead - having broken many screws off DVI/CrossFire dongles in the past, latches sounds like a much better idea
__________________
#8 |
UnSeenly
Supports audio and video... great.. i really don't think thats going to fly.... would have to be supported by the graphics card (the audio) and once more its one more thing to shove through that 16x pci-e slot... O i can see the performance conspiracies already.
#9 |
When did I get a custom title!?!
main reason is that the HDIM watsit has an expensive licensing fee and all your staff have to sign NDA's etc to work with it (even more expense). Personaly I think video over USB will be the most common interface in a few years time, as what is the point in a dedicated graphics interface if all your rendering is done in software (ray tracing etc).
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#10 |
Supermodder
If I was a blonde English youth in a field of green, yellow, and white on a cool spring day I would love and covet the thought of such a potent and powerful insertion connector. A long and thin black interface pulsating with feats and ability. oohh...
How far of a resolution could a 50gig bluray disc project? Surely 2 hours of movie at 1080p isn't 50. Also sand. I hope AMD's new Fusion comes with HD audio in their new DTX form factor with displayport.... That wood be gut for bizness.
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs |
#11 | |||
. Constructive criticism and all that...RE: Audio and video in one cable. It works for things like SCART/HDMI because the audio and video is always going to be coming from the same source, wheras in a PC, the graphics card and sound card will be separate, so I feel there should be two different cables. RE: DRM/Encryption (as seen on HDMI but not VGA) /paranoid This is just another way to force DRM onto consumers! Burn them!
__________________
#12 | ||||
Pewlius Caesar
bit-tech Staff
![]() Quote:
![]() Quote:
__________________
#13 | |||
Supermodder
Edit: Quote:
![]() Quote:
cheers. Note to self: calm down now and have a cup of tea
#14 |
Pewlius Caesar
bit-tech Staff
Of course it is a matter of perception, but one of the things that DisplayPort can do is to increase bit depths over and above what DVI can manage at high resolutions. If we think back a few years, the most popular display being purchased was 1280x1024... we're now looking at 1680x1050 being fairly typical, 1920x1200 is within the realms of affordability and 30" screens are around the price of 1920x1200 screens of yesteryear.
That said, there are far too many screens with 6bpc today - the millisecond myth is to blame for that. I think the minimum we should be using is 8bpc and above 10bpc, I don't think there will be many people that will be able to distinguish between 12bpc and 16bpc for example. 10bpc is right on the ragged edge of what's viewable by most human eyes, IMO.
__________________
#15 |
The Right man in the Wrong place
I remember reading about display port back in April and thought it would just another specification on the market. but I do think this might be a good idea. I'm not just sure yet. I'm waiting to see what this usb imagery is like. But if the display port would last for a good while, then it would be a great idea.
#16 |
quad fuelled, GTX200 powered
just moved to DVI
and now they are having display ports? man, i can't keep up. 2560x1600 is dual-link DVI, so i guess that if im a computer user who don't plan to have a 30inch monitor on my tiny desk, i'd be fine sticking to DVI?
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#17 | |
Pewlius Caesar
bit-tech Staff
__________________
#18 |
69 Dude!!
What's the big deal if i can still connect all my old **** to it anyway, via a dongle?
oh.. apart from random expense.
__________________
Cyberstorm-3:Athlon 64 X2 4400@4800+/xfx 7800GT oc version/2gb(2x1gb) 3500llpro corsair ram@2,3,2,6, /2x80gb sata seagates / 2x 160 sata segates/fatality xfi/Creative Inspire T7900/poineer110d/asusx16dvd a8n SLI premium mobo/samsung 930BF 19inch flat panel |
#19 | |
DUR HUR
Video via USB is interesting though, I'd like to see a higher speed USB and more and more things using it, I wouldn't mind if the computer of the future had nothing but USB ports and a couple of high speed ethernet ports the back, would make life a lot simpler if everything plugged into the same port. |
#20 | |
I Mod, Therefore I Own
i've got a whole box of dvi->vga convertors from graphics cards sounds good to me, backwards compatibility was going to be the only issue i could see with displayport but if it is literally just a free/cheapo dongle then fine
| Thread Tools | |
