Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 27th Oct 2007, 12:39   #1
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 has yet to learn the way of the Dremel
FSX any good?
Is fsx any good? I used to have quite a good fs2004 install which I had pretty tricked out but I got annoyed with the poor game enginie which was unable to load game tiles seamlessly and didn't have enough draw distance. I tried the FSx demo and it ran like a turd is the actual game better?
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 28th Oct 2007, 15:09   #2
eeevan
Dremel Master
eeevan's Avatar
eeevan has yet to learn the way of the Dremel
Yes, it is good. When it was released it ran like a slide show, but they have since released performance optimizations (SP1) that shoot up the overall FPS. And with the release of Acceleration, they are finally including DX10 support, which looks beautiful.
/$0.02
__________________
E6850 @ 3.85Ghz - 4GB PC6400 - 500GB WD + 250GB Seagate + 1TB Spinpoint - X-Fi Xtreme Audio - Asus P5K-E WiFi/AP - XFX 8800 Ultra @ 650/1100 - Antec Twelve Hundred
eeevan is offline   Reply With Quote
Old 28th Oct 2007, 17:13   #3
samkiller42
Considered for President!! Moi??
samkiller42's Avatar
samkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for president
/$0.02
Linky
Sam
__________________
The Laptop: Dell Vostro 3450, SB i3 2350m, 8GB DDR3, 256GB 830 SSD, Intel 6235 Wifi N/BT 4.0, Dell 5550 3G/GPS
The Server: Phenom 2 x6, 8GB DDR3, 3TB Seagate, 2TB WD Green, 2*1TB Samsung F1
samkiller42 is offline   Reply With Quote
Reply
Tags
pc
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
