RSS
Go Back   bit-tech.net Forums > Recreation > Art & Photography
Reply
Thread Tools
Old 25th Oct 2007, 04:40   #1
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
[10/07] Dying in the Dark
Taken around dusk, 1/50s f/8 ISO100, EF28-135 IS @ 30mm, remote triggered flash sitting at the base of the tree at something like 1/16 power. Exposure levels are tweaked a tiny bit in Lightroom, but no other changes.
Feedback is much appreciated, but this is one of my entries for the POTM as-is.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 25th Oct 2007, 05:16   #2
ajack
rox
ajack's Avatar
ajack is on a distinguished road
I'm not sure the subject is very interesting in this shot, and I feel the lighting is just too harsh. A wider crop might have been nicer too. Sorry if that sounds very negative but you know, constructive criticism and all.
__________________
ajack.org
DA | Flickr
select * from pants;
ajack is offline   Reply With Quote
Old 25th Oct 2007, 21:03   #3
OleJ
Me!
OleJ's Avatar
OleJ will become famous soon enough
I like it. Reminds of another picture I've seen recently. But I like it. It's frozen in a wonderful way.
__________________
Quickr! Clickr to my Flickr!
Canon camera stuff. Some aluminium PC, an HTPC and a MBP 17"..
OleJ is offline   Reply With Quote
Old 26th Oct 2007, 14:27   #4
Firehed
Firehed's Avatar
Don't apologize - nothing wrong with harsh feedback as long as there's a valid reason for it. It was a bit more blunt than I'm used to, but I appreciate it nonetheless.
The lighting hadn't come off quite the way I'd have liked, but without a pair of snooted flashes (which I don't have, yet), it's about as close as I could get. I'll consider the framing/cropping in future shots as well.
__________________
Old 26th Oct 2007, 15:34   #5
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Nexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud of
I think it has the potential to be a really interesting shot; it is just that the flash doesn't work so well because it is too narrow and focused. Try setting your camera on long (20 second or so) exposure while shining a torch at the tree, moving the beam over each part to cover everything. Having a torch shining up from the base at the same time would add to the effect nicely. I think that would work.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"There is no Real Life, only Away From Keyboard" --gpw111
"...my wife says I can't have any trolls, cause they argue with the dog and eat the fish" --KayinBlack
Nexxo is offline   Reply With Quote
Old 26th Oct 2007, 16:44   #6
Firehed
Firehed's Avatar
Hm, I was actually thinking the opposite and getting the part that's fairly well-exposed to be the only part that's exposed giving a sort of floating-branch look. I'd rather not do long-exposure if I can avoid it as I don't want to bring the background into the equation. Remember, that was 1/50 f/8. Even if I stopped down to f/32, opening it up for even two seconds or so would really start to bring out the background (not to mention screw with my strobe, as it only cares about aperture and not exposure time), as I'd be darkening by four stops via aperture but lightening by eight or nine stops if not more. That, plus white balance. I don't have any gels for my flash and don't have a powerful flashlight that's anywhere near the same color temp.
But I'll hopefully be able to give it a try at some point anyways and see what happens. Learn through experimentation, and all that, right?
__________________
Old 26th Oct 2007, 19:49   #7
supermonkey
Space Monkey
supermonkey's Avatar
supermonkey is just really nicesupermonkey is just really nicesupermonkey is just really nicesupermonkey is just really nicesupermonkey is just really nice
Reciprocity. If you stopped down to f/32, an exposure time of 1/4 second would give you roughly the same exposure as 1/50 at f/8. I say "roughly" because I'm calculating from 1/60. Either way, going out to 2 seconds would only give you 3 more stops exposure of the ambient light. If it's dark enough outside, this might not be enough to get all the background detail. If the background starts to show, some minor post processing can fix that quite easily. Same thing with white balance. You can fix that prior to the shot (by manually setting the white balance), or afterwards in the raw editor of your choice.
For snooted flashes, you can try using a toilet paper tube (or other such device). It's cheaper than an actual snoot, and may perform well enough for the effect you're after.
Light painting is great, and you can end up with some really nifty effects. Flickr has a decent gallery of the subject.
-monkey
__________________
But of bliss and of glad life there is little to be said, before it ends; as works fair and wonderful, while still they endure for eyes to see, are their own record, and only when they are in peril or broken for ever do they pass into song.
-J.R.R. Tolkien, The Silmarillion
supermonkey is offline   Reply With Quote
Old 26th Oct 2007, 19:54   #8
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Not to mention ND filters.
__________________
Old 26th Oct 2007, 21:04   #9
Ryu_ookami
Mod Master
Ryu_ookami's Avatar
Ryu_ookami is a splendid one to beholdRyu_ookami is a splendid one to beholdRyu_ookami is a splendid one to beholdRyu_ookami is a splendid one to beholdRyu_ookami is a splendid one to beholdRyu_ookami is a splendid one to beholdRyu_ookami is a splendid one to behold
Oi who said you could take pictures in my garden
nice picture
__________________
Never argue with a fool. They'll drag you down to their level and beat you with experience
All edits done by the Hellhound Grammar Nazi that is my evil GF.
Ryu_ookami is offline   Reply With Quote
Old 27th Oct 2007, 04:31   #10
Firehed
Firehed's Avatar
-monkey
I probably had some flaky math in there, but I know how the stops would work out. Regardless, it'd be considerably more exposed than as I shot (not to mention the different DOF), and I'm concerned that there would be way too much gain in the background.
Regarding the snooted flashes - I have a Strobist-style snoot for my 580II (read: piece of bent and taped cardboard) that'll get the job done. I was more commenting on the fact that I'd need at least two strobes to really do it how I want, and I only have a single.
Maybe I'll have fun with a makeshift pinhole thing. It'll let me expose as long as I need anyways.
__________________
Old 27th Oct 2007, 06:55   #11
supermonkey
Space Monkey
Since you only have one flash, you could always try a multiple exposure. Fire once at 1/50 at f/8. Then fire again with the flash in the next part of the scene. Two or even three exposures may keep your background dark, but will give you the opportunity to use the one flash multiple times.
Exposing for 2 seconds may give you more ambient light than you desire. It's hard to say without actually being there and experiencing the conditions first hand. As far as the depth of field is concerned, with the lens set at 30mm, and guesstimating your distance from the tree, you may have reached the hyperfocal distance at f/8. Given that, stopping down to f/32 won't necessarily give you any more depth of field, since everything is already sharp to infinity (for a given value of sharp).
Of course, it's 1:00am here and I may be over thinking that. It's entirely possible.
-monkey
__________________
Old 28th Oct 2007, 05:15   #12
Firehed
Firehed's Avatar
Tree was across the road from me... maybe 20-25ft or so? It was around dusk when I took the shot, more of a dark blue outside at the time, not nearly as black as it looked in the shot - the background is fantastically underexposed relative to actual conditions. Which I suppose gives me more possibilities if I reshoot it, as I can just go out later at night when there's less ambient light to worry about. Even if I were to reshoot in similar ambient lighting conditions, I probably could get another two stops more exposure and still be reasonably close to the same on the background.
__________________
Reply
Tags
potm
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
